GTI-24DWFIR не загружается
belokuriha
Сообщение belokuriha » 06 авг 2020, 18:59
Добрый день. Проблема с камерой , не проходит загрузка полностью. Грешу на прошивку , но как сейчас ее залить не могу понять ,подскажите , прошивка есть , терминал выдает такую картинку
Код: Выделить всё
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.10.73 (zucker@ubuntu) (gcc version 4.9.1 20140625 (prerelease) (crosstool-NG - Ambarella Linaro Multilib GCC [CortexA9 & ARMv6k] 2014.06) ) #1 PREEMPT Wed Aug 19 17:00:46 CST 2015
[    0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Ambarella S2L (Flattened Device Tree), model: Ambarella S2LM Kiwi Board
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] Ambarella:      AHB = 0xe0000000[0xe0000000],0x01000000 0
[    0.000000] Ambarella:      APB = 0xe8000000[0xe8000000],0x01000000 0
[    0.000000] Ambarella:      PPM = 0x00000000[0xdfe00000],0x00200000 9
[    0.000000] Ambarella:      AXI = 0xf0000000[0xf0000000],0x00030000 0
[    0.000000] Ambarella:    DRAMC = 0xdffe0000[0xef000000],0x00020000 0
[    0.000000] Ambarella:   DBGBUS = 0xec000000[0xec000000],0x00200000 0
[    0.000000] Ambarella:  DBGFMEM = 0xee000000[0xee000000],0x01000000 0
[    0.000000] Ambarella:   IAVMEM = 0x07000000[          ],0x09000000
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 27940
[    0.000000] Kernel command line: console=ttyS0 ubi.mtd=lnx root=ubi0:rootfs rw rootfstype=ubifs init=/linuxrc
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Memory: 110MB = 110MB total
[    0.000000] Memory: 106404k/106404k available, 6236k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0x87000000 - 0xff000000   (1920 MB)
[    0.000000]     lowmem  : 0x80000000 - 0x86e00000   ( 110 MB)
[    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[    0.000000]       .text : 0x80008000 - 0x8048c840   (4627 kB)
[    0.000000]       .init : 0x8048d000 - 0x804b01fc   ( 141 kB)
[    0.000000]       .data : 0x804b2000 - 0x804e7540   ( 214 kB)
[    0.000000]        .bss : 0x804e7540 - 0x80507538   ( 128 kB)
[    0.000000] NR_IRQS:240
[    0.000000] sched_clock: 32 bits at 36MHz, resolution 27ns, wraps every 119304ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [ttyS0] enabled
[    0.232665] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[    0.292608] pid_max: default: 32768 minimum: 301
[    0.297299] Mount-cache hash table entries: 512
[    0.304218] CPU: Testing write buffer coherency: ok
[    0.309362] Setting up static identity map for 0x80367740 - 0x80367798
[    0.318143] devtmpfs: initialized
[    0.322683] pinctrl core: initialized pinctrl subsystem
[    0.328130] NET: Registered protocol family 16
[    0.333348] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.340734] L310 cache controller enabled
[    0.344734] l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32020000, Cache size: 131072 B
[    0.354268] ambarella-pinctrl e8009000.pinctrl: Ambarella pinctrl driver registered
[    0.362272] ambarella-gpio gpio.0: Ambarella GPIO driver registered
[    0.372196] bio: create slab <bio-0> at 0
[    0.377244] ambarella-dma e0005000.dma: Ambarella DMA Engine
[    0.384645] ambarella-i2c e8003000.i2c: Ambarella I2C adapter[0] probed!
[    9.389990] ambarella-i2c e8007000.i2c: No ACK from address 0xe8, 2:0!
[    9.396506] pca953x 2-0074: failed reading register
[    9.401395] pca953x: probe of 2-0074 failed with error -16
[    9.406871] ambarella-i2c e8007000.i2c: Ambarella I2C adapter[2] probed!
[    9.414859] Switching to clocksource ambarella-cs-timer
[    9.420158] cfg80211: Calling CRDA to update world regulatory domain
[    9.432988] ambarella-sd e0002000.sdmmc0: Slot0 use bounce buffer[0x86720000<->0x06920000]
[    9.441279] ambarella-sd e0002000.sdmmc0: Slot0 req_size=0x00020000, segs=32, seg_size=0x00020000
[    9.450150] ambarella-sd e0002000.sdmmc0: Slot0 use ADMA
[    9.526645] ambarella-sd e0002000.sdmmc0: 1 slots @ 50000000Hz
[    9.532652] NET: Registered protocol family 2
[    9.540883] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[    9.547924] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    9.554294] TCP: Hash tables configured (established 1024 bind 1024)
[    9.560721] TCP: reno registered
[    9.563973] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    9.569839] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    9.576270] NET: Registered protocol family 1
[    9.580956] RPC: Registered named UNIX socket transport module.
[    9.586941] RPC: Registered udp transport module.
[    9.591650] RPC: Registered tcp transport module.
[    9.596332] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    9.603139] ambarella-adc e801d000.adc: Ambarella ADC driver init
[    9.611832] msgmni has been set to 207
[    9.616905] NET: Registered protocol family 38
[    9.621420] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    9.628940] io scheduler noop registered
[    9.632846] io scheduler deadline registered
[    9.637152] io scheduler cfq registered (default)
[    9.642506] ambarella-fb ambarella-fb.0: ambfb_probe: use prealloc.
[    9.649072] ambarella-fb ambarella-fb.0: probe p[320x240] v[320x480] c[16] b[0] l[1280] @ [0x00100000:0x00100000]!
[    9.659779] e8005000.uart: ttyS0 at MMIO 0xe8005000 (irq = 9) is a ambuart
[    9.667556] brd: module loaded
[    9.673154] loop: module loaded
[    9.678919] ambarella-nand e0001000.nand: in ecc-[1]bit mode
[    9.684563] ambarella_nand: Use On Flash BBT
[    9.688959] NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD/Spansion NAND 128MiB 3,3V 8-bit), 128MiB, page size: 2048, OOB size: 64
[    9.701642] Bad block table found at page 65472, version 0x01
[    9.708613] Bad block table found at page 65408, version 0x01
[    9.716638] 7 ofpart partitions found on MTD device amba_nand
[    9.722393] Creating 7 MTD partitions on "amba_nand":
[    9.727477] 0x000000000000-0x000000020000 : "bst"
[    9.732889] 0x000000020000-0x000000160000 : "bld"
[    9.738295] 0x000000160000-0x0000002a0000 : "ptb"
[    9.743652] 0x0000002a0000-0x000000aa0000 : "pri"
[    9.749062] 0x000000aa0000-0x000003ea0000 : "lnx"
[    9.754460] 0x000003ea0000-0x0000058a0000 : "add"
[    9.759911] 0x0000058a0000-0x000007ca0000 : "adc"
[    9.766469] ambarella-spi e0020000.spi: cs1 >= max 1
[    9.771509] spi_master spi0: spi_device register error /ahb@e0000000/spi@e0020000/spidev@1
[    9.780987] ambarella-spi e0020000.spi: Ambarella spi controller 0 created.
[    9.846556] libphy: Ambarella MII Bus: probed
[    9.851393] ambarella-eth e000e000.ethernet: Ethernet PHY[0]: 0x001cc816!
[    9.858692] ambarella-eth e000e000.ethernet: MAC Address[00:00:1b:02:4d:c8].
[    9.866035] mousedev: PS/2 mouse device common for all mice
[    9.875014] ambarella-rtc e8015000.rtc: rtc core: registered rtc-ambarella as rtc0
[    9.882779] i2c /dev entries driver
[    9.886947] ambarella-wdt e800c000.wdt: Ambarella Watchdog Timer Probed.
[    9.894000] TCP: cubic registered
[    9.897369] Initializing XFRM netlink socket
[    9.901674] NET: Registered protocol family 17
[    9.906200] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    9.913904] ThumbEE CPU extension supported.
[    9.919343] UBI: attaching mtd4 to ubi0
[   10.068821] UBI: scanning is finished
[   10.078148] UBI: attached mtd4 (name "lnx", size 52 MiB) to ubi0
[   10.084139] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[   10.090953] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[   10.097650] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[   10.104499] UBI: good PEBs: 416, bad PEBs: 0, corrupted PEBs: 0
[   10.110406] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[   10.117529] UBI: max/mean erase counter: 67/7, WL threshold: 4096, image sequence number: 1289759144
[   10.126643] UBI: available PEBs: 0, total reserved PEBs: 416, PEBs reserved for bad PEB handling: 20
[   10.135753] UBI: background thread "ubi_bgt0d" started, PID 50
[   10.141616] ambarella-rtc e8015000.rtc: setting system clock to 2106-02-07 06:28:15 UTC (4294967295)
^[[   10.151970] UBIFS: background thread "ubifs_bgt0_0" started, PID 51
[   10.180061] UBIFS: recovery needed
[   10.235193] UBIFS: recovery completed
[   10.239098] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[   10.245153] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[   10.254369] UBIFS: FS size: 48377856 bytes (46 MiB, 381 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[   10.264048] UBIFS: reserved for root: 0 bytes (0 KiB)
[   10.269109] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 82450C95-ED86-48FB-9F48-F796C332D68E, small LPT model
[   10.280648] VFS: Mounted root (ubifs filesystem) on device 0:12.
[   10.287323] devtmpfs: mounted
[   10.290443] Freeing unused kernel memory: 140K (8048d000 - 804b0000)
^[^[^[^[Disable kswapd write
^[Populating s2lm_kiwi using udev: [   11.041724] systemd-udevd[189]: starting version 215
^[Done
^[Initializing random number generator... done.
Starting system message bus: ^[done
Starting PulseAudio Daemon: ^[OK
###### Starting userd.sh #####
[   11.870393] UBI: attaching mtd6 to ubi1
[   11.874466] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58a0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58a0000!
^[[   11.892079] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 0:0, read only 64 bytes, retry
[   12.005227] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58a0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58a0000!
^[[   12.023078] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 0:0, read only 64 bytes, retry
[   12.057843] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58a0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58a0000!
[   12.075394] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 0:0, read only 64 bytes, retry
[   12.106680] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58a0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58a0000!
[   12.124200] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 0:0, read 64 bytes
[   12.134024] CPU: 0 PID: 228 Comm: ubiattach Not tainted 3.10.73 #1
[   12.140236] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   12.148856] [<80011a14>] (show_stack+0x10/0x14) from [<802562a0>] (ubi_io_read+0x13c/0x384)
[   12.157205] [<802562a0>] (ubi_io_read+0x13c/0x384) from [<80256720>] (ubi_io_read_ec_hdr+0x5c/0x35c)
[   12.166319] [<80256720>] (ubi_io_read_ec_hdr+0x5c/0x35c) from [<8025cc0c>] (scan_all.constprop.8+0xec/0xb78)
[   12.176140] [<8025cc0c>] (scan_all.constprop.8+0xec/0xb78) from [<8025daa0>] (ubi_attach+0x94/0x190)
[   12.185276] [<8025daa0>] (ubi_attach+0x94/0x190) from [<8024f944>] (ubi_attach_mtd_dev+0x20c/0x808)
^[[   12.194384] [<8024f944>] (ubi_attach_mtd_dev+0x20c/0x808) from [<8025149c>] (ctrl_cdev_ioctl+0xf4/0x22c)
[   12.204031] [<8025149c>] (ctrl_cdev_ioctl+0xf4/0x22c) from [<800b1aac>] (do_vfs_ioctl+0x3f8/0x5ac)
[   12.212994] [<800b1aac>] (do_vfs_ioctl+0x3f8/0x5ac) from [<800b1c98>] (SyS_ioctl+0x38/0x60)
[   12.221346] [<800b1c98>] (SyS_ioctl+0x38/0x60) from [<8000ecc0>] (ret_fast_syscall+0x0/0x30)
[   12.230143] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58c0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58c0000!
[   12.247642] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 1:0, read only 64 bytes, retry
[   12.258802] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58c0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58c0000!
[   12.276285] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 1:0, read only 64 bytes, retry
[   12.287442] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58c0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58c0000!
[   12.304925] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 1:0, read only 64 bytes, retry
[   12.316082] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58c0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58c0000!
^[[   12.333611] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 1:0, read 64 bytes
[   12.343560] CPU: 0 PID: 228 Comm: ubiattach Not tainted 3.10.73 #1
[   12.349758] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   12.358372] [<80011a14>] (show_stack+0x10/0x14) from [<802562a0>] (ubi_io_read+0x13c/0x384)
[   12.366720] [<802562a0>] (ubi_io_read+0x13c/0x384) from [<80256720>] (ubi_io_read_ec_hdr+0x5c/0x35c)
[   12.375833] [<80256720>] (ubi_io_read_ec_hdr+0x5c/0x35c) from [<8025cc0c>] (scan_all.constprop.8+0xec/0xb78)
[   12.385653] [<8025cc0c>] (scan_all.constprop.8+0xec/0xb78) from [<8025daa0>] (ubi_attach+0x94/0x190)
[   12.394784] [<8025daa0>] (ubi_attach+0x94/0x190) from [<8024f944>] (ubi_attach_mtd_dev+0x20c/0x808)
[   12.403823] [<8024f944>] (ubi_attach_mtd_dev+0x20c/0x808) from [<8025149c>] (ctrl_cdev_ioctl+0xf4/0x22c)
[   12.413296] [<8025149c>] (ctrl_cdev_ioctl+0xf4/0x22c) from [<800b1aac>] (do_vfs_ioctl+0x3f8/0x5ac)
[   12.422248] [<800b1aac>] (do_vfs_ioctl+0x3f8/0x5ac) from [<800b1c98>] (SyS_ioctl+0x38/0x60)
[   12.430594] [<800b1c98>] (SyS_ioctl+0x38/0x60) from [<8000ecc0>] (ret_fast_syscall+0x0/0x30)
[   12.439362] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58e0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58e0000!
[   12.456856] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 2:0, read only 64 bytes, retry
[   12.468012] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58e0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58e0000!
[   12.485495] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 2:0, read only 64 bytes, retry
[   12.496649] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58e0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58e0000!
[   12.514131] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 2:0, read only 64 bytes, retry
[   12.525282] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x58e0000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x58e0000!
[   12.542768] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 2:0, read 64 bytes
[   12.552583] CPU: 0 PID: 228 Comm: ubiattach Not tainted 3.10.73 #1
[   12.558771] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   12.567383] [<80011a14>] (show_stack+0x10/0x14) from [<802562a0>] (ubi_io_read+0x13c/0x384)
[   12.575714] [<802562a0>] (ubi_io_read+0x13c/0x384) from [<80256720>] (ubi_io_read_ec_hdr+0x5c/0x35c)
[   12.584839] [<80256720>] (ubi_io_read_ec_hdr+0x5c/0x35c) from [<8025cc0c>] (scan_all.constprop.8+0xec/0xb78)
[   12.594656] [<8025cc0c>] (scan_all.constprop.8+0xec/0xb78) from [<8025daa0>] (ubi_attach+0x94/0x190)
[   12.603785] [<8025daa0>] (ubi_attach+0x94/0x190) from [<8024f944>] (ubi_attach_mtd_dev+0x20c/0x808)
[   12.612823] [<8024f944>] (ubi_attach_mtd_dev+0x20c/0x808) from [<8025149c>] (ctrl_cdev_ioctl+0xf4/0x22c)
[   12.622295] [<8025149c>] (ctrl_cdev_ioctl+0xf4/0x22c) from [<800b1aac>] (do_vfs_ioctl+0x3f8/0x5ac)
[   12.631253] [<800b1aac>] (do_vfs_ioctl+0x3f8/0x5ac) from [<800b1c98>] (SyS_ioctl+0x38/0x60)
[   12.639600] [<800b1c98>] (SyS_ioctl+0x38/0x60) from [<8000ecc0>] (ret_fast_syscall+0x0/0x30)
[   12.648724] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x5920000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x5920000!
[   12.666212] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 4:0, read only 64 bytes, retry
[   12.677368] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x5920000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x5920000!
[   12.694851] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 4:0, read only 64 bytes, retry
[   12.706003] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x5920000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x5920000!
[   12.723484] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 4:0, read only 64 bytes, retry
[   12.734636] ambarella-nand e0001000.nand: nand_amb_request: dma_status=0x05000800, cmd=0xe, addr_hi=0x0, addr=0x5920000, dst=0x0, buf=0x69c3000, len=0x800, area=0x2, ecc=0x2, block addr=0x5920000!
[   12.752120] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 4:0, read 64 bytes
[   12.761935] CPU: 0 PID: 228 Comm: ubiattach Not tainted 3.10.73 #1
[   12.768124] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   12.776735] [<80011a14>] (show_stack+0x10/0x14) from [<802562a0>] (ubi_io_read+0x13c/0x384)
[   12.785065] [<802562a0>] (ubi_io_read+0x13c/0x384) from [<80256720>] (ubi_io_read_ec_hdr+0x5c/0x35c)
[   12.794191] [<80256720>] (ubi_io_read_ec_hdr+0x5c/0x35c) from [<8025cc0c>] (scan_all.constprop.8+0xec/0xb78)
[   12.804009] [<8025cc0c>] (scan_all.constprop.8+0xec/0xb78) from [<8025daa0>] (ubi_attach+0x94/0x190)
[   12.813137] [<8025daa0>] (ubi_attach+0x94/0x190) from [<8024f944>] (ubi_attach_mtd_dev+0x20c/0x808)
[   12.822176] [<8024f944>] (ubi_attach_mtd_dev+0x20c/0x808) from [<8025149c>] (ctrl_cdev_ioctl+0xf4/0x22c)
[   12.831648] [<8025149c>] (ctrl_cdev_ioctl+0xf4/0x22c) from [<800b1aac>] (do_vfs_ioctl+0x3f8/0x5ac)
[   12.840600] [<800b1aac>] (do_vfs_ioctl+0x3f8/0x5ac) from [<800b1c98>] (SyS_ioctl+0x38/0x60)
[   12.848946] [<800b1c98>] (SyS_ioctl+0x38/0x60) from [<8000ecc0>] (ret_fast_syscall+0x0/0x30)
[   13.856705] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   14.856601] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000005
[   14.864586] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 5:0, read only 64 bytes, retry
[   15.856585] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000003
[   16.856593] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000003
[   16.864552] UBI warning: ubi_io_read: error -74 (ECC error) while reading 188 bytes from PEB 326:78784, read only 188 bytes, retry
[   17.856586] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   18.856592] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   18.864554] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 5:0, read only 64 bytes, retry
[   19.856739] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xc timeout 0x00000007
[   20.856583] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xf timeout 0x00000006
[   20.864544] UBI error: ubi_io_write: error -5 while writing 2048 bytes to PEB 324:51200, written 0 bytes
[   20.874034] CPU: 0 PID: 230 Comm: pulseaudio Not tainted 3.10.73 #1
[   20.880334] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   20.888968] [<80011a14>] (show_stack+0x10/0x14) from [<80257580>] (ubi_io_write+0x528/0x698)
[   20.897408] [<80257580>] (ubi_io_write+0x528/0x698) from [<80253964>] (ubi_eba_write_leb+0x90/0x91c)
[   20.906519] [<80253964>] (ubi_eba_write_leb+0x90/0x91c) from [<80252480>] (ubi_leb_write+0xe4/0x140)
[   20.915647] [<80252480>] (ubi_leb_write+0xe4/0x140) from [<801667d8>] (ubifs_leb_write+0xa0/0x140)
[   20.924599] [<801667d8>] (ubifs_leb_write+0xa0/0x140) from [<801673cc>] (ubifs_wbuf_sync_nolock+0x110/0x3c8)
[   20.934425] [<801673cc>] (ubifs_wbuf_sync_nolock+0x110/0x3c8) from [<80158d70>] (ubifs_jnl_update+0x2cc/0x6b4)
[   20.944423] [<80158d70>] (ubifs_jnl_update+0x2cc/0x6b4) from [<80160320>] (ubifs_create+0x110/0x1fc)
[   20.953554] [<80160320>] (ubifs_create+0x110/0x1fc) from [<800ab8c8>] (vfs_create+0x7c/0xbc)
[   20.961988] [<800ab8c8>] (vfs_create+0x7c/0xbc) from [<800adf40>] (do_last.isra.60+0x634/0xcac)
[   20.970682] [<800adf40>] (do_last.isra.60+0x634/0xcac) from [<800ae664>] (path_openat.isra.61+0xac/0x468)
[   20.980242] [<800ae664>] (path_openat.isra.61+0xac/0x468) from [<800af81c>] (do_filp_open+0x2c/0x88)
[   20.989368] [<800af81c>] (do_filp_open+0x2c/0x88) from [<800a092c>] (do_sys_open+0xe0/0x174)
[   20.997803] [<800a092c>] (do_sys_open+0xe0/0x174) from [<8000ecc0>] (ret_fast_syscall+0x0/0x30)
[   21.856580] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000003
[   22.856765] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000003
[   23.856580] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000003
[   24.856593] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000003
[   25.856687] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000003
[   26.856585] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000003
[   26.864556] UBI warning: ubi_io_read: error -74 (ECC error) while reading 3115 bytes from PEB 169:18312, read only 3115 bytes, retry
[   27.856582] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   28.856699] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   28.864654] UBI error: ubi_dump_flash: error -74 while reading 2048 bytes from PEB 324:51200, read 2048 bytes
[   28.874585] UBI warning: ubi_eba_write_leb: failed to write data to PEB 324
[   28.881564] UBI: recover PEB 324, move data to PEB 342
^C[   29.856581] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   30.856589] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   30.864551] UBI warning: ubi_io_read: error -74 (ECC error) while reading 188 bytes from PEB 326:78784, read only 188 bytes, retry
[   31.856585] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   32.856589] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   33.856580] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   34.856687] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   35.856578] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   36.856586] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   36.864551] UBI warning: ubi_io_read: error -74 (ECC error) while reading 3115 bytes from PEB 169:18312, read only 3115 bytes, retry
[   37.856656] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   38.856589] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   38.864551] UBI warning: ubi_io_read: error -74 (ECC error) while reading 188 bytes from PEB 326:78784, read only 188 bytes, retry
[   39.856579] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   40.856690] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   41.856601] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   42.856586] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   43.856649] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   44.856588] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   44.864555] UBI warning: ubi_io_read: error -74 (ECC error) while reading 3115 bytes from PEB 169:18312, read only 3115 bytes, retry
[   45.856578] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   46.856582] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   46.864540] UBI error: ubi_io_read: error -74 (ECC error) while reading 188 bytes from PEB 326:78784, read 188 bytes
[   46.875060] CPU: 0 PID: 199 Comm: udevd Not tainted 3.10.73 #1
[   46.880922] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   46.889540] [<80011a14>] (show_stack+0x10/0x14) from [<802562a0>] (ubi_io_read+0x13c/0x384)
[   46.897894] [<802562a0>] (ubi_io_read+0x13c/0x384) from [<80253580>] (ubi_eba_read_leb+0x194/0x4e8)
[   46.906933] [<80253580>] (ubi_eba_read_leb+0x194/0x4e8) from [<802522e0>] (ubi_leb_read+0xcc/0x188)
[   46.915960] [<802522e0>] (ubi_leb_read+0xcc/0x188) from [<801666d8>] (ubifs_leb_read+0x28/0x88)
[   46.924652] [<801666d8>] (ubifs_leb_read+0x28/0x88) from [<80168778>] (ubifs_read_node+0xac/0x304)
[   46.933604] [<80168778>] (ubifs_read_node+0xac/0x304) from [<8018aba4>] (ubifs_load_znode+0x8c/0x60c)
[   46.942817] [<8018aba4>] (ubifs_load_znode+0x8c/0x60c) from [<8016c32c>] (ubifs_lookup_level0+0xd4/0x390)
[   46.952374] [<8016c32c>] (ubifs_lookup_level0+0xd4/0x390) from [<8016c63c>] (ubifs_tnc_locate+0x54/0x1e8)
[   46.961939] [<8016c63c>] (ubifs_tnc_locate+0x54/0x1e8) from [<8015c1b8>] (do_readpage+0x1a4/0x544)
[   46.970895] [<8015c1b8>] (do_readpage+0x1a4/0x544) from [<8015d878>] (ubifs_readpage+0x38/0x4a0)
[   46.979678] [<8015d878>] (ubifs_readpage+0x38/0x4a0) from [<80070380>] (filemap_fault+0x284/0x44c)
[   46.988636] [<80070380>] (filemap_fault+0x284/0x44c) from [<800883b8>] (__do_fault+0x68/0x514)
[   46.997245] [<800883b8>] (__do_fault+0x68/0x514) from [<8008b438>] (handle_pte_fault+0x78/0x728)
[   47.006012] [<8008b438>] (handle_pte_fault+0x78/0x728) from [<8008bb84>] (handle_mm_fault+0x9c/0xcc)
[   47.015138] [<8008bb84>] (handle_mm_fault+0x9c/0xcc) from [<800148e4>] (do_page_fault+0x1c4/0x290)
[   47.024090] [<800148e4>] (do_page_fault+0x1c4/0x290) from [<80008480>] (do_PrefetchAbort+0x34/0x9c)
[   47.033132] [<80008480>] (do_PrefetchAbort+0x34/0x9c) from [<8000ec54>] (ret_from_exception+0x0/0x10)
[   47.042335] Exception stack(0x86975fb0 to 0x86975ff8)
[   47.047381] 5fa0:                                     76d3e1f8 76eb22f8 0000bf44 76d32f44
[   47.055535] 5fc0: 76d3def4 774e8338 0000000a 7eb7f588 0000000e ffffffff 76f6af90 7eb7f548
[   47.063699] 5fe0: 76ddcbb9 7eb7f548 76f2de8f 76d32f44 600d0010 ffffffff
[   47.070309] UBIFS error (pid 199): ubifs_read_node: bad node type (25 but expected 9)
[   47.078131] UBIFS error (pid 199): ubifs_read_node: bad node at LEB 324:74688, LEB mapping status 1
[   47.087158] Not a node, first 24 bytes:
[   47.090807] 00000000: 93 05 00 00 69 01 00 00 0d 00 00 20 ff ff ff ff 31 18 10 06 19 01 d6 a6                          ....i...... ....1.......
[   47.103823] CPU: 0 PID: 199 Comm: udevd Not tainted 3.10.73 #1
[   47.109661] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   47.118271] [<80011a14>] (show_stack+0x10/0x14) from [<80168968>] (ubifs_read_node+0x29c/0x304)
[   47.126964] [<80168968>] (ubifs_read_node+0x29c/0x304) from [<8018aba4>] (ubifs_load_znode+0x8c/0x60c)
[   47.136248] [<8018aba4>] (ubifs_load_znode+0x8c/0x60c) from [<8016c32c>] (ubifs_lookup_level0+0xd4/0x390)
[   47.145806] [<8016c32c>] (ubifs_lookup_level0+0xd4/0x390) from [<8016c63c>] (ubifs_tnc_locate+0x54/0x1e8)
[   47.155366] [<8016c63c>] (ubifs_tnc_locate+0x54/0x1e8) from [<8015c1b8>] (do_readpage+0x1a4/0x544)
[   47.164320] [<8015c1b8>] (do_readpage+0x1a4/0x544) from [<8015d878>] (ubifs_readpage+0x38/0x4a0)
[   47.173099] [<8015d878>] (ubifs_readpage+0x38/0x4a0) from [<80070380>] (filemap_fault+0x284/0x44c)
[   47.182052] [<80070380>] (filemap_fault+0x284/0x44c) from [<800883b8>] (__do_fault+0x68/0x514)
[   47.190658] [<800883b8>] (__do_fault+0x68/0x514) from [<8008b438>] (handle_pte_fault+0x78/0x728)
[   47.199438] [<8008b438>] (handle_pte_fault+0x78/0x728) from [<8008bb84>] (handle_mm_fault+0x9c/0xcc)
[   47.208563] [<8008bb84>] (handle_mm_fault+0x9c/0xcc) from [<800148e4>] (do_page_fault+0x1c4/0x290)
[   47.217513] [<800148e4>] (do_page_fault+0x1c4/0x290) from [<80008480>] (do_PrefetchAbort+0x34/0x9c)
[   47.226538] [<80008480>] (do_PrefetchAbort+0x34/0x9c) from [<8000ec54>] (ret_from_exception+0x0/0x10)
[   47.235739] Exception stack(0x86975fb0 to 0x86975ff8)
[   47.240782] 5fa0:                                     76d3e1f8 76eb22f8 0000bf44 76d32f44
[   47.248949] 5fc0: 76d3def4 774e8338 0000000a 7eb7f588 0000000e ffffffff 76f6af90 7eb7f548
[   47.257112] 5fe0: 76ddcbb9 7eb7f548 76f2de8f 76d32f44 600d0010 ffffffff
[   47.263708] UBIFS error (pid 199): do_readpage: cannot read page 11 of inode 361, error -22
[   47.856586] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   48.856585] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   49.856684] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   50.856578] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   51.856594] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   52.856670] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   52.864637] UBI error: ubi_io_read: error -74 (ECC error) while reading 3115 bytes from PEB 169:18312, read 3115 bytes
[   52.875337] CPU: 0 PID: 198 Comm: udevd Not tainted 3.10.73 #1
[   52.881199] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   52.889817] [<80011a14>] (show_stack+0x10/0x14) from [<802562a0>] (ubi_io_read+0x13c/0x384)
[   52.898165] [<802562a0>] (ubi_io_read+0x13c/0x384) from [<80253580>] (ubi_eba_read_leb+0x194/0x4e8)
[   52.907203] [<80253580>] (ubi_eba_read_leb+0x194/0x4e8) from [<802522e0>] (ubi_leb_read+0xcc/0x188)
[   52.916229] [<802522e0>] (ubi_leb_read+0xcc/0x188) from [<801666d8>] (ubifs_leb_read+0x28/0x88)
[   52.924921] [<801666d8>] (ubifs_leb_read+0x28/0x88) from [<80169b48>] (fallible_read_node+0x88/0x2fc)
[   52.934135] [<80169b48>] (fallible_read_node+0x88/0x2fc) from [<8016c6ec>] (ubifs_tnc_locate+0x104/0x1e8)
[   52.943701] [<8016c6ec>] (ubifs_tnc_locate+0x104/0x1e8) from [<8015c1b8>] (do_readpage+0x1a4/0x544)
[   52.952743] [<8015c1b8>] (do_readpage+0x1a4/0x544) from [<8015d878>] (ubifs_readpage+0x38/0x4a0)
[   52.961525] [<8015d878>] (ubifs_readpage+0x38/0x4a0) from [<80070380>] (filemap_fault+0x284/0x44c)
[   52.970484] [<80070380>] (filemap_fault+0x284/0x44c) from [<800883b8>] (__do_fault+0x68/0x514)
[   52.979094] [<800883b8>] (__do_fault+0x68/0x514) from [<8008b438>] (handle_pte_fault+0x78/0x728)
[   52.987876] [<8008b438>] (handle_pte_fault+0x78/0x728) from [<8008bb84>] (handle_mm_fault+0x9c/0xcc)
[   52.997120] [<8008bb84>] (handle_mm_fault+0x9c/0xcc) from [<800148e4>] (do_page_fault+0x1c4/0x290)
[   53.006064] [<800148e4>] (do_page_fault+0x1c4/0x290) from [<80008480>] (do_PrefetchAbort+0x34/0x9c)
[   53.015122] [<80008480>] (do_PrefetchAbort+0x34/0x9c) from [<8000ec54>] (ret_from_exception+0x0/0x10)
[   53.024329] Exception stack(0x8696ffb0 to 0x8696fff8)
[   53.029403] ffa0:                                     00000000 00000000 00000000 00000001
[   53.037580] ffc0: 774e8270 00000000 774df3f8 0000000a 00000000 76f7d020 76f6af90 7eb7fc30
[   53.045732] ffe0: 76f7cd20 7eb7f5c0 76f5fb6f 76f615b4 60060030 ffffffff
[   53.052346] UBIFS error (pid 198): ubifs_leb_read: reading 3115 bytes from LEB 167:14216 failed, error -74
[   53.061988] CPU: 0 PID: 198 Comm: udevd Not tainted 3.10.73 #1
[   53.067825] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   53.076419] [<80011a14>] (show_stack+0x10/0x14) from [<80166730>] (ubifs_leb_read+0x80/0x88)
[   53.084853] [<80166730>] (ubifs_leb_read+0x80/0x88) from [<80169b48>] (fallible_read_node+0x88/0x2fc)
[   53.094066] [<80169b48>] (fallible_read_node+0x88/0x2fc) from [<8016c6ec>] (ubifs_tnc_locate+0x104/0x1e8)
[   53.103627] [<8016c6ec>] (ubifs_tnc_locate+0x104/0x1e8) from [<8015c1b8>] (do_readpage+0x1a4/0x544)
[   53.112667] [<8015c1b8>] (do_readpage+0x1a4/0x544) from [<8015d878>] (ubifs_readpage+0x38/0x4a0)
[   53.121446] [<8015d878>] (ubifs_readpage+0x38/0x4a0) from [<80070380>] (filemap_fault+0x284/0x44c)
[   53.130401] [<80070380>] (filemap_fault+0x284/0x44c) from [<800883b8>] (__do_fault+0x68/0x514)
[   53.139008] [<800883b8>] (__do_fault+0x68/0x514) from [<8008b438>] (handle_pte_fault+0x78/0x728)
[   53.147787] [<8008b438>] (handle_pte_fault+0x78/0x728) from [<8008bb84>] (handle_mm_fault+0x9c/0xcc)
[   53.156911] [<8008bb84>] (handle_mm_fault+0x9c/0xcc) from [<800148e4>] (do_page_fault+0x1c4/0x290)
[   53.165848] [<800148e4>] (do_page_fault+0x1c4/0x290) from [<80008480>] (do_PrefetchAbort+0x34/0x9c)
[   53.174886] [<80008480>] (do_PrefetchAbort+0x34/0x9c) from [<8000ec54>] (ret_from_exception+0x0/0x10)
[   53.184088] Exception stack(0x8696ffb0 to 0x8696fff8)
[   53.189131] ffa0:                                     00000000 00000000 00000000 00000001
[   53.197296] ffc0: 774e8270 00000000 774df3f8 0000000a 00000000 76f7d020 76f6af90 7eb7fc30
[   53.205447] ffe0: 76f7cd20 7eb7f5c0 76f5fb6f 76f615b4 60060030 ffffffff
[   53.212052] UBIFS error (pid 198): try_read_node: cannot read node type 1 from LEB 167:14216, error -74
[   53.856585] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   54.856581] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   54.864533] UBI warning: ubi_io_read: error -74 (ECC error) while reading 188 bytes from PEB 326:78784, read only 188 bytes, retry
[   55.856676] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   56.856579] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   56.864532] UBI warning: ubi_io_read: error -74 (ECC error) while reading 2048 bytes from PEB 324:2048, read only 2048 bytes, retry
[   57.856592] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   58.856673] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   58.864625] UBI warning: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 5:0, read only 64 bytes, retry
[   59.856581] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   60.856580] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   60.864528] UBI warning: ubi_io_read: error -74 (ECC error) while reading 188 bytes from PEB 326:78784, read only 188 bytes, retry
[   61.856664] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   62.856579] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   62.864533] UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 5:0, read 64 bytes
[   62.874359] CPU: 0 PID: 228 Comm: ubiattach Not tainted 3.10.73 #1
[   62.880565] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   62.889182] [<80011a14>] (show_stack+0x10/0x14) from [<802562a0>] (ubi_io_read+0x13c/0x384)
[   62.897532] [<802562a0>] (ubi_io_read+0x13c/0x384) from [<80256720>] (ubi_io_read_ec_hdr+0x5c/0x35c)
[   62.906661] [<80256720>] (ubi_io_read_ec_hdr+0x5c/0x35c) from [<8025cc0c>] (scan_all.constprop.8+0xec/0xb78)
[   62.916467] [<8025cc0c>] (scan_all.constprop.8+0xec/0xb78) from [<8025daa0>] (ubi_attach+0x94/0x190)
[   62.925605] [<8025daa0>] (ubi_attach+0x94/0x190) from [<8024f944>] (ubi_attach_mtd_dev+0x20c/0x808)
[   62.934646] [<8024f944>] (ubi_attach_mtd_dev+0x20c/0x808) from [<8025149c>] (ctrl_cdev_ioctl+0xf4/0x22c)
[   62.944123] [<8025149c>] (ctrl_cdev_ioctl+0xf4/0x22c) from [<800b1aac>] (do_vfs_ioctl+0x3f8/0x5ac)
[   62.953077] [<800b1aac>] (do_vfs_ioctl+0x3f8/0x5ac) from [<800b1c98>] (SyS_ioctl+0x38/0x60)
[   62.961424] [<800b1c98>] (SyS_ioctl+0x38/0x60) from [<8000ecc0>] (ret_fast_syscall+0x0/0x30)
[   63.856596] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   64.856674] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   64.864625] UBI warning: ubi_io_read: error -74 (ECC error) while reading 188 bytes from PEB 326:78784, read only 188 bytes, retry
[   65.856581] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   66.856579] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   66.864527] UBI warning: ubi_io_read: error -74 (ECC error) while reading 2048 bytes from PEB 5:2048, read only 2048 bytes, retry
[   67.856667] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   68.856579] ambarella-nand e0001000.nand: nand_amb_request: cmd=0xe timeout 0x00000007
[   68.864535] UBI error: ubi_io_read: error -74 (ECC error) while reading 188 bytes from PEB 326:78784, read 188 bytes
[   68.875055] CPU: 0 PID: 201 Comm: udevd Not tainted 3.10.73 #1
[   68.880914] [<800133ac>] (unwind_backtrace+0x0/0x12c) from [<80011a14>] (show_stack+0x10/0x14)
[   68.889530] [<80011a14>] (show_stack+0x10/0x14) from [<802562a0>] (ubi_io_read+0x13c/0x384)
[   68.897878] [<802562a0>] (ubi_io_read+0x13c/0x384) from [<80253580>] (ubi_eba_read_leb+0x194/0x4e8)
[   68.906915] [<80253580>] (ubi_eba_read_leb+0x194/0x4e8) from [<802522e0>] (ubi_leb_read+0xcc/0x188)
[   68.915941] [<802522e0>] (ubi_leb_read+0xcc/0x188) from [<801666d8>] (ubifs_leb_read+0x28/0x88)
[   68.924633] [<801666d8>] (ubifs_leb_read+0x28/0x88) from [<80168778>] (ubifs_read_node+0xac/0x304)
[   68.933585] [<80168778>] (ubifs_read_node+0xac/0x304) from [<8018aba4>] (ubifs_load_znode+0x8c/0x60c)
[   68.942798] [<8018aba4>] (ubifs_load_znode+0x8c/0x60c) from [<8016c32c>] (ubifs_lookup_level0+0xd4/0x390)
[   68.952357] [<8016c32c>] (ubifs_lookup_level0+0xd4/0x390) from [<8016c63c>] (ubifs_tnc_locate+0x54/0x1e8)
[   68.961921] [<8016c63c>] (ubifs_tnc_locate+0x54/0x1e8) from [<8015c1b8>] (do_readpage+0x1a4/0x544)
[   68.970876] [<8015c1b8>] (do_readpage+0x1a4/0x544) from [<8015d878>] (ubifs_readpage+0x38/0x4a0)
[   68.979658] [<8015d878>] (ubifs_readpage+0x38/0x4a0) from [<80070288>] (filemap_fault+0x18c/0x44c)
[   68.988616] [<80070288>] (filemap_fault+0x18c/0x44c) from [<800883b8>] (__do_fault+0x68/0x514)
[   68.997225] [<800883b8>] (__do_fault+0x68/0x514) from [<8008b438>] (handle_pte_fault+0x78/0x728)
[   69.005991] [<8008b438>] (handle_pte_fault+0x78/0x728) from [<8008bb84>] (handle_mm_fault+0x9c/0xcc)
[   69.015117] [<8008bb84>] (handle_mm_fault+0x9c/0xcc) from [<800148e4>] (do_page_fault+0x1c4/0x290)
[   69.024068] [<800148e4>] (do_page_fault+0x1c4/0x290) from [<80008480>] (do_PrefetchAbort+0x34/0x9c)
[   69.033108] [<80008480>] (do_PrefetchAbort+0x34/0x9c) from [<8000ec54>] (ret_from_exception+0x0/0x10)
[   69.042310] Exception stack(0x8698ffb0 to 0x8698fff8)
[   69.047354] ffa0:                                     76d3e1f8 76eb22f8 0000bf44 76d32f44
[   69.055508] ffc0: 76d3def4 774e8338 0000000a 7eb7f588 0000000e ffffffff 76f6af90 7eb7f548
[   69.063671] ffe0: 76ddcbb9 7eb7f548 76f2de8f 76d32f44 600d0010 ffffffff
[   69.070281] UBIFS error (pid 201): ubifs_read_node: bad node type (25 but expected 9)
[   69.078102] UBIFS error (pid 201): ubifs_read_node: bad node at LEB 324:74688, LEB mapping status 1
[   69.087130] Not a node, first 24 bytes:
[   69.090778] 00000000: 93 05 00 00 69 01 00 00 0d 00 00 20 ff ff ff ff 31 18 10 06 19 01 d6 a6                          ....i...... ....1.......
[   69.103796] CPU: 0 PID: 201 Comm: udevd Not tainted 3.10.73 #1
Пожет как то по TFTP залиться можно ? или это нанд пришел конец ?
VirtualLink
Re: GTI-24DWFIR не загружается
Сообщение VirtualLink » 06 авг 2020, 19:08
Грешить не надо!
Прошивка где?!
Загрузчик останавливал?!
belokuriha
Сообщение belokuriha » 07 авг 2020, 04:50
Как остановить ? прошивка , но умаю не совсем от нее , нашел по названию с платы , от производителя я почему то не смог найти .
belokuriha
Сообщение belokuriha » 07 авг 2020, 04:53
да , по железу могу сказать -
CPU - Ambarella S2L-M-A1-RH
LAN -RTL8201F
RAM -H5TQ2G63FFR
ROM-ML01G200BHIOO
Зашел в AMBROOT
Код: Выделить всё
             ___  ___  _________                _
            / _ \ |  \/  || ___ \              | |
           / /_\ \| .  . || |_/ /  ___    ___  | |_
           |  _  || |\/| || ___ \ / _ \  / _ \ | __|
           | | | || |  | || |_/ /| (_) || (_) || |_
           \_| |_/\_|  |_/\____/  \___/  \___/  \__|
Amboot(R) Ambarella(R) Copyright (C) 2004-2014
Boot From: NAND 2048 RC
SYS_CONFIG: 0x300600DB POC: 101
Cortex freq: 600000000
iDSP freq: 144000000
Dram freq: 528000000
Core freq: 144000000
AHB freq: 72000000
APB freq: 36000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
amboot>
The following commands are supported:
r32 w32 boot erase
help reboot setenv show
memtest fs fdt nand
usbdl gpio tftp ping
sd
Use 'help' to get help on a specific command
amboot>
Код: Выделить всё
amboot> show ptb
bst: 0x56265C79 1.3     (2015/8/20)     0x00000000 0x00000001 (2048)
bld: 0xA9F13FC5 1.3     (2015/8/20)     0x00000000 0x00000000 (193168)
pri: 0xBB89A3F1 0.1     (2015/8/20)     0x00208000 0x00000000 (5109056)
lnx: 0xA58A190C 0.1     (2015/8/20)     0x00000000 0x00000001 (43384832)
add: 0xC493B563 0.1     (2015/8/20)     0x00000000 0x00000001 (13369344)
adc: 0x466D92DD 0.1     (2015/8/20)     0x00000000 0x00000001 (3670016)
Какие команды дальше ?
belokuriha
Сообщение belokuriha » 10 авг 2020, 15:17
Желающих нет помочь ?
VirtualLink
Сообщение VirtualLink » 10 авг 2020, 18:55
Доступ к прошивке открой общий!
Прошивку запроси у производителя!
belokuriha
Сообщение belokuriha » 14 авг 2020, 09:21
Написал им , толку нет. Подскажите хоть чем затолкать то что есть из прошивок .
VirtualLink
Сообщение VirtualLink » 14 авг 2020, 10:19
Что есть?!
Ссылка выше, так и недоступна!
Все продают, но никто ничего не гарантирует?!
belokuriha
Сообщение belokuriha » 14 авг 2020, 11:24
VirtualLink
Сообщение VirtualLink » 14 авг 2020, 18:51
Дамп?!
belokuriha
Сообщение belokuriha » 15 авг 2020, 07:30
VirtualLink писал(а):
14 авг 2020, 18:51
Дамп?!
не получиться ,Э нет программатора под такую микруху , может как то программно слить можно
VirtualLink
Сообщение VirtualLink » 15 авг 2020, 12:42
belokuriha писал(а):
15 авг 2020, 07:30
Все равно он нужен для того, чтобы понять в какую область записать из загрузчика, при условии, что в нем можно это сделать через интерфейс nand!
