Re: Зависания ahd dvr
Добавлено: 01 апр 2019, 15:51
Порядок, вот что пишет:kROOT писал(а):Сверху по центру скорее всего, CN10 вроде написано.
U-Boot 2010.06 (Jan 14 2017 - 11:22:32)
SPI Nor(cs 0) ID: 0xef 0x40 0x18
Block:64KB Chip:16MB Name:"W25Q128(B/F)V"
SPI Nor total size: 16MB
In: serial
Out: serial
Err: serial
USB: scanning bus for devices... 2 USB Device(s) found
0 Storage Device(s) found
PHY 0x02: OUI = 0x01F0, Model = 0x0F, Rev = 0x01
Net PHY: LAN8710
at higmac_demux() phy_intf:0 [0:mii,1:rmii,2:rgmii];MAC_TXCKOUT_MUX_REG value:0x2 [1,rgmii;2,mii;3,rmii;]
change register for 8710
PHY reg: 0x12, value:0x62
CONFIG MII
ETH0: PHY(phyaddr=2, mii) not link!
higmac init fail!
Press CTRL-C to abort autoboot in 2 seconds16384 KiB hi_fmc at 0:0 is now current device
CFG_BOOT_ADDR:0x0
### /UbootLogo UbootLogoload complete: 21986 bytes loaded to 0x8e800000
jpeg decoding ...
<<addr=0x8e800000, size=0xb85f9, vobuf=0x8f000000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg success.
decode jpeg!
OpenDev vo:0 intf_type:36 out_sync:16
OpenDev vo:1 intf_type:1 out_sync:0
srcAddr 0x82000000, dstAddr 0x82000000
find_squashfs_file: name bin, start_block 0, offset 2552, type 1
find_squashfs_file: name boot, start_block 0, offset 2656, type 1
read inode: name boot, sb 0, of 2656, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 2584, type 2
read inode: name zImage.img, sb 0, of 2584, type 2
### FS load complete: 2366136 bytes loaded to 0x82000000
Image Name: linux
Data Size: 2366072 Bytes = 2.3 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
жду зависание....
