Помогите восстановить dvr ESCAM K616.
orbit
Сообщение orbit » 16 ноя 2018, 11:47
Вроде как мак слетел. Возможно проделки китайцев, тк было включено облако.
Код: Выделить всё
U-Boot 2010.06 (Apr 27 2015 - 16:04:52)
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
Spi(cs1): Block:64KB Chip:16MB Name:"MX25L128XX"
In:    serial
Out:   serial
Err:   serial
mmu_enable
<<imgwidth=1024, imgheight=768, linebytes=2048>>
decode success!!!!
dev 0 set background color!
dev 2 set background color!
dev 0 opened!
dev 2 opened!
graphic layer 0 opened!
graphic layer 2 opened!
(Re)start USB...
USB:   scanning bus for devices... 1 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot:  0
hisilicon # printenv
bootargs=mem=163M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=squashfs mtdparts=hi_sfc:320K(uboot),1600K(kernel),13888K(rfs),320K(config),256K(logo)
bootcmd=sf probe 0;sf read 0x82000000 0x50000 0x190000;bootm 0x82000000
bootdelay=1
baudrate=115200
ethaddr=00:00:23:34:45:66
uboot_postfix=.bin.3520d
kernel_postfix=.img.3520d
rfs_postfix=.squashfs.3520d
cfg_postfix=.jffs2.3520d
logo_postfix=.jpeg.3520d
ipaddr=192.168.1.10
serverip=192.168.1.2
netmask=255.255.254.0
bootfile="uImage"
stdin=serial
stdout=serial
stderr=serial
verify=n
jpeg_addr=809ce358
jpeg_size=0x40000
vobuf=80838100
ver=U-Boot 2010.06 (Apr 27 2015 - 16:04:52)
Environment size: 641/65532 bytes
hisilicon #
In:    serial
Out:   serial
Err:   serial
mmu_enable
decode success!!!!
dev 0 opened!
dev 2 opened!
(Re)start USB...
   Image Name:   Linux-3.0.8
   Data Size:    1588180 Bytes = 1.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (root@sqy-desktop) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #162 Sat Sep 12 01:42:52 CST 2015
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: hi3520d
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 41402
Kernel command line: mem=163M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=squashfs mtdparts=hi_sfc:320K(uboot),1600K(kernel),13888K(rfs),320K(config),256K(logo)
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 163MB = 163MB total
Memory: 160944k/160944k available, 5968k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xca800000 - 0xfe000000   ( 824 MB)
    lowmem  : 0xc0000000 - 0xca300000   ( 163 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0023000   ( 108 kB)
      .text : 0xc0023000 - 0xc03dd000   (3816 kB)
      .data : 0xc03de000 - 0xc03fa0a0   ( 113 kB)
       .bss : 0xc03fa0c4 - 0xc044e840   ( 338 kB)
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 75MHz, resolution 13ns, wraps every 57266ms
Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256)
console [ttyAMA0] enabled
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 42) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
L2cache cache controller enabled
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 314
acTemp 0 0x52
acTemp 1 0xe
acTemp 2 0xec
acTemp 3 0x31
acTemp 4 0x50
acTemp 5 0x7e
acTemp 6 0x63
acTemp 7 0x1c
acTemp 8 0x2c
acTemp 9 0xc3
acTemp 10 0x16
acTemp 11 0x0
acTemp 12 0x0
acTemp 13 0x5
acTemp 14 0x15
acTemp 15 0x20
acTemp 16 0xaf
acTemp 17 0x33
acTemp 18 0xac
acTemp 19 0x20
acTemp 20 0x5f
acTemp 21 0x3e
acTemp 22 0x82
acTemp 23 0xaa
acTemp 24 0xe
acTemp 25 0xfd
acTemp 26 0xa
acTemp 27 0xcd
acTemp 28 0xd7
acTemp 29 0x2f
acTemp 30 0xa1
acTemp 31 0x5c
acTemp 32 0x1
acTemp 33 0x75
acTemp 34 0x0
acTemp 35 0x0
acTemp 36 0x0
acTemp 37 0x0
acTemp 38 0x0
acTemp 39 0x0
acTemp 40 0x0
acTemp 41 0x0
acTemp 42 0x0
acTemp 43 0x0
acTemp 44 0x0
acTemp 45 0x0
acTemp 46 0x0
acTemp 47 0x0
acTemp 48 0xfb
acTemp 49 0xdb
acTemp 50 0xf7
acTemp 51 0xe2
acTemp 52 0x4b
acTemp 53 0x67
acTemp 54 0xab
acTemp 55 0xc7
acTemp 56 0xa6
acTemp 57 0xfe
acTemp 58 0x8e
acTemp 59 0x17
acTemp 60 0x47
acTemp 61 0xd3
acTemp 62 0xea
acTemp 63 0xc
acTemp 64 0x6b
acTemp 65 0x92
acTemp 66 0xf1
acTemp 67 0xf1
acTemp 68 0xac
acTemp 69 0x86
acTemp 70 0x6e
acTemp 71 0xce
acTemp 72 0xda
acTemp 73 0x34
acTemp 74 0xdb
acTemp 75 0x3a
acTemp 76 0x6d
acTemp 77 0x9c
acTemp 78 0x2f
acTemp 79 0x4b
acTemp 80 0x8f
acTemp 81 0xf7
acTemp 82 0x2b
acTemp 83 0xd2
acTemp 84 0x9a
acTemp 85 0x9d
acTemp 86 0xb7
acTemp 87 0xd3
acTempFinal 0 0xa6
acTempFinal 1 0xfe
acTempFinal 2 0x8e
acTempFinal 3 0x17
acTempFinal 4 0x47
acTempFinal 5 0xd3
acTempFinal 6 0xea
acTempFinal 7 0xc
acTempFinal 8 0x6b
acTempFinal 9 0x92
acTempFinal 10 0xf1
acTempFinal 11 0xf1
acTempFinal 12 0xac
acTempFinal 13 0x86
acTempFinal 14 0x6e
acTempFinal 15 0xce
acTempFinal 16 0xda
acTempFinal 17 0x34
acTempFinal 18 0xdb
acTempFinal 19 0x3a
acTempFinal 20 0x6d
acTempFinal 21 0x9c
acTempFinal 22 0x2f
acTempFinal 23 0x4b
acTempFinal 24 0x8f
acTempFinal 25 0xf7
acTempFinal 26 0x2b
acTempFinal 27 0xd2
acTempFinal 28 0x9a
acTempFinal 29 0x9d
acTempFinal 30 0xb7
acTempFinal 31 0xd3
bj:ok
encryption ok
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 52
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 52
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 0x16777216
chip num: 1
5 cmdlinepart partitions found on MTD device hi_sfc
Creating 5 MTD partitions on "hi_sfc":
0x000000000000-0x000000050000 : "uboot"
0x000000050000-0x0000001e0000 : "kernel"
0x0000001e0000-0x000000f70000 : "rfs"
0x000000f70000-0x000000fc0000 : "config"
0x000000fc0000-0x000001000000 : "logo"
Fixed MDIO Bus: probed
ata1: SATA link down (SStatus 0 SControl 300)
himii: probed
ata2: SATA link down (SStatus 0 SControl 300)
PHY himii:03 not found
hieth:hieth_platdev_probe_port:668:
connect to phy_device himii:03 failed!
hieth:hieth_plat_driver_probe:797:
no dev probed!
PPP generic driver version 2.4.2
NET: Registered protocol family 24
hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
usbhid: USB HID core driver
TCP cubic registered
802.1Q VLAN Support v1.8
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing init memory: 108K
            _ _ _ _ _ _ _ _ _ _ _ _
            \  _  _   _  _ _ ___
            / /__/ \ |_/
           / __   /  -  _ ___
  _ _ _ _/ /  /  \_/  \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
Jan  1 00:00:02 udevd (475): /proc/475/oom_adj is deprecated, please use /proc/475/oom_score_adj instead.
udevd[475]: main: error opening /dev/null: No such file or directory
[RCS]: /etc/init.d/S03ants
init hotplug
start hotplug ok
SDK_TYPE type is 8d1
hi3520D_base: module license 'Proprietary' taints kernel.
Hisilicon UMAP device driver interface: v3.00
load sys.ko ...OK!
Load tde.ko ...OK!
load venc.ko ...OK!
load group.ko ...OK!
load chnl.ko ...OK!
load h264e.ko ...OK!
load rc.ko ...OK!
load jpege.ko ...OK!
load viu.ko ...OK!
load vou.ko ....OK!
load vpss.ko ....OK!
load vda.ko ....OK!
load region.ko ....OK!
load vdec.ko ....OK
load vhd firmware.ko OK
load hdmi.ko ....OK!
Load hi_jpegdec.ko success.     (SDK_VERSION:[SDK_VERSION] Build Time:[Apr 15 2015, 20:12:57])
HISI_IRDA-MF @Hi3520Dv100R00
hiir: init ok. ver=Nov 26 2013, 15:14:13.
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
rm: can't remove '/usr/etc/config.tar.gz': No such file or directory
mkdir: can't create directory '/usr/etc/tmp': File exists
mkdir: can't create directory '/usr/etc/var': File exists
mkdir: can't create directory '/usr/etc/var/run': File exists
mkdir: can't create directory '/usr/etc/var/lock': File exists
mkdir: can't create directory '/usr/etc/ppp': File exists
mkdir: can't create directory '/usr/etc/ppp/peers': File exists
rm: can't remove '/usr/etc/tmp/qtembedded-0/fonts/fontdb': No such file or directory
ln: /usr/etc/web/web: Read-only file system
cp: can't stat '/usr/sbin/wcdma-chat-disconnect': No such file or directory
ifconfig: SIOCSIFADDR: No such device
/etc/init.d/S03ants: line 48: /etc/startusb: not found
[RCS]: /etc/init.d/S80network
Auto login as root ...
Jan  1 02:28:39 login[766]: root login on 'ttyS000'
Welcome to HiLinux.
# begin dvr//////////////////////////////////////////////////////////////
argc 2, argv ./ants_dvr
g_iDevType 175
 open /usr/etc/mycfg.xml
 open /tmp/qtembedded-0//fonts//fontdb.tmp
 open /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/fonts/gulim_17_50.qpf2
 open /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/fonts/microsoft_sans_serif_12_75.qpf2
 open /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/fonts/yh3500x2_17_50.qpf2
DBG[embedded/qscreenlinuxfb_qws.cpp connect--350]       QLinuxFbScreen::connect :0
DBG[embedded/qscreenlinuxfb_qws.cpp connect--379]
 open /dev/fb0
DBG[embedded/qscreenlinuxfb_qws.cpp connect--397]       open device /dev/fb0 success
DBG[embedded/qscreenlinuxfb_qws.cpp connect--425]
 open /root/DeviceDisplay.xml
DBG[embedded/qscreenlinuxfb_qws.cpp getScreenInfo--307] file doesn't exists
DBG[embedded/qscreenlinuxfb_qws.cpp connect--469]       vinfo.xres 1024 768
DBG[embedded/qscreenlinuxfb_qws.cpp connect--481]       d_ptr->fd 8 vinfo xres 1024, xres_virtual1024
DBG[embedded/qscreenlinuxfb_qws.cpp connect--513]       screen vinfo
 bits_per_pixel 16
 r g b 5 5 5
 d = 15
 finfo.line_length 2560
DBG[embedded/qscreenlinuxfb_qws.cpp connect--554]       dw is 1024,dh is 768 lstep 2048
DBG[embedded/qscreenlinuxfb_qws.cpp connect--600]
  mmap fb0 : d_ptr->fd 8,  data 1088958464, mapsize 4300800
 open /dev/tty0
newMouseHandler mouseProto auto, mouseDev/dev/mouse0
erro[embedded/qmousedriverfactory_qws.cpp create--111]
erro[embedded/qmousedriverfactory_qws.cpp create--114]
erro[embedded/qmousedriverfactory_qws.cpp create--117]
 open /dev/psaux
 open /dev/input/mice
QWSTtyKeyboardHandler /dev/ttyS2
kbdType RS485
kbdType RS485PelcoD
 open /dev/hi_gpio
 open /dev/ttyS1
termdata.c_iflag 5
termdata.c_oflag 0
termdata.c_cflag b0
termdata.c_lflag 0
termdata.c_ispeed bfca917c
termdata.c_ospeed bfca917c
termdata.c_line 0
termdata.c_cc 0 0
kbdType 3520Dgpio
 open /dev/ttyS2
 open /dev/Hi_IR
Could not initialize virtual console switching
 open /root/res/language_Russian.qm
 open /root/res/LanguageInfo.xml
 open /root/res/default.qss
font=efont
font-size=16
from config -> font=efont
from config -> font-size=16
QLayout: Attempting to add QLayout "" to informationFrame "IMShowMain", which already has a layout
 open ./pinyin/english.xml
 open /root/res/cursor.png
 open /root/res/pre_enlarge.png
 open /root/res/label_Mouse.png
 open /root/res/enlarge.png
 open /root/res/shrink.png
 open /root/res/up_Mouse.png
 open /root/res/down_Mouse.png
 open /root/res/left_Mouse.png
 open /root/res/right_Mouse.png
 open /root/res/up_left_Mouse.png
 open /root/res/up_right_Mouse.png
 open /root/res/down_left_Mouse.png
 open /root/res/down_right_Mouse.png
QImage::pixel: coordinate (10,6) out of range
QImage::pixel: coordinate (10,7) out of range
QImage::pixel: coordinate (10,8) out of range
QImage::pixel: coordinate (10,9) out of range
QImage::pixel: coordinate (10,10) out of range
QImage::pixel: coordinate (10,11) out of range
QImage::pixel: coordinate (10,12) out of range
QImage::pixel: coordinate (10,13) out of range
QImage::pixel: coordinate (10,14) out of range
QLayout: Attempting to add QLayout "" to CQRCode "", which already has a layout
QLayout: Attempting to add QLayout "" to DlgDragChannel "", which already has a layout
 open /root/res/pre_recordState.png
QLayout: Attempting to add QLayout "" to SysRecover "", which already has a layout
 open /root/res/play_left.png
 open /root/res/play_play.png
 open /root/res/play_noVideo.png
 open /root/res/play_stop.png
 open /root/res/play_sound.png
 open /root/res/play_fast.png
 open /root/res/play_slow.png
 open /root/res/play_capture.png
 open /root/res/play_backup.png
 open /root/res/play_frame.png
 open /root/res/play_fullscreen.png
QWidget::setLayout: Attempting to set QLayout "horizontalLayout_2" on DlgScreenInfo "DlgScreenInfo_UI", when the QLayout already has a parent
 open /root/res/ptz_back.png
 open /root/res/ptz_up.png
 open /root/res/ptz_up_Hover.png
 open /root/res/ptz_up_press.png
 open /root/res/ptz_down.png
 open /root/res/ptz_down_Hover.png
 open /root/res/ptz_down_press.png
 open /root/res/ptz_left.png
 open /root/res/ptz_left_Hover.png
 open /root/res/ptz_left_press.png
 open /root/res/ptz_right.png
 open /root/res/ptz_right_Hover.png
 open /root/res/ptz_right_press.png
 open /root/res/ptz_left_top.png
 open /root/res/ptz_left_top_Hover.png
 open /root/res/ptz_left_top_press.png
 open /root/res/ptz_right_top.png
 open /root/res/ptz_right_top_Hover.png
 open /root/res/ptz_right_top_press.png
 open /root/res/ptz_left_down.png
 open /root/res/ptz_left_down_Hover.png
 open /root/res/ptz_left_down_press.png
 open /root/res/ptz_right_down.png
 open /root/res/ptz_right_down_Hover.png
 open /root/res/ptz_right_down_press.png
 open /root/res/ptz_auto.png
 open /root/res/ptz_auto_hover.png
 open /root/res/ptz_auto_press.png
 open /root/res/ptz_minus.png
 open /root/res/ptz_plus.png
QLayout: Attempting to add QLayout "" to DlgAutoIP "", which already has a layout
 open /root/res/pre_AudioOpen.png
 open /root/res/pre_AudioClose.png
 open /root/res/pre_DiskNormal.png
 open /root/res/pre_DiskNormal.png.bmp
 open /root/res/pre_DiskNormal.png.jpeg
 open /root/res/pre_DiskNormal.png.jpg
 open /root/res/pre_DiskNormal.png.pbm
 open /root/res/pre_DiskNormal.png.pgm
 open /root/res/pre_DiskNormal.png.png
 open /root/res/pre_DiskNormal.png.ppm
 open /root/res/pre_DiskNormal.png.xbm
 open /root/res/pre_DiskNormal.png.xpm
 open /root/res/pre_DiskFull.png
 open /root/res/pre_DiskFull.png.bmp
 open /root/res/pre_DiskFull.png.jpeg
 open /root/res/pre_DiskFull.png.jpg
 open /root/res/pre_DiskFull.png.pbm
 open /root/res/pre_DiskFull.png.pgm
 open /root/res/pre_DiskFull.png.png
 open /root/res/pre_DiskFull.png.ppm
 open /root/res/pre_DiskFull.png.xbm
 open /root/res/pre_DiskFull.png.xpm
 open /root/res/pre_DiskNull.png
 open /root/res/pre_DiskNull.png.bmp
 open /root/res/pre_DiskNull.png.jpeg
 open /root/res/pre_DiskNull.png.jpg
 open /root/res/pre_DiskNull.png.pbm
 open /root/res/pre_DiskNull.png.pgm
 open /root/res/pre_DiskNull.png.png
 open /root/res/pre_DiskNull.png.ppm
 open /root/res/pre_DiskNull.png.xbm
 open /root/res/pre_DiskNull.png.xpm
QPixmap::scaled: Pixmap is a null pixmap
 open /root/res/pre_alarm1.png
 open /root/res/pre_alarm2.png
 open /root/res/pre_Disk.png
 open /root/res/pre_Disk.png.bmp
 open /root/res/pre_Disk.png.jpeg
 open /root/res/pre_Disk.png.jpg
 open /root/res/pre_Disk.png.pbm
 open /root/res/pre_Disk.png.pgm
 open /root/res/pre_Disk.png.png
 open /root/res/pre_Disk.png.ppm
 open /root/res/pre_Disk.png.xbm
 open /root/res/pre_Disk.png.xpm
[Mid] start init
system:/root/nvr_daemon &
system:killall -9 ntpd;ntpd -l
killall: ntpd: no process killed
[Mid] load custom cfg
[MID]load RTSP
load host proto /root/host_libs/libhost_platform_umeye.so
[WEBSDK][../../src/AntsWebSDK.c:ants_HostMgr_Lib_GetFxns:651:time:14:25:28]Start================================[WebServer] SUCCESS
load host proto /root/host_libs/libwebserver.so
MidLibInfo.nNvrCurrExMode = 0
[NVR/DVR] [dvr/enc] = 0 nvr = 8 dec = 8
pAntsDVRInfo->byChanNum = 0 byDecodeChans = 8
!!pAntsDVRInfo->byChanNum = 0 byDecodeChans = 8 LocalChannelnum= 8
[enable] all
[disable] RTSP
load ipc proto /root/ipc_libs/libi12.so
load ipc proto /root/ipc_libs/libi8.so
load ipc proto /root/ipc_libs/libi8h.so
load ipc proto /root/ipc_libs/libi8s.so
load ipc proto /root/ipc_libs/libi9.so
load ipc proto /root/ipc_libs/libonvif.so
dwNVRChnum = 8
get mac ioctl error!
byDecodeChans = 1 dwRealDecodeChnNum = 8 bDeviceInfo_AuxRecord = 1 dwDecodChnNum = 8 ReplayChnNum=1
******MidLibInfo.dwTotalChnNum  = 8,[1,175,2]  8
[SaveHDCfg.7320]
[ANTS_DVR_LogicLayer_Init.5962.zero]Support = 0
system:rm -fr /tmp/sata
[SaveHDCfg.7320]
sd_serialport.cpp:213 No such file or directory
serial232 not open[MID] net server load...
[GPIO] GPIOGET_WATCHDOG Enable chardata = 1!!!
chmod: /etc/ppp/resolv.conf: No such file or directory
[I8-Server] [src/AntsServerSDK.cpp:9627:GSVRLoadDDNSLib] Load ddns proto /root/ddns_libs/libddns_3322.so
[I8-Server] [src/AntsServerSDK.cpp:9627:GSVRLoadDDNSLib] Load ddns proto /root/ddns_libs/libddns_dnsdynamic.so
[I8-Server] [src/AntsServerSDK.cpp:9627:GSVRLoadDDNSLib] Load ddns proto /root/ddns_libs/libddns_dyndns.so
[I8-Server] [src/AntsServerSDK.cpp:9627:GSVRLoadDDNSLib] Load ddns proto /root/ddns_libs/libddns_noip.so
[I8-Server] [src/AntsServerSDK.cpp:9627:GSVRLoadDDNSLib] Load ddns proto /root/ddns_libs/libddns_peanuthull.so
[src/AntsServerSDK.cpp:00009799:GSVRInitDVR] GetDeviceType Result[33649928] DeviceType[NVR-175-8CH]
[src/AntsServerSDK.cpp:4662:set_mac_addr] offset->8 sn->0175fbdbc7ab674be2f7
[src/AntsServerSDK.cpp:4671:set_mac_addr] MacAddrUnit ->ab MacAddr->0xab
[src/AntsServerSDK.cpp:4671:set_mac_addr] MacAddrUnit ->67 MacAddr->0x67
[src/AntsServerSDK.cpp:4671:set_mac_addr] MacAddrUnit ->4b MacAddr->0x4b
[src/AntsServerSDK.cpp:4671:set_mac_addr] MacAddrUnit ->e2 MacAddr->0xe2
[src/AntsServerSDK.cpp:4671:set_mac_addr] MacAddrUnit ->f7 MacAddr->0xf7
[src/AntsServerSDK.cpp:4680:set_mac_addr] mac[0] addr->0x00:0xab:0x67:0x4b:0xe2:0xf7
[src/AntsServerSDK.cpp:4758:set_mac_addr] offset->8 sn->0175fbdbc7ab674be2f7
[src/AntsServerSDK.cpp:4767:set_mac_addr] MacAddrUnit ->ab MacAddr->0xab
[src/AntsServerSDK.cpp:4767:set_mac_addr] MacAddrUnit ->67 MacAddr->0x67
[src/AntsServerSDK.cpp:4767:set_mac_addr] MacAddrUnit ->4b MacAddr->0x4b
[src/AntsServerSDK.cpp:4767:set_mac_addr] MacAddrUnit ->e2 MacAddr->0xe2
[src/AntsServerSDK.cpp:4767:set_mac_addr] MacAddrUnit ->f7 MacAddr->0xf7
[src/AntsServerSDK.cpp:4776:set_mac_addr] mac[1] addr->0x02:0xab:0x67:0x4b:0xe2:0xf7
[I8-Server] [src/AntsServerSDK.cpp:4795:set_mac_addr] ifconfig eth0 down
ifconfig: SIOCGIFFLAGS: No such device
[I8-Server] [src/AntsServerSDK.cpp:4865:set_mac_addr] ifconfig eth0 hw ether 0:ab:67:4b:e2:f7
ifconfig: SIOCSIFHWADDR: No such device
[I8-Server] [src/AntsServerSDK.cpp:4943:set_mac_addr] ifconfig eth0 0.0.0.0
[I8-Server] [src/AntsServerSDK.cpp:5055:set_mac_addr] route add default gw 192.168.1.1 eth0
route: SIOCADDRT: No such device
[set_loopback_addr:5152] ifconfig lo 127.0.0.1 netmask 255.0.0.0
[set_loopback_addr:5162] ifconfig lo 127.0.0.1 netmask 255.0.0.0 result[0]
[I8-Server] [src/AntsParameter.cpp:195:InitializeDDNSAbility] ddns[1] [DynDns]->[members.dyndns.org:80]
[I8-Server] [src/AntsParameter.cpp:195:InitializeDDNSAbility] ddns[2] [PeanutHull]->[ddns.oray.org:80]
[I8-Server] [src/AntsParameter.cpp:195:InitializeDDNSAbility] ddns[3] [No-IP]->[dynupdate.no-ip.com:80]
[I8-Server] [src/AntsParameter.cpp:195:InitializeDDNSAbility] ddns[4] [3322]->[members.3322.org:80]
[I8-Server] [src/AntsParameter.cpp:195:InitializeDDNSAbility] ddns[7] [DnsDynamic]->[www.dnsdynamic.org:80]
[I8-Server] [943:CheckExternalIP] call cur wanip[]
[I8-Server] [959:CheckExternalIP] call failed(wanip[])
ERROR: PPP link is not active on ppp0
route: SIOCDELRT: No such device
[MID] ARP server load...
del /usr/etc/udhcpc_resolv_eth0
del /usr/etc/udhcpc_ip_eth0
del /usr/etc/udhcpc_route_eth0
udhcpc udhcpc  -i eth0 -t 20 -b -R -n -H 0175fbdbc7ab674be2f7_0_0 -p /var/dhcpc_eth0_0.pid > /var/dhcpc_result4eth0_0.log
[MID] ARP server load...ok
[MID] nvr ipcs load...
[MID] nvr ipcs load...ok
[MID] nvr host load...
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:84:time:14:25:27]g_struWebSiteSDKInfo.g_ChanNum===============================[8]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:85:time:14:25:27]g_struWebSiteSDKInfo.g_byIPChanNum===========================[8]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:86:time:14:25:27]g_struWebSiteSDKInfo.g_DVRType===============================[2]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:87:time:14:25:27]g_struWebSiteSDKInfo.g_AlarmOutPortNum=======================[0]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:88:time:14:25:27]g_struWebSiteSDKInfo.g_AlarmInPortNum========================[0]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:89:time:14:25:27]g_struWebSiteSDKInfo.g_byStartChan===========================[0]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:90:time:14:25:27]g_struWebSiteSDKInfo.sSerialNumberm==========================[0175fbdbc7ab674be2f7]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:99:time:14:25:27]g_struWebSiteSDKInfo.wDVRPort================================[5050]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:100:time:14:25:27]g_struWebSiteSDKInfo.wHttpPort===============================[80]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:101:time:14:25:27]g_struWebSiteSDKInfo.wHttpsPort==============================[4433]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:102:time:14:25:27]g_struWebSiteSDKInfo.wRTMPPort===============================[1935]
udhcpc: option -h NAME is deprecated, use -x hostname:NAME
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:109:time:14:25:27]g_struWebSiteSDKInfo.wRTSPPort===============================[554]
[WEBSDK][../../src/AntsWebSDK.c:ANTS_WEB_Start:434:time:14:25:28]Server Start
udhcpc: ioctl 0x8933 failed: No such device
[WEBS][../../src/AntsWebSDK.c:0132:initWebs]WebPath[/root/web/www]
[WEBS][../../src/webs.c:0399:websOpenListen]Create websListenSocket[0x588de950]
[WEBS][../../src/webs.c:0455:websOpenListen]Create AcceptThread[0x58bdc4c0] DeleteThread[0x46fda4c0]
[WEBSDK][../../src/AntsWebSDK.c:initWebs:378:time:14:25:28]Call End
[WEBSDK][../../src/AntsWebSDK.c:AntsHostMgrLibStart:618:time:14:25:28]AntsHostMgrLibStart================================[1] SUCCESS
[MID] nvr host load.ok..
dwRuleNum1 = 0!!!!!!!!!!
system:echo 1 >/proc/sys/net/ipv4/ip_forward
system:iptables -t nat -F
sh: iptables: not found
dwRuleNum2 = 0!!!!!!!!!!
[MID] nvr rtsp/onvif/rtmp server load...
[MID] nvr rtsp/onvif/rtmp server load...ok
Ants_RTMPServer_Start !!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1935
[INFO.Ants_RTMPServer_Start.66]Ants_RTMPServer_Start  start!
[INFO.Ants_RTMPServer_Start.87]create i 1 start!
[RTMP] [server/server.cpp:00003087:Start] Start ok!
[RTMP] [server/server.cpp:00003131:StartListenThread] Create Listen Thread OK
[INFO.Ants_RTMPServer_Start.91]create i 1 end!
[INFO.Ants_RTMPServer_Start.102]hRtmpHandle = 1!
[INFO.Ants_RTMPServer_Start.106]Ants_RTMPServer_Start  end!
[INFO.Ants_RTMPServer_SetStreamCallBackV2.291]Ants_RTMPServer_SetStreamCallBack  start!
[INFO.Ants_RTMPServer_SetStreamCallBackV2.315]Ants_RTMPServer_SetStreamCallBack  end!
[INFO.Ants_RTMPServer_SetStreamCallBack.145]Ants_RTMPServer_SetStreamCallBack  start!
[INFO.Ants_RTMPServer_SetStreamCallBack.165]Ants_RTMPServer_SetStreamCallBack  end!
Ants_RTMPServer_Start !!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1935  ok
Ants_RTSPServer_Start !!!!!!!!!!!!!!!!!!!!!!!!!!!!! 554
[RTMP][static void* CRtmpServer::ListenThread(void*):3378]pid=965 enter
[INFO.ListenProc.3420]ListenProc  start!
 open /usr/etc/myExceptionState.xml
erro[antsMainDlg.cpp timerEvent--3621]  STOP_DVR_ILLEGAL poweroff?
erro[preview/preview.cpp SysAudio--4963]        no right stopAudio
GUI -->   [0/0] dwAbilityType= 2305 bsupp = 1
GUI -->   [1/1] dwAbilityType= 2306 bsupp = 1
GUI -->   [2/2] dwAbilityType= 2307 bsupp = 1
GUI -->   [3/3] dwAbilityType= 2308 bsupp = 1
GUI -->   [4/4] dwAbilityType= 2309 bsupp = 1
GUI -->   [5/5] dwAbilityType= 2310 bsupp = 1
GUI -->   [6/6] dwAbilityType= 2311 bsupp = 1
GUI -->   [7/7] dwAbilityType= 2312 bsupp = 1
 QLinuxFbScreen::disconnect
 munmap 4300800
DBG[embedded/qscreenlinuxfb_qws.cpp connect--350]       QLinuxFbScreen::connect /dev/fb0
 open /dev/fb0
 bits_per_pixel 16
 r g b 5 5 5
 d = 15
vm.drop_caches = 3
 open /root/res/prv_voice.png
 open /root/res/pre_capture.png
 open /root/res/pre_start.png
 open /root/res/pre_screen.png
 open /root/res/pre_ptz.png
 open /root/res/pre_config.png
 open /root/res/pre_playback.png
 open /root/res/pre_backup.png
 open /root/res/pre_alarm.png
 open /root/res/pre_file.png
 open /root/res/pre_record.png
[IPCMgrThreadAll.8087] new i = 0
[IPCMgrThreadAll.8087] new i = 1
[IPCMgrThreadAll.8087] new i = 2
[IPCMgrThreadAll.8087] new i = 3
[IPCMgrThreadAll.8087] new i = 4
[IPCMgrThreadAll.8087] new i = 5
[IPCMgrThreadAll.8087] new i = 6
[IPCMgrThreadAll.8087] new i = 7
[Register:1088] killall ntsclientcon
killall: ntsclientcon: no process killed
[Register:1099] chmod +x /root/start_umeye_p2p.sh
chmod: /root/start_umeye_p2p.sh: Read-only file system
[Register:1110] /root/start_umeye_p2p.sh
/tmp
 open /root/res/pre_link_addipc.png
02:29:01    [--?]  v2.3.2.1
02:29:02    [Prompt]  Start device protocol network service success.
02:29:02    [Prompt]  Callback queue size: 0, ver: v2.3.2.1.
02:29:02    [Prompt]  Cache size: 0KB, UpCache size: 0KB, TcpConnNum: 0.
NPC_SR_StartService ....
02:29:02    [Prompt]  Start service.......
NPC_F_LINUX_GNA_QueryLocalNetAddr NPC_F_LINUX_GETGW_QueryGatewayAddr fail.
02:29:02    [Prompt]  CfgEthName: eth0.
02:29:02    [Log]  Not get the MAC address.
killall udhcpc udhcpc
killall: udhcpc: no process killed
[set_single_eth0_0:464] ifconfig eth0 192.168.1.188 netmask 255.255.255.0
[set_single_eth0_0:489] route add default gw 192.168.1.1 eth0
[I8S] build Mar  3 2016 16:28:47
02:29:07    [Prompt]  Cache size: 0KB, UpCache size: 0KB, TcpConnNum: 0.
02:29:12    [Prompt]  Cache size: 0KB, UpCache size: 0KB, TcpConnNum: 0.
02:29:12    [Prompt]  CfgEthName: eth0.
02:29:12    [Log]  Not get the MAC address.
02:29:17    [Prompt]  Cache size: 0KB, UpCache size: 0KB, TcpConnNum: 0.
delete 1 nDelIdx = 0
delete 2  nStart = 0
delete 2  nStart = 0
delete 2  nStart = 2
02:29:22    [Prompt]  Cache size: 0KB, UpCache size: 0KB, TcpConnNum: 0.
02:29:22    [Prompt]  CfgEthName: eth0.
02:29:22    [Log]  Not get the MAC address.
02:29:27    [Prompt]  Cache size: 0KB, UpCache size: 0KB, TcpConnNum: 0.
lspciget mac ioctl error!
0
orbit
Re: Помогите восстановить dvr ESCAM K616.
Сообщение orbit » 17 ноя 2018, 00:52
нет идей?
Сообщение dede » 17 ноя 2018, 08:44
Идеи есть. Читаем лог и видим что мак тут не причем. Сдох PHY или левая прошивка.
orbit
Сообщение orbit » 17 ноя 2018, 18:19
подскажите маркировку м/c
orbit
Сообщение orbit » 18 ноя 2018, 09:44
1,2,3,4 -
7,8 +
5,6 шина i2c ?
Сообщение dede » 18 ноя 2018, 10:47
Следующий ваш пост будет - дайте дамп еепром. Откройте глаза, прочитайте ваш собственный лог, найдите там место где eth0 не появляется в системе, найдите место, где идет установка мак адреса, прочитанного из еепром.
orbit
Сообщение orbit » 18 ноя 2018, 11:16
маркировку еепром подскажите.
думаете она ни при чём?
Сообщение AlienP666 » 19 ноя 2018, 06:26
orbit писал(а):маркировку еепром подскажите.
Посмотрите модель вашего регистратора под белой наклейкой. После напишите, что у вас за модель и поищите в теме Китайский mini NVR, там есть способы восстановления.
orbit
Сообщение orbit » 19 ноя 2018, 18:30
AlienP666 писал(а): Посмотрите модель вашего регистратора под белой наклейкой. После напишите, что у вас за модель и поищите в теме Китайский mini NVR, там есть способы восстановления.
0865
Fluffykrsk
Сообщение Fluffykrsk » 19 ноя 2018, 18:41
FalconEye FE-NR-2108 клон :smile:
Главное, на плате нихрена не видно, источник света настроен на стол исцарапанный. Но фалькончик я узнаю и в темноте :lol:
orbit
Сообщение orbit » 19 ноя 2018, 19:19
Fluffykrsk писал(а):FalconEye FE-NR-2108 клон :smile:
меню похоже, только этот
Fluffykrsk
Сообщение Fluffykrsk » 19 ноя 2018, 19:28
dvr ESCAM K616 это чего, 16-ти каналка))). Эти мини NVR, как китайцы, все на одно лицо. Ну фотка тёмная, проц не видно было, может и не такой. Фиг его знает.
Но похож был....
https://yadi.sk/i/XV3bai6F25EkDw" onclick="window.open(this.href);return false;
