Из симптомов - камера постоянно перезапускалась.
Подключился к UART разъему и вот что увидел:
Код: Выделить всё
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.10.73 (sb@package-Server) (gcc version 4.9.1 20140625 (prerelease) (crosstool-NG - Ambarella Linaro Multilib GCC [CortexA9 & ARMv6k] 2014.06) ) #1 PREEMPT Tue Jan 23 11:37:51 KST 2018
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Ambarella S2L (Flattened Device Tree), model: Ambarella S2L Hawthorn Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] Ambarella: AHB = 0xe0000000[0xe0000000],0x01000000 0
[ 0.000000] Ambarella: APB = 0xe8000000[0xe8000000],0x01000000 0
[ 0.000000] Ambarella: PPM = 0x00000000[0xdfe00000],0x00200000 9
[ 0.000000] Ambarella: AXI = 0xf0000000[0xf0000000],0x00030000 0
[ 0.000000] Ambarella: DRAMC = 0xdffe0000[0xef000000],0x00020000 0
[ 0.000000] Ambarella: DBGBUS = 0xec000000[0xec000000],0x00200000 0
[ 0.000000] Ambarella: DBGFMEM = 0xee000000[0xee000000],0x01000000 0
[ 0.000000] Ambarella: IAVMEM = 0x10000000[ ],0x10000000
[ 0.000000] Ambarella: FBMEM = 0x10000000[ ],0x00000000
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64516
[ 0.000000] Kernel command line: console=ttyS0 ubi.mtd=lnx root=ubi0:rootfs rw rootfstype=ubifs init=/linuxrc
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 254MB = 254MB total
[ 0.000000] Memory: 251384k/251384k available, 8712k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0x90000000 - 0xff000000 (1776 MB)
[ 0.000000] lowmem : 0x80000000 - 0x8fe00000 ( 254 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x805a2bd0 (5739 kB)
[ 0.000000] .init : 0x805a3000 - 0x805c7a1c ( 147 kB)
[ 0.000000] .data : 0x805c8000 - 0x80613938 ( 303 kB)
[ 0.000000] .bss : 0x80613938 - 0x80636d78 ( 142 kB)
[ 0.000000] NR_IRQS:240
[ 0.000000] sched_clock: 32 bits at 108MHz, resolution 9ns, wraps every 39768ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [ttyS0] enabled
[ 0.239393] Calibrating delay loop... 1007.61 BogoMIPS (lpj=5038080)
[ 0.332792] pid_max: default: 32768 minimum: 301
[ 0.337451] Mount-cache hash table entries: 512
[ 0.343843] CPU: Testing write buffer coherency: ok
[ 0.348894] Setting up static identity map for 0x8043cfb0 - 0x8043d018
[ 0.356993] devtmpfs: initialized
[ 0.361253] pinctrl core: initialized pinctrl subsystem
[ 0.366654] NET: Registered protocol family 16
[ 0.371595] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.378766] Ambarella power management: Wed Aug 10 2016
[ 0.384095] L310 cache controller enabled
[ 0.388084] l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32020000, Cache size: 131072 B
[ 0.397141] ambarella-pinctrl e8009000.pinctrl: Ambarella pinctrl driver registered
[ 0.405015] ambarella-gpio gpio.0: Ambarella GPIO driver registered
[ 0.413725] bio: create slab <bio-0> at 0
[ 0.418392] ambarella-dma e0005000.dma: Ambarella DMA Engine
[ 0.425021] ambarella-i2c e8003000.i2c: Ambarella I2C adapter[0] probed!
[ 0.431897] ambarella-i2c e8001000.i2c: Ambarella I2C adapter[1] probed!
[ 0.439199] Switching to clocksource ambarella-cs-timer
[ 0.444561] FS-Cache: Loaded
[ 0.451394] NET: Registered protocol family 2
[ 0.456296] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.463344] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.469758] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.476140] TCP: reno registered
[ 0.479349] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.485176] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.491520] NET: Registered protocol family 1
[ 0.496050] RPC: Registered named UNIX socket transport module.
[ 0.501944] RPC: Registered udp transport module.
[ 0.506657] RPC: Registered tcp transport module.
[ 0.511335] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.518009] ambarella-adc e801d000.adc: Ambarella ADC driver init
[ 0.524957] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.530922] NFS: Registering the id_resolver key type
[ 0.536021] Key type id_resolver registered
[ 0.540181] Key type id_legacy registered
[ 0.544176] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.550749] FS-Cache: Netfs 'cifs' registered for caching
[ 0.556193] Key type cifs.spnego registered
[ 0.560371] Key type cifs.idmap registered
[ 0.564449] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.570604] msgmni has been set to 490
[ 0.575147] NET: Registered protocol family 38
[ 0.579631] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.587080] io scheduler noop registered
[ 0.590980] io scheduler deadline registered
[ 0.595258] io scheduler cfq registered (default)
[ 0.600147] e8005000.uart: ttyS0 at MMIO 0xe8005000 (irq = 9) is a ambuart
[ 0.607580] brd: module loaded
[ 0.612236] loop: module loaded
[ 0.617742] ambarella-nand e0001000.nand: in ecc-[1]bit mode
[ 0.623379] ambarella_nand: Use On Flash BBT
[ 0.627715] NAND device: Manufacturer ID: 0xc8, Chip ID: 0xda (GigdDevice NAND 256MiB 3,3V 8-bit), 256MiB, page size: 2048, OOB size: 64
[ 0.640129] Bad block table found at page 131008, version 0x01
[ 0.646080] Bad block table found at page 130944, version 0x01
[ 0.652037] nand_read_bbt: bad block at 0x00000f2a0000
[ 0.657159] nand_read_bbt: bad block at 0x00000f560000
[ 0.662269] nand_read_bbt: bad block at 0x00000fb40000
[ 0.667430] 11 ofpart partitions found on MTD device amba_nand
[ 0.673236] Creating 11 MTD partitions on "amba_nand":
[ 0.678362] 0x000000000000-0x000000020000 : "bst"
[ 0.683505] 0x000000020000-0x000000160000 : "bld"
[ 0.688637] 0x000000160000-0x0000002a0000 : "ptb"
[ 0.693736] 0x0000002a0000-0x0000006a0000 : "spl"
[ 0.698857] 0x0000006a0000-0x000000ea0000 : "pba"
[ 0.703952] 0x000000ea0000-0x000001aa0000 : "pri"
[ 0.709097] 0x000001aa0000-0x0000026a0000 : "sec"
[ 0.714190] 0x0000026a0000-0x0000028a0000 : "bak"
[ 0.719334] 0x0000028a0000-0x0000066a0000 : "rmd"
[ 0.724496] 0x0000066a0000-0x00000a6a0000 : "lnx"
[ 0.729665] 0x00000a6a0000-0x00000e6a0000 : "swp"
[ 0.794487] libphy: Ambarella MII Bus: probed
[ 0.798830] mdio_bus e000e000.etherne: /ahb@e0000000/ethernet@e000e000/phy@3 has invalid PHY address
[ 0.807945] mdio_bus e000e000.etherne: scan phy phy at address 0
[ 0.814240] mdio_bus e000e000.etherne: registered phy phy at address 0
[ 0.820796] ambarella-eth e000e000.ethernet: Ethernet PHY[0]: 0x00221560!
[ 0.827842] ambarella-eth e000e000.ethernet: MAC Address[00:0d:f1:20:fa:eb].
[ 0.835058] mousedev: PS/2 mouse device common for all mice
[ 0.840826] ambarella-rtc e8015000.rtc: rtc core: registered rtc-ambarella as rtc0
[ 0.848695] ambarella-wdt e800c000.wdt: Ambarella Watchdog Timer Probed.
[ 0.855442] ambarella cpufreq driver init
[ 0.859552] IPVS: Registered protocols ()
[ 0.863552] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 0.870951] IPVS: Creating netns size=736 id=0
[ 0.875416] IPVS: ipvs loaded.
[ 0.878552] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.883925] arp_tables: (C) 2002 David S. Miller
[ 0.888575] TCP: cubic registered
[ 0.891868] Initializing XFRM netlink socket
[ 0.896168] NET: Registered protocol family 10
[ 0.901022] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 0.906494] sit: IPv6 over IPv4 tunneling driver
[ 0.911435] NET: Registered protocol family 17
[ 0.915964] Key type dns_resolver registered
[ 0.920253] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.927897] ThumbEE CPU extension supported.
[ 0.932916] UBI: attaching mtd9 to ubi0
[ 1.061177] UBI: scanning is finished
[ 1.068747] UBI: attached mtd9 (name "lnx", size 64 MiB) to ubi0
[ 1.074767] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 1.081526] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 1.088209] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 1.095060] UBI: good PEBs: 512, bad PEBs: 0, corrupted PEBs: 0
[ 1.100951] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 1.108065] UBI: max/mean erase counter: 792/69, WL threshold: 4096, image sequence number: 1393631869
[ 1.117341] UBI: available PEBs: 0, total reserved PEBs: 512, PEBs reserved for bad PEB handling: 40
[ 1.126450] UBI: background thread "ubi_bgt0d" started, PID 42
[ 1.132287] ambarella-rtc e8015000.rtc: setting system clock to 2005-01-02 00:25:59 UTC (1104625559)
[ 1.142192] UBIFS: background thread "ubifs_bgt0_0" started, PID 43
[ 1.163734] UBIFS: recovery needed
[ 1.249624] UBIFS: recovery completed
[ 1.253385] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 1.259424] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 1.268539] UBIFS: FS size: 58028032 bytes (55 MiB, 457 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 1.278164] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 1.283193] UBIFS: media format: w4/r0 (latest is w4/r0), UUID B5D2FEBF-C4A8-4F1B-8FF4-5A0676420900, small LPT model
[ 1.294283] VFS: Mounted root (ubifs filesystem) on device 0:12.
[ 1.300740] devtmpfs: mounted
[ 1.303794] Freeing unused kernel memory: 144K (805a3000 - 805c7000)
Disable kswapd write
[ 1.772669] hw_timer: module license 'Proprietary' taints kernel.
[ 1.778773] Disabling lock debugging due to kernel taint
[ 1.793650] i2c /dev entries driver
net.core.wmem_default = 327680
[ 1.894051] wm8510_amb.c :: __init wm8510_modinit(void)
[ 1.927687] ambarella-sd e0002000.sdmmc0: Slot0 use bounce buffer[0x8eea0000<->0x0f0a0000]
[ 1.936016] ambarella-sd e0002000.sdmmc0: Slot0 req_size=0x00020000, segs=32, seg_size=0x00020000
[ 1.944881] ambarella-sd e0002000.sdmmc0: Slot0 use ADMA
[ 2.334531] ambarella-sd e0002000.sdmmc0: 1 slots @ 200000000Hz
[ 2.380757] usbcore: registered new interface driver usbfs
[ 2.386464] usbcore: registered new interface driver hub
[ 2.391934] usbcore: registered new device driver usb
[ 2.401317] mmc0: new high speed SDXC card at address 59b4
[ 2.408502] mmcblk0: mmc0:59b4 USDU1 59.4 GiB
[ 2.413096] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.420710] mmcblk0: p1
[ 2.429735] ehci-ambarella: AMBARELLA-EHCI Host Controller driver
[ 2.436028] ambarella-ehci e0018000.ehci: EHCI Host Controller
[ 2.441862] ambarella-ehci e0018000.ehci: new USB bus registered, assigned bus number 1
[ 2.449997] ambarella-ehci e0018000.ehci: irq 39, io mem 0xe0018000
[ 2.474481] ambarella-ehci e0018000.ehci: USB 2.0 started, EHCI 1.00
[ 2.480858] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.487635] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.494836] usb usb1: Product: EHCI Host Controller
[ 2.499688] usb usb1: Manufacturer: Linux 3.10.73 ehci_hcd
[ 2.505153] usb usb1: SerialNumber: AmbUSB
[ 2.509781] hub 1-0:1.0: USB hub found
[ 2.513525] hub 1-0:1.0: 2 ports detected
[ 2.520827] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.527194] ambarella-ohci e0019000.ohci: Ambarella OHCI
[ 2.532499] ambarella-ohci e0019000.ohci: new USB bus registered, assigned bus number 2
[ 2.540528] ambarella-ohci e0019000.ohci: irq 44, io mem 0xe0019000
[ 2.608537] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.615356] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.622551] usb usb2: Product: Ambarella OHCI
[ 2.626897] usb usb2: Manufacturer: Linux 3.10.73 ohci_hcd
[ 2.632356] usb usb2: SerialNumber: AmbUSB
[ 2.637000] hub 2-0:1.0: USB hub found
[ 2.640743] hub 2-0:1.0: 2 ports detected
[ 2.653604] ambarella-udc e0006000.udc: ambarella_udc: version 12 August 2015
Populating s2l_cpro using udev: [ 2.733194] systemd-udevd[271]: starting version 215
Done
Initializing random number generator... done.
Starting system message bus: done
Starting network...
ip: RTNETLINK answers: File exists
[ 3.225333] net eth0: adv: sym 0, asym: 0
[ 3.229480] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 3.272804] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Starting PulseAudio Daemon: OK
[ 3.596104] jffs2: Empty flash at 0x001cb900 ends at 0x001cc000
[ 3.662152] EXT4-fs (mtdblock3): mounted filesystem with ordered data mode. Opts: (null)
[CamSocketServer:143]>>SocketServer: bind() failed - errno(2)
[CamSocketServer:151]>>SocketServer: listen() failed - errno(9)
[main:89]>>failure epoll_ctl(Invalid argument)
| I P - C A M E R A |
| ( Version 04.01.02 2018.03.14 ) |
>> Watchdog : main start
create hal for A5S
CamSetupInfo::setDeviceInfo
/etc/init.d/S99digitalwatchdog-mediaserver: source: line 40: can't open '/opt/digitalwatchdog/build_info.txt'
[Initialize][61][Model : N8Fx-OLAH4 ] capability
[setModelInfo][418] Unknwon Capability [description=CVD8_4M, Mini_Dome]
+ RECOVERY_MODE : OFF
mem_size : 245 MB
board_chipset : amba_s2l66
image_sensor : ov4689
camera_moduel : s2l_internal_isp
ptz_moduel : normal
camera_type : normal
oem : DW
image_direction : 1
max_resolution_width : 2560
max_resolution_height : 1440
max_resolution_fps : 30
channle : 3 4.111958] Vout notice: vout0:0 probed!
m
4.116214] Vout notice: vout1:1 probed!
mvideo_in : 1
video_out : 0
osd : 0
audio_in : 0
audio_in_gain : 0
audio_out : 0
audio_out_gain : 0
sensor_count : 0
relay_count : 0
have_pantilt : 0
have_zoom : 0
have_zoom_button : 0
have_digitalzoom : 0
have_focus : 0
[ 4.163181] VIN: vin0: probed!
have_iris [ 4.167416] VIN: vin1: probed!
:0
have_cds : 1
have_sdcard : 1
focus_mode : 0
cds_adc : 1
ir_gpio : 107
4.187453] Vout notice: CVBS:0@1 probed!
49mday_gpio : 32
night_gpio : 31
tele_gpio : 0
wide_gpio : 0
/home/sb/project_S2L/s2lmcaas/ipnc/source/hal/ambarella/s2lm55/HALA5sModel.cpp Initialize 100
Welcome to Ambarella
CAAS login: [ 4.224629] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 4.254518] SYSCLK:SO[23993520]
[ 4.276486] jffs2: notice: (346) check_node_data: wrong data CRC in data node at 0x001cb57c: read 0xec3e5757, calculated 0x3a906649.
[ 4.294486] VIN: OV4689 init(4-lane mipi)
Default init without lens driver
[ 4.322620] amba_debug_init 248:248.
[ 4.369553] jffs2: notice: (346) check_node_data: wrong data CRC in data node at 0x001dae90: read 0x88c8ea48, calculated 0x4b0b0488.
Use default settings
map_size = 0x400000, nr_item = 3
addr_offset = 0x00000000, filename = orccode.bin
addr_offset = 0x00300000, filename = orcme.bin
addr_offset = 0x003a0000, filename = default_binary.bin
mmap returns 0x769f2000
loading /lib/firmware/orccode.bin...addr = 0x769f2000, size = 0x17129c
loading /lib/firmware/orcme.bin...addr = 0x76cf2000, size = 0x51634
loading /lib/firmware/default_binary.bin...addr = 0x76d92000, size = 0x40000
ucode (S2L) version = 2016/10/20 263143.263973
load dsplog driver
getStructurePos tMediaConfiguration=100896 tMediaSource=272 tProfiles=3525 tProfileConfiguration=95689 tChannelConfiguration=1410
open /mnt/nand/ipnc_sys.cfg(FD11)
close /mnt/nand/ipnc_sys.cfg(FD11)
updateDeviceInfo()0 100 0 100
[saveDeviceInfo][120] DeviceInformation is saved!!!!
ir_led_check = 0
>> runCode() CAMERA_DN_MODE:3
[runCode][2120] value = 3
[runCode][2130] value = 0
open /root/cali_awb_ov4689.txt(FD13)
close /root/cali_awb_ov4689.txt(FD13)
open /mnt/nand/ipnc_sys.cfg(FD13)
close /mnt/nand/ipnc_sys.cfg(FD13)
>> /usr/local/bin/test_encode --idle
IAVIOC_S_IDLE don[ 9.097369] iav_check_vin(602): VIN is not enabled! Enable VIN first!
e
IAV_IOC_ENABLE_PREVIEW: Resource temporarily unavailable
>> /usr/local/bin/test_encode -i poweroff
Stop encoding for stream 0xf
IAVIO[ 9.116671] iav_check_vin(602): VIN is not enabled! Enable VIN first!
C_S_IDLE done
Find Vin Source ov4689 it supports:
2688x1512P 60 RGB 10bits 16:9 AUTO rev[0]
2560x1440P 60 RGB 10bits 16:9 AUTO rev[0]
2560x1440P(HDR [ 9.136791] Vout info: CVBS-0 switch to mode 131072!
2x) 30 RGB 10bit[ 9.143142] SYSCLK:VOUT[27000000]
s 16:9 AUTO rev[0]
2560x1440P(HDR 3x) 25 RGB 10bits 16:9 AUTO rev[0]
2688x1520P 60 RGB 10bits 16:9 AUTO rev[0]
2688x1520P(HDR 2x) 30 RGB 10bits 16:9 AUTO rev[0]
1920x1080P(HDR 2x) 30 RGB 10bits 16:9 AUTO rev[0]
1920x1080P(HDR 3x) 30 RGB 10bits 16:9 AUTO rev[0]
VIN is power off.
>> /usr/local/bin/test_encode -i 2560x1440 -[ 9.184465] VIN: 4 lane 4M
f 30 -V 480i --c[ 9.188365] VIN: Linear mode
vbs -J --btype prev --hdr-mode 0 --enc-mode 4 --hdr-expo 1 --mixer 1 -X --bmaxsize 2560x1440 --binsize 2560x1440 --bsize 2560x1440 -A -h 2560x1440 --smaxsize 2560x1440 --bc cbr --frame-factor 28/30 --profile 0 -M 1 --max-gop-M 1 --gop 0 -N 20 --idr 1 --bitrate 5845050 --deblocking-enable 1 -b 0 -K --btype enc --bmaxsize 768x432 --binsize 2560x1440 --bsize 768x432 -C -m 768x432 --smaxsize 768x432 --bc cbr --frame-factor 7/30 -q 84 -b 3 -Y --btype enc --bmaxsize 352x288 --binsize 2560x1440 --bsize 352x288 -B -h 352x288 --smaxsize 352x288 --bc cbr --frame-factor 7/30 --profile 0 -M 1 --max-gop-M 1 --gop 0 -N 20 --idr 1 --bitrate 765257 --deblocking-enable 1 -b 1
Connection established with kernel.
resolution 2560x1440
resolution 768x432
resolution 768x432
resolution 768x432
resolution 768x432
352x288 resolution is 352x288
IAVIOC_S_IDLE done
sink 0 is CVBS
vout_get_sink_id: 1 1, return 0
init_vout1 done
2560x1440P(HDR 2x) 30 RGB 10bits 16:9 AUTO rev[0]
Active src 0's mode is:
2560x1440P 30 RGB 10bits 16:9 AUTO rev[0]
init_vin done
>>> pipline:2, hdr_mode:0, expo_num:1, raw_pitch:0
>>> main:size 2560x1440, raw:2560x1440, resolution:10
no translater for filter 10
init 3A done
loop start now
enable_preview done
>>> ======= [DONE] mw_start_aaa =======
The current vin fps is 30, stream [0] encoding fps will be 30 x 28/30!
The current vin fps is 30, stream [1] encoding fps will be 30 x 7/30!
The current vin fps is 30, stream [2] encoding fps will be 30 x 7/30!
>>>>> restart 0
img_get_3a_cntl_status awb_enable=1 ae_enable=1 af_enable=0 adj_enable=1
img_get_sensor_agc agc=0
img_get_wdr_enable wdr=0
img_get_ae_cfa_luma cfa_luma=0
img_get_ae_rgb_luma rgb_luma=0
img_get_ae_system_gain agc=0
img_get_ae_target_ratio ae_target_ratio=1024
img_get_ae_target ae_target_ratio=110
mw_get_ae_param ae_param.ae_level[0]=100
mw_get_ae_param ae_param.ae_level[1]=0
mw_get_ae_param ae_param.ae_level[2]=0
mw_get_ae_param ae_param.ae_level[3]=0
img_get_wb_property_ratio wb_r_ratio=128 wb_b_ratio=128
img_get_img_property brightness=0 contrast=64 saturation=64 hue=0
mw_get_sharpness sharpness=6
=== Sensor is Normal mode
sensor_gain_max:36 shutter_time_min:32000 shutter_time_max:8533333
>> setCamera() CAMERA_AE_ENABLE : 1
>> runCode() CAMERA_AE_ENABLE:1
>> setCamera() first:1 lp:CAMERA_AE_ENABLE ret:Ok
>> setCamera() CAMERA_EXP_LEVEL : 128
>> runCode() CAMERA_EXP_LEVEL:128
>> setCamera() first:1 lp:CAMERA_EXP_LEVEL ret:Ok
>> setCamera() CAMERA_A_FLICKER : 1
>> runCode() CAMERA_A_FLICKER:1
>> setCamera() first:1 lp:CAMERA_A_FLICKER ret:Ok
>> setCamera() CAMERA_AE_METERING : 1
>> runCode() CAMERA_AE_METERING:1
>> setCamera() first:1 lp:CAMERA_AE_METERING ret:Ok
>> setCamera() CAMERA_AWB_ENABLE : 1
>> runCode() CAMERA_AWB_ENABLE:1
>> setCamera() first:1 lp:CAMERA_AWB_ENABLE ret:Ok
>> setCamera() CAMERA_AWB_MODE : 0
>> runCode() CAMERA_AWB_MODE:0
>> setCamera() first:1 lp:CAMERA_AWB_MODE ret:Ok
>> setCamera() CAMERA_R_GAIN : 1500
>> runCode() CAMERA_R_GAIN:1500
>> setCamera() first:1 lp:CAMERA_B_GAIN ret:Ok
>> setCamera() CAMERA_HUE : 50
>> runCode() CAMERA_HUE:50
>> runCode() img_set_color_hue :0
>> setCamera() first:1 lp:CAMERA_HUE ret:Ok
>> setCamera() CAMERA_SATURATION : 25
>> runCode() CAMERA_SATURATION:25
>> runCode() mw_set_saturation :64
>> setCamera() first:1 lp:CAMERA_SATURATION ret:Ok
>> setCamera() CAMERA_BRIGHTNESS : 50
>> runCode() CAMERA_BRIGHTNESS:50
>> runCode() mw_set_brightness :0
>> setCamera() first:1 lp:CAMERA_BRIGHTNESS ret:Ok
>> setCamera() CAMERA_CONTRAST : 50
>> runCode() CAMERA_CONTRAST:50
>> runCode() mw_set_contrast :64
>> setCamera() first:1 lp:CAMERA_CONTRAST ret:Ok
>> setCamera() CAMERA_SHARPNESS : 55
>> runCode() CAMERA_SHARPNESS:55
>> runCode() mw_set_sharpness :6
>> setCamera() first:1 lp:CAMERA_SHARPNESS ret:Ok
>> setCamera() CAMERA_MCTF_3DNR : 1
>> runCode() CAMERA_MCTF_3DNR:1
>> setCamera() first:1 lp:CAMERA_MCTF_3DNR ret:Ok
>> setCamera() CAMERA_LOCAL_EXP : 0
>> runCode() CAMERA_LOCAL_EXP:0
>> setCamera() first:1 lp:CAMERA_LOCAL_EXP ret:Ok
>> setCamera() CAMERA_BACKLIGHT : 0
>> runCode() CAMERA_BACKLIGHT:0
>>> The strength is 0 already
>> setCamera() first:1 lp:CAMERA_BACKLIGHT ret:Ok
>> setCamera() CAMERA_DN_MODE : 2
>> runCode() CAMERA_DN_MODE:2
[runCode][2120] value = 2
>> setCamera() first:1 lp:CAMERA_DN_MODE ret:Ok
>> setCamera() CAMERA_SHUTTER : 2
>> setCamera() CAMERA_SLOW_SHUTTER : 1
>> runCode() CAMERA_SLOW_SHUTTER:1
>> setCamera() first:1 lp:CAMERA_SLOW_SHUTTER ret:Ok
>> setCamera() CAMERA_MIRROR : 0
>> runCode() CAMERA_MIRROR:0
>> setCamera() first:1 lp:CAMERA_MIRROR ret:Ok
>> setCamera() CAMERA_FLIP : 0
>> runCode() CAMERA_FLIP:0
>> setCamera() first:1 lp:CAMERA_FLIP ret:Ok
>> setCamera() CAMERA_GAIN : 9
>> runCode() CAMERA_GAIN:9
>> setCamera() first:1 lp:CAMERA_GAIN ret:Ok
>> setCamera() CAMERA_TDN_BW_LEVEL : 5
>> runCode() CAMERA_TDN_BW_LEVEL:5
>> setCamera() first:1 lp:CAMERA_TDN_BW_LEVEL ret:Ok
>> setCamera() CAMERA_TDN_COLOR_LEVEL : 5
>> runCode() CAMERA_TDN_COLOR_LEVEL:5
>> setCamera() first:1 lp:CAMERA_TDN_COLOR_LEVEL ret:Ok
>> setCamera() CAMERA_RESP : 1
>> runCode() CAMERA_RESP:1
>> setCamera() first:1 lp:CAMERA_RESP ret:Ok
>> setCamera() CAMERA_HDR_MODE : 0
>> runCode() CAMERA_HDR_MODE:0
>> setCamera() first:1 lp:CAMERA_HDR_MODE ret:Ok
>> setCamera() CAMERA_HDR_LEVEL : 0
>> runCode() CAMERA_HDR_LEVEL:0
>> setCamera() first:1 lp:CAMERA_HDR_LEVEL ret:Ok
>> setCamera() CAMERA_TDN_COLOR_HOUR : 5
>> runCode() CAMERA_TDN_COLOR_HOUR:5
>> setCamera() first:1 lp:CAMERA_TDN_COLOR_HOUR ret:Ok
>> setCamera() CAMERA_TDN_COLOR_MIN : 0
>> runCode() CAMERA_TDN_COLOR_MIN:0
>> setCamera() first:1 lp:CAMERA_TDN_COLOR_MIN ret:Ok
>> setCamera() CAMERA_TDN_BW_HOUR : 19
>> runCode() CAMERA_TDN_BW_HOUR:19
>> setCamera() first:1 lp:CAMERA_TDN_BW_HOUR ret:Ok
>> setCamera() CAMERA_TDN_BW_MIN : 0
>> runCode() CAMERA_TDN_BW_MIN:0
>> setCamera() first:1 lp:CAMERA_TDN_BW_MIN ret:Ok
>> /usr/local/bin/test_encode --mirror-pattern 3
+[mainLoop][1036] START - CamA5sOsd::mainLoop
>> lens type 1
overlay: start = 0x71140000, total size = 0x200000 ( bytes)
@ [start][208] MOTION IS UP
Motion Buffer pitch 640, width 640, height 360
>> ui: origin sens:3276870
>> ui: thres:50, sens:70
>> api: thres:49, sens:84
>> ui: ROI 0, 0, 100, 100
>> api: ROI 0, 0, 639, 359
>> ui: origin sens:0
>> ui: thres:0, sens:0
>> ui: origin sens:0
>> ui: thres:0, sens:0
>> ui: origin sens:0
>> ui: thres:0, sens:0
>> /usr/local/bin/test_encode -A -e -B -e -C -e
ROI#0 Motion Start!
Start encoding for stream 0x7 successfully
TOMATO id= 0 enable= 0 sense= 50 10 10 50 50
bsb_mem = 0x615cd000, size = 0x600000
open /mnt/nand/ipnc_sys.cfg(FD21)
close /mnt/nand/ipnc_sys.cfg(FD21)
route: SIOCDELRT: No such process
open /mnt/nand/ipnc_sys.cfg(FD22)
close /mnt/nand/ipnc_sys.cfg(FD22)
[CamSocketServer:143]>>Socket[ 10.756283] iav_query_me1desc(696): [TIMEOUT] Query ME1 descriptor.
[connect:192]>>SocketClient: connect() failed - errno(2)
ipnc: /home/sb/project_S2L/s2lmcaas/ipnc/source/app/messenger/CamNotifyMessenger.cpp:57: virtual void CamNotifyMessenger::initialize(): Assertion `0 == ret' failed.
[sighdlr_exit:45]>>Signal Exit : 6
~CamThread: 48: ### Thread"HwMon" is exit
~CamThread: 48: ### Thread"WatchdogTsk" is exit
Код: Выделить всё
boot console=ttyS0 ubi.mtd=lnx root=ubi0:rootfs rw rootfstype=ubifs init=/bin/sh
Код: Выделить всё
amboot> boot
bst: 0x7445286A 0.5 (2017/9/1) 0x00000000 0x00000001 (2048)
bld: 0x381E9FF5 1.1 (2017/9/1) 0x00000000 0x00000000 (206056)
pri: 0xB3ABD2A1 0.18 (2018/1/23) 0x00208000 0x00000000 (6338872)
bak: 0x8116F5D3 0.18 (2018/3/14) 0x00000000 0x00000001 (53084160)
loading pri to 0x00208000
rmd image absent... skipping
Jumping to 0x00208000 ...
cpux_jump: 0x00000000
initrd2_start: 0x00000000 initrd2_size: 0x00000000
kernelp: 0x00200000 kernels: 0x0FE00000
idspp: 0x10000000 idsps: 0x10000000
fbp: 0x10000000 fbs: 0x00000000
37:51 KST 2018
nit=/linuxrc
[ 0.332791] pid_max: default: 32768 minimum: 301
[ 0.337452] Mount-cache hash table entries: 512
[ 0.343842] CPU: Testing write buffer coherency: ok
[ 0.356994] devtmpfs: initialized
[ 0.361252] pinctrl core: initialized pinctrl subsystem
[ 0.366655] NET: Registered protocol family 16
[ 0.371599] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.378764] Ambarella power management: Wed Aug 10 2016
[ 0.384091] L310 cache controller enabled
[ 0.388079] l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32020000, Cache size: 131072 B
[ 0.397137] ambarella-pinctrl e8009000.pinctrl: Ambarella pinctrl driver registered
[ 0.405012] ambarella-gpio gpio.0: Ambarella GPIO driver registered
[ 0.413741] bio: create slab <bio-0> at 0
[ 0.418414] ambarella-dma e0005000.dma: Ambarella DMA Engine
[ 0.425044] ambarella-i2c e8003000.i2c: Ambarella I2C adapter[0] probed!
[ 0.431919] ambarella-i2c e8001000.i2c: Ambarella I2C adapter[1] probed!
[ 0.439217] Switching to clocksource ambarella-cs-timer
[ 0.444579] FS-Cache: Loaded
[ 0.451416] NET: Registered protocol family 2
[ 0.456322] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.463370] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.469782] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.476165] TCP: reno registered
[ 0.479375] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.485199] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.491540] NET: Registered protocol family 1
[ 0.496069] RPC: Registered named UNIX socket transport module.
[ 0.501964] RPC: Registered udp transport module.
[ 0.506677] RPC: Registered tcp transport module.
[ 0.511356] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.518026] ambarella-adc e801d000.adc: Ambarella ADC driver init
[ 0.524976] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.530943] NFS: Registering the id_resolver key type
[ 0.536073] Key type id_resolver registered
[ 0.540234] Key type id_legacy registered
[ 0.544229] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.550798] FS-Cache: Netfs 'cifs' registered for caching
[ 0.556242] Key type cifs.spnego registered
[ 0.560423] Key type cifs.idmap registered
[ 0.564514] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.570655] msgmni has been set to 490
[ 0.575194] NET: Registered protocol family 38
[ 0.579677] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.587128] io scheduler noop registered
[ 0.591028] io scheduler deadline registered
[ 0.595305] io scheduler cfq registered (default)
[ 0.600193] e8005000.uart: ttyS0 at MMIO 0xe8005000 (irq = 9) is a ambuart
[ 0.607628] brd: module loaded
[ 0.612285] loop: module loaded
[ 0.617787] ambarella-nand e0001000.nand: in ecc-[1]bit mode
[ 0.623424] ambarella_nand: Use On Flash BBT
[ 0.627758] NAND device: Manufacturer ID: 0xc8, Chip ID: 0xda (GigdDevice NAND 256MiB 3,3V 8-bit)
[ 0.640170] Bad block table found at page 131008, version 0x01
[ 0.646120] Bad block table found at page 130944, version 0x01
[ 0.652076] nand_read_bbt: bad block at 0x00000f2a0000
[ 0.657198] nand_read_bbt: bad block at 0x00000f560000
[ 0.662308] nand_read_bbt: bad block at 0x00000fb40000
[ 0.667471] 11 ofpart partitions found on MTD device amba_nand
[ 0.673277] Creating 11 MTD partitions on "amba_nand":
[ 0.678404] 0x000000000000-0x000000020000 : "bst"
[ 0.683551] 0x000000020000-0x000000160000 : "bld"
[ 0.688683] 0x000000160000-0x0000002a0000 : "ptb"
[ 0.693772] 0x0000002a0000-0x0000006a0000 : "spl"
[ 0.698891] 0x0000006a0000-0x000000ea0000 : "pba"
[ 0.703986] 0x000000ea0000-0x000001aa0000 : "pri"
[ 0.709135] 0x000001aa0000-0x0000026a0000 : "sec"
[ 0.714228] 0x0000026a0000-0x0000028a0000 : "bak"
[ 0.719372] 0x0000028a0000-0x0000066a0000 : "rmd"
[ 0.724537] 0x0000066a0000-0x00000a6a0000 : "lnx"
[ 0.729705] 0x00000a6a0000-0x00000e6a0000 : "swp"
[ 0.794507] libphy: Ambarella MII Bus: probed
[ 0.798850] mdio_bus e000e000.etherne: /ahb@e0000000/ethernet@e000e000/phy@3 has invalid PHY addr
ess
[ 0.807966] mdio_bus e000e000.etherne: scan phy phy at address 0
[ 0.814263] mdio_bus e000e000.etherne: registered phy phy at address 0
[ 0.820819] ambarella-eth e000e000.ethernet: Ethernet PHY[0]: 0x00221560!
[ 0.827861] ambarella-eth e000e000.ethernet: MAC Address[d0:50:99:49:1f:3d].
[ 0.835076] mousedev: PS/2 mouse device common for all mice
[ 0.840848] ambarella-rtc e8015000.rtc: rtc core: registered rtc-ambarella as rtc0
[ 0.848718] ambarella-wdt e800c000.wdt: Ambarella Watchdog Timer Probed.
[ 0.855465] ambarella cpufreq driver init
[ 0.859577] IPVS: Registered protocols ()
[ 0.863579] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 0.870976] IPVS: Creating netns size=736 id=0
[ 0.875440] IPVS: ipvs loaded.
[ 0.878577] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.883949] arp_tables: (C) 2002 David S. Miller
[ 0.888599] TCP: cubic registered
[ 0.891892] Initializing XFRM netlink socket
[ 0.896193] NET: Registered protocol family 10
[ 0.901051] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 0.906523] sit: IPv6 over IPv4 tunneling driver
[ 0.911464] NET: Registered protocol family 17
[ 0.915985] Key type dns_resolver registered
[ 0.920275] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.927917] ThumbEE CPU extension supported.
[ 0.932948] UBI: attaching mtd9 to ubi0
[ 1.000566] UBI: scanning is finished
[ 1.007916] UBI: attached mtd9 (name "lnx", size 64 MiB) to ubi0
[ 1.013901] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 1.020696] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 1.027378] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 1.034222] UBI: good PEBs: 512, bad PEBs: 0, corrupted PEBs: 0
[ 1.040123] UBI: user volume: 0, internal volumes: 1, max. volumes count: 128
[ 1.047234] UBI: max/mean erase counter: 1/1, WL threshold: 4096, image sequence number: 19737779
30
[ 1.056251] UBI: available PEBs: 468, total reserved PEBs: 44, PEBs reserved for bad PEB handling
: 40
[ 1.065448] UBI: background thread "ubi_bgt0d" started, PID 42
[ 1.071307] ambarella-rtc e8015000.rtc: setting system clock to 1970-01-01 01:27:38 UTC (5258)
[ 1.080264] UBIFS error (pid 1): ubifs_mount: cannot open "ubi0:rootfs", error -19
[ 1.087893] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0): error -19
[ 1.095941] Please append a correct "root=" boot option; here are the available partitions:
[ 1.104301] 1f00 128 mtdblock0 (driver?)
[ 1.109420] 1f01 1280 mtdblock1 (driver?)
[ 1.114523] 1f02 1280 mtdblock2 (driver?)
[ 1.119611] 1f03 4096 mtdblock3 (driver?)
[ 1.124713] 1f04 8192 mtdblock4 (driver?)
[ 1.129800] 1f05 12288 mtdblock5 (driver?)
[ 1.134898] 1f06 12288 mtdblock6 (driver?)
[ 1.139994] 1f07 2048 mtdblock7 (driver?)
[ 1.145089] 1f08 63488 mtdblock8 (driver?)
[ 1.150176] 1f09 65536 mtdblock9 (driver?)
[ 1.155272] 1f0a 65536 mtdblock10 (driver?)
[ 1.160442] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 1.168680] CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.73 #1
[ 1.174512] [<800133ec>] (unwind_backtrace+0x0/0x12c) from [<80011a50>] (show_stack+0x10/0x14)
[ 1.183099] [<80011a50>] (show_stack+0x10/0x14) from [<804366cc>] (panic+0xa4/0x1e0)
[ 1.190818] [<804366cc>] (panic+0xa4/0x1e0) from [<805a3f98>] (mount_block_root+0x1d4/0x278)
[ 1.199227] [<805a3f98>] (mount_block_root+0x1d4/0x278) from [<805a4308>] (prepare_namespace+0xa8
/0x1d4)
[ 1.208675] [<805a4308>] (prepare_namespace+0xa8/0x1d4) from [<805a3c20>] (kernel_init_freeable+0
x1b0/0x1c0)
[ 1.218475] [<805a3c20>] (kernel_init_freeable+0x1b0/0x1c0) from [<80435e7c>] (kernel_init+0xc/0x
154)
[ 1.227667] [<80435e7c>] (kernel_init+0xc/0x154) from [<8000ed58>] (ret_from_fork+0x14/0x3c)
Код: Выделить всё
cat /dev/mtdblock0 | gzip -9 -c > /tmp/mtd0.gz
cat /dev/mtdblock10 | gzip -9 -c > /tmp/mtd10.gz
Подключаюсь я к нем через телнет, но поднять сеть у меня не получается, чтобы так же использовать tftp - настроки прописал, но линка нет на роутере
Код: Выделить всё
CPRO Copyright (C) 2016-2026
Boot From: NAND 2048 RC
SYS_CONFIG: 0x3006005B POC: 101
Cortex freq: 1008000000
ENET freq: 50000000
iDSP freq: 504000000
Dram freq: 660000000
Core freq: 432000000
AHB freq: 216000000
APB freq: 108000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
amboot> show netboot
eth0_mac: 11:22:33:01:02:01
eth0_ip: 192.168.0.101
eth0_mask: 255.255.255.0
eth0_gw: 192.168.0.12
eth1_mac: 11:22:33:01:02:02
eth1_ip: 192.168.1.102
eth1_mask: 255.255.255.0
eth1_gw: 192.168.1.12
auto_dl: 1
tftpd: 192.168.0.12
pri_addr: 0x00000000
pri_file:
pri_comp: 0
rmd_addr: 0x00000000
rmd_file:
rmd_comp: 0
dsp_addr: 0x00000000
dsp_file:
dsp_comp: 0
amboot>
Код: Выделить всё
amboot> ping 192.168.0.12
link down ...
Топик http://forum.videon.spb.ru/viewtopic.php?f=24&t=8311 перечитан, но там без счастливого финала.
