Ip камера DAHUA DH-IPC2231RP-ZS-IRE6
aavan
Re: Ip камера DAHUA DH-IPC2231RP-ZS-IRE6
Сообщение aavan » 26 мар 2020, 11:09
Прошил дамп на программаторе,камера стала оживать .через uart и tftp ,командами run dr,run dk, и т.д. загрузил прошивку вот результат
U-Boot 2010.06-svn5733 (Aug 12 2018 - 00:33:23)
I2C: ready
DRAM: 118 MiB
gBootLogPtr:00b80008.
spinor flash ID is 0x1940ef
partition file version 2
rootfstype squashfs root /dev/mtdblock5
fail to parse HWID
fail to parse bootargsParametersV2.text info
fail to init bootargsParametersV2
TEXT_BASE:01000000
Net: Detected MACID:00:12:34:56:78:9a
PHY:0x001cc816,addr:0x00
s3l phy RTL8201 init
sd update init:HWID is missing!
link down
Using ambarella mac device
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Download Filename 'upgrade_info_7db780a713a4.txt'.
Download to address: 0x5000000
Downloading:
Retry count exceeded; starting again
Try again use backup_serverip
*** ERROR: `serverip' not set
Failed to get info.txt
Fail to get info file!
Init error!
Download Filename 'failed.txt'.
Download to address: 0x2000000
Downloading:
Support backupVer:255
state:ff,err_count:02
unknown phy memory type, use default
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
get bootargs info failed
hmagic=0xffffffff
Before write boot backup version page, it should be erased!!!
SPI probe: 32768 KiB W25Q256FV at 0:0 is now current device
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Linux-3.10.73
Created: 2019-01-11 13:17:05 UTC
Data Size: 1570224 Bytes = 1.5 MiB
Load Address: 00208000
Entry Point: 00208000
Verifying Checksum ... OK
Loading Kernel Image ...OK
OK
crashflasg:1, logmagic:54410011.
Starting kernel ...
unknown core,use back
Это что-неродная прошивка?
fobos
Сообщение fobos » 26 мар 2020, 22:08
нужно, как минимум, HWID корректный прописать
aavan
Сообщение aavan » 27 мар 2020, 04:56
Как это сделать?
fobos
Сообщение fobos » 27 мар 2020, 17:49
setenv HWID <указать корректный HWID для данного семейства камер>
saveenv
reset
aavan
Сообщение aavan » 28 мар 2020, 09:35
Из рабочей камеры DH-IPC-HFW2431 скопировал HWID:
HWID=IPC-HFW2431T-ZAS-2713:01:02:02:23:20:00:01:0F:01:01:04:2D0:03:00:00:00:00:01:00:00:200
скопировал его заменив название
Environment size: 1053/131068 bytes
>setenv HWID IPC-HFW2231RP-ZS-2713:01:02:02:23:20:00:01:0F:01:01:04:2D0:03:00:00:00:00:01:00:00:200
>saveenv
Saving Environment to SPI Flash...
Erasing SPI flash...
Writing to SPI flash...
erase bst!
reload 33
теперь выдаёт такое сообщение
I2C: ready
DRAM: 118 MiB
can not search bootargs settings
TEXT_BASE:01000000
MMC: sdmmc init
link down
link down
link down
Init error!
link down
state:ff,err_count:00
smagic=0x424f4f54
OK
Starting kernel ...
half-boot found, check bst
aavan
Сообщение aavan » 29 мар 2020, 06:11
О,пока никто не ответил.Сегодня есть время заняться камерой-растолкуйте кто знает,что за bst предлагается проверить.
fobos
Сообщение fobos » 29 мар 2020, 22:20
так у IPC-HFW2431T-ZAS и IPC-HFW2231RP-ZS HWID разный...простое изменение названия не даст результата...в архиве от oleglevsha есть файл check.img...в нем указан корректный HWID для вашей камеры
arni
Сообщение arni » 11 авг 2020, 13:20
У меня такая же ситуация на камере HDBW5431EP-Z, поможете ?
fobos
Сообщение fobos » 13 авг 2020, 21:57
конкретно чем помочь?
VirtualLink
Сообщение VirtualLink » 14 авг 2020, 10:20
aavan писал(а):
24 мар 2020, 18:33
В смысле без мас?будьте любезны,растолкуйте какова процедура восстановления.просто залить дамп на программаторе видимо недостаточно?напоминаю-у меня чистая флешь.
Остановить загрузку и далее команды
set mac XX:XX:XX:XX:XX:XX
saveenv
