Re: Восстановление прошивки и сброс пароля XM с помощью USB
Команды выполняются до:
Вроде как заводится и дальше просит ввести логин и пароль.Следующие команды ввести не могу.
						Код: Выделить всё
bootm 0x81000000 0x82000000Код: Выделить всё
U-Boot 2010.06 (Sep 24 2014 - 11:37:37)
Spi(cs1) ID: 0xC2 0x20 0x17 0xC2 0x20 0x17
spi->chipsize:8388608
start_up_mode is 3bite
Spi(cs1): Block:64KB Chip:8MB Name:"MX25L6406E"
Spi(cs1): 3 addr SPI read:0x1,3B,0xc write:0x0,02,0xc erase:0x0,D8,0xc
num_chip of Spi: 1
In:    serial
Out:   serial
Err:   serial
(Re)start USB search...
USB:   scanning bus for devices... 2 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
hisilicon # setenv bootcmd showlogo
hisilicon # startvo 0 36 13
dev 0 opened!
hisilicon # sf probe 0
hisilicon # sf read 0x81000000 0xA0000 0x190000
hisilicon # sf read 0x82000000 0x230000 0x1A0000
hisilicon # bootm 0x81000000 0x82000000
## Booting kernel from Legacy Image at 81000000 ...
   Image Name:   Linux-3.0.8
   Data Size:    1597248 Bytes = 1.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
## Loading init Ramdisk from Legacy Image at 82000000 ...
   Image Name:   RAM disk
   Image Type:   ARM Linux RAMDisk Image (uncompressed)
   Data Size:    1674756 Bytes = 1.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (mrdong@mrdong-desktop) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #17 Tue Oct 28 09:48:04 CST 2014
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: hi3520d
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 24384
Kernel command line: mem=96M console=ttyAMA0,115200
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 96MB = 96MB total
Memory: 91468k/91468k available, 6836k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xc6800000 - 0xfe000000   ( 888 MB)
    lowmem  : 0xc0000000 - 0xc6000000   (  96 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0024000   ( 112 kB)
      .text : 0xc0024000 - 0xc03c5000   (3716 kB)
      .data : 0xc03c6000 - 0xc03dfa60   ( 103 kB)
       .bss : 0xc03dfa84 - 0xc042f928   ( 320 kB)
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 82MHz, resolution 12ns, wraps every 52060ms
Calibrating delay loop... 1318.91 BogoMIPS (lpj=6594560)
update_logo 9
console [ttyAMA0] enabled
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 42) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
Trying to unpack rootfs image as initramfs...
update_logo 10
update_logo 11
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 1632K
L2cache cache controller enabled
msgmni has been set to 181
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 52
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 52
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:8MB
spi size: 0x8388608
chip num: 1
Creating 0 MTD partitions on "hi_sfc":
Fixed MDIO Bus: probed
ata1: SATA link down (SStatus 0 SControl 300)
himii: probed
ata2: SATA link down (SStatus 0 SControl 300)
Invalid HW-MAC Address: 00:00:00:00:00:00
Set Random MAC address: C2:64:BB:70:77:E3
PPP Deflate Compression module registered
PPP BSD Compression module registered
NET: Registered protocol family 24
usbmon: debugfs is not available
hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
usbhid: USB HID core driver
TCP cubic registered
RAMDISK: xz image found at block 0
update_logo 12
usb 2-1: new full speed USB device number 2 using hiusb-ohci
input: A4Tech USB Mouse as /devices/platform/hiusb-ohci.0/usb2/2-1/2-1:1.0/input/input0
generic-usb 0003:09DA:0080.0001: input: USB HID v1.11 Mouse [A4Tech USB Mouse] on usb-hiusb-ohci-1/input0
update_logo 13
VFS: Mounted root (ext2 filesystem) on device 1:0.
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
Jan  1 08:00:02 udevd (360): /proc/360/oom_adj is deprecated, please use /proc/360/oom_score_adj instead.
udevd[360]: main: error opening /dev/null: No such file or directory
[RCS]: /etc/init.d/S80network
mount: mounting /dev/mtdblock5 on /etc/conf.d/ failed: No such file or directory
mount: mounting /dev/mtdblock3 on /cramfs_tmp/ failed: No such file or directory
mount: mounting /cramfs_tmp/Cramfs-ko on /usr/ko_hi3520D/ failed: No such file or directory
cat: can't open '/dev/mtdblock4': No such file or directory
mount: mounting /dev/ram1 on /progs/bin/ failed: Invalid argument
mount: mounting /cramfs_tmp/Cramfs-res on /progs/res/ failed: No such file or directory
mount: mounting /cramfs_tmp/Cramfs-ie on /progs/html/ failed: No such file or directory
sh: can't open '/usr/ko_hi3520D/pinmux_8D1_hi3520D.sh'
*** Board tools : ver0.0.1_20121120 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x200f005c: 0x00000000 --> 0x00000001
[END]
0x200f0060: 0x00000000 --> 0x00000001
[END]
sh: can't open '/usr/ko_hi3520D/crgctrl_8D1_hi3520D.sh'
insmod: can't insert '/usr/ko_hi3520D/extdrv/gpioi2c.ko': No such file or directory
insmod: can't insert '/usr/ko_hi3520D/extdrv/gpioi2c_hdmi.ko': No such file or directory
/etc/init.d/rcS: line 44: /usr/ko_hi3520D/extdrv/i2c_read: not found
sh: fd:54: unknown operand
insmod: can't insert '/usr/ko_hi3520D/extdrv/ad_driver.ko': No such file or directory
setMac err:open /dev/jdvr fail
192.168.1.10
255.255.255.0
192.168.1.1
0
after network.sh
/etc/init.d/rcS: line 62: ./load3520D: not found
insmod: can't insert 'extdrv/jovi_key.ko': No such file or directory
hwclock: can't open '/dev/hi_rtc': No such file or directory
/etc/init.d/rcS: line 80: ./bin/jdvr: not found
(none) login: /etc/init.d/rcS: line 79: ./bin/mySystem: not found
setenv bootargs mem=55M console=ttyAMA0,115200 root=0100 rootfstype=ext2 mtdparts=hi_sfc:640k(boot),1600K(kernel),1664K,2304k,1664k,320ksetenv bootargs mem=55M console=ttyAMA0,115200 root=0100 rootfstype=ext2 mtdparts=hi_sfc:640k(boot),1600K(kernel),1664K,2304k,1664k,320k
(none) login:
Login timed out after 60 seconds
(none) login:
(none) login:
Вставляю флешку, подаю питание получаю следующее:
Код: Выделить всё
num_chip of Spi: 1
In:    serial
Out:   serial
Err:   serial
USB:   scanning bus for devices... 3 USB Device(s) found
       scanning bus for storage devices... usb_stor_get_info->1406,blksz:512
1 Storage Device(s) found
** Partition 1 not valid on device 0 **
** Partition 5 not valid on device 0 **
** Unable to use usb 0:5 for fatls **
Hit any key to stop autoboot:  0
saveaddr: 82000000
do_netupdate
Hisilicon ETH net controler
MAC:   00-00-23-34-45-66
Up/Down PHY not link.
vo 0,picwh:720 576, addr=0, xywh:40 12 720 576
vo 2,picwh:720 576, addr=0, xywh:0 0 720 576
С флешки удалить все разделы, отформатировать ее в фат32
Наверное вот так надо было, ну или в одинарных попробуете. Всего 4 команды, не должно разделять
Код: Выделить всё
setenv bootcmd "showlogo;startvo 0 36 13;sf probe 0;sf read 0x81000000 0xA0000 0x190000;sf read 0x82000000 0x230000 0x1A0000;bootm 0x81000000 0x82000000"
setenv bootargs "mem=55M console=ttyAMA0,115200 root=0100 rootfstype=ext2 mtdparts=hi_sfc:640k(boot),1600K(kernel),1664K,2304k,1664k,320k"
setenv machine MBD6004D
saveenvRe: Восстановление прошивки и сброс пароля XM с помощью USB
Заливаю прошивку. Даю первую команду.
Лог такой
Просит ввести логин и пароль. Дальше никакие команды не принимает. На экране зеленый фон.
						Код: Выделить всё
setenv bootcmd "showlogo;startvo 0 36 13;sf probe 0;sf read 0x81000000 0xA0000 0x190000;sf read 0x82000000 0x230000 0x1A0000;bootm 0x81000000 0x82000000"Код: Выделить всё
num_chip of Spi: 1
In:    serial
Out:   serial
Err:   serial
USB:   scanning bus for devices... 1 USB Device(s) found
hisilicon # setenv bootcmd "showlogo;startvo 0 36 13;sf probe 0;sf read 0x81000000 0xA0000 0x190000;sf read 0x82000000 0x230000 0x1A0000;bootm 0x81000000 0x82000000"
dev 0 opened!
   Data Size:    1606924 Bytes = 1.5 MiB
   Data Size:    1672568 Bytes = 1.6 MiB
OK
Starting kernel ...
Linux version 3.0.8 (mrdong@mrdong-desktop) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #2 Tue Jun 10 10:38:56 CST 2014
Machine: hi3520d
Memory: 91444k/91444k available, 6860k reserved, 0K highmem
      .text : 0xc0024000 - 0xc03cc000   (3744 kB)
      .data : 0xc03cc000 - 0xc03e6c80   ( 108 kB)
       .bss : 0xc03e6ca4 - 0xc0435b68   ( 316 kB)
update_logo 9
TCP reno registered
update_logo 10
update_logo 11
brd: module loaded
Spi(cs1):
Block:64KB
Chip:8MB
spi size: 0x8388608
chip num: 1
himii: probed
Set Random MAC address: F6:D9:40:D5:9B:49
usbcore: registered new interface driver kaweth
pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
cdc_ncm: 04-Aug-2011
usbcore: registered new interface driver cdc_ncm
usbcore: registered new interface driver cdc_wdm
update_logo 12
update_logo 13
Jan  1 08:00:02 udevd (361): /proc/361/oom_adj is deprecated, please use /proc/361/oom_score_adj instead.
udevd[361]: main: error opening /dev/null: No such file or directory
[END]
[END]
192.168.1.10
255.255.255.0
192.168.1.1
0
after network.sh
/etc/init.d/rcS: line 60: ./load3520D: not found
insmod: can't insert 'showlogo.ko': No such file or directory
rmmod: can't unload 'showlogo': unknown symbol in module, or unknown parameter
/etc/init.d/rcS: line 78: ./bin/jdvr: not found
(none) login: /etc/init.d/rcS: line 77: ./bin/mySystem: not found
(none) login:
НУ в одинарных попробуйте, я ж написал сразу. После всех этих команд ничего не должно происходить, просто переход строки для ввода следующей
В одинарных перед каждой командой нужно прописывать setenv?
при вводе одинарных команд получается так:
что я делаю не так?
						Код: Выделить всё
num_chip of Spi: 1
In:    serial
Out:   serial
Err:   serial
hisilicon # setenv startvo 0 36 13
hisilicon # setenv sf probe 0
hisilicon # setenv sf read 0x81000000 0xA0000 0x190000
hisilicon # setenv sf read 0x82000000 0x230000 0x1A0000
hisilicon # setenv bootm 0x81000000 0x82000000
hisilicon # setenv bootargs mem=55M console=ttyAMA0,115200 root=0100 rootfstype=ext2 mtdparts=hi_sfc:640k(boot),1600K(kernel),1664K,2304k,1664k,320k
hisilicon # setenv machine MBD6004D
hisilicon # saveenv
Saving Environment to SPI Flash...
Erasing SPI flash, offset 0x00050000 size 64K ...done
Writing to SPI flash, offset 0x00050000 size 64K ...done
hisilicon # reset
resetting ...
num_chip of Spi: 1
In:    serial
Out:   serial
Err:   serial
saveaddr: 82000000
do_netupdate
Вы что-то не так копируете, там  4 команды, вы в логе 10 показываете
вот это все одна команда, а не 5
setenv bootcmd 'showlogo;startvo 0 36 13;sf probe 0;sf read 0x81000000 0xA0000 0x190000;sf read 0x82000000 0x230000 0x1A0000;bootm 0x81000000 0x82000000'
одинарные кавычки, я имел ввиду, не команды
Теперь вставляю флешку, подаю питание и получаю следующее:
после перезапуска:
Что еще можно попробовать?
						Код: Выделить всё
num_chip of Spi: 1
In:    serial
Out:   serial
Err:   serial
reading jdvr-recover-MBD6004D-ver.bin
get jdvr-recover-MBD6004D-ver.bin size=-1
recover mask=ffffffff
reading jdvr-recover-MBD6004D.bin
jpeg decoding ...
<<addr=0x8082d054, size=0x77ff, vobuf=0x83000000>>
mmu_enable
<<imgwidth=320, imgheight=320, linebytes=640>>
decode success!!!!
decode jpeg!
dev 0 set background color!
dev 0 opened!
graphic layer 0 opened!
dev 2 set background color!
dev 2 opened!
graphic layer 2 opened!
start decrypt...
Erasing at 0x800000 -- 100% complete.
Writing at 0x800000 -- 100% complete.
dev 0 closed!
dev 2 closed!
hisilicon #
Код: Выделить всё
num_chip of Spi: 1
In:    serial
Out:   serial
Err:   serial
hisilicon #
Делать и энв и флешку, у вас файл прошился, но энв все равно пустой, поэтому там просто нет команд для запуска. Выполняйте мои 4 команды и проверяйте, что после перезапуска у вас printenv  их выводит
Вот что в printenv после перезапуска:
						Код: Выделить всё
hisilicon # printenv
bootdelay=1
baudrate=115200
ethaddr=00:00:23:34:45:66
ipaddr=192.168.0.10
serverip=192.168.0.2
netmask=255.255.255.0
bootfile="uImage"
bootcmd=showlogo;startvo 0 36 13;sf probe 0;sf read 0x81000000 0xA0000 0x190000;sf read 0x82000000 0x230000 0x1A0000;bootm 0x81000000 0x82000000
bootargs=mem=55M console=ttyAMA0,115200 root=0100 rootfstype=ext2 mtdparts=hi_sfc:640k(boot),1600K(kernel),1664K,2304k,1664k,320k
machine=MBD6004D
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06 (Sep 24 2014 - 11:37:37)
Environment size: 521/65532 bytes
hisilicon #
