Линк мигает но только зеленый
Код: Выделить всё
System startup..........
System startup
U-Boot 2010.06-svn1147 (Sep 06 2018 - 20:01:43)
Check Flash Memory Controller v100 ... Found
SPI Nor(cs 0) ID: 0x20 0x70 0x18
Block:64KB Chip:16MB Name:"XM25QH128AHIG"
CONFIG_CLOSE_SPI_8PIN_4IO = y.
at hifmc100_setTB() mid:0x20,chipsize:0x1000000 <no>.
unlock all.
SPI Nor total size: 16MB
In:    serial
Out:   serial
Err:   serial
USB:   scanning bus for devices... 2 USB Device(s) found
0 Storage Device(s) found
i:0, No usb storage device found!
at higmac_demux() phy_intf:2 [0:mii,1:rmii,2:rgmii];MAC_TXCKOUT_MUX_REG value:0x1 [1,rgmii;2,mii;3,rmii;]
ETH0: PHY(phyaddr=2, rgmii) not link!
ETH1: PHY(phyaddr=3, rgmii) not link!
higmac init fail!
Press CTRL-C to abort autoboot in 2 seconds16384 KiB hi_fmc at 0:0 is now current device
CFG_BOOT_ADDR:0x0 argc 2 argv[0] logoload
### /UbootLogo/ UbootLogoload complete:bytes  oadaddr0x84000000 loaded to 0x9f000000
### /UbootLogo UbootLogoload complete: 59577 bytes loaded to 0x9f000000
jpeg decoding ...
<<addr=0x9f000000, size=0xb85f9, vobuf=0x9f600000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg success.
decode jpeg!
stMaxRect.u32Width:800, stMaxRect.u32Height:600.
HDMI_INFO:DispFmt2HdmiTiming[383] ,Non CEA video timing:16
HDMI_INFO:Hdmi_PixelFreqSearch[127] ,u32Fmt16.
srcAddr 0x82000000, dstAddr 0x81000000
find_squashfs_file: name bin, start_block 0, offset 2608, type 1
find_squashfs_file: name boot, start_block 0, offset 2716, type 1
read inode: name boot, sb 0, of 2716, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 2640, type 2
read inode: name zImage.img, sb 0, of 2640, type 2
XZ-compressed data is corruptxz_wrapper.c[unxz]:94
xz uncompress failed with error code 7
### FS load complete: 2571734 bytes loaded to 0x81000000
Wrong Image Format for bootm command
ERROR: can't get kernel image!
hisilicon # printnv
Unknown command 'printnv' - try 'help'
hisilicon # printenv
bootargs=mem=140M console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=squashfs mtdparts=hi_sfc:320K(boot),3968K(romfs),7040K(usr),1600K(web),2816K(custom),128K(logo),512K(mtd) coherent_pool=2M
bootcmd=sf probe 0;sf read 0x84000000 0xf60000 0x20000;logoload 0x84000000;decjpg;sf read 0x82000000 0x50000 0x500000;squashfsload 82000000;bootm 0x81000000
bootdelay=1
baudrate=115200
ethaddr=00:0b:3f:00:00:01
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.0.0
bootfile="uImage"
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
de=mw.b 0x82000000 ff 1000000;tftp 0x82000000 u-boot.env.bin.img;sf probe 0;flwrite
appSystemLanguage=SimpChinese
appVideoStandard=PAL
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn1147 (Sep 06 2018 - 20:01:43)
jpeg_addr=0x9f000000
jpeg_size=0xb85f9
vobuf=0x9f600000
Environment size: 1507/65532 bytes
hisilicon #
