востановить камеру 83H40P-B
Привет
камера не счелкает при старте и не видится в сети.
При подключении через com
U-Boot 2010.06-svn588 (Jul 22 2017 - 17:22:07)
NAND: Check nand flash controller v610. found
Special NAND id table Version 1.36
Nand ID: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
No NAND device found!!!
0 MiB
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
SPI Nor Enable Quad succeed.
Spi(cs1): Block:64KB Chip:16MB Name:"MX25L128XX"
at hifmc100_setTB() mid:0xc2,chipsize:0x1000000 <NO>
all blocks is unlocked.
envcrc 0x978c8624
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
Press Ctrl+C to stop autoboot
CFG_BOOT_ADDR:0x58080000
### boot load complete: 1992416 bytes loaded to 0x82000000
### SAVE TO 80008000 !
Image Name: linux
Data Size: 1992352 Bytes = 1.9 MiB
Load Address: 80008000
Entry Point: 80008000
load=0x80008000,_bss_end=8088fa00,image_end=801ee6a0,boot_sp=80797540
Loading Kernel Image ... OK
OK
Starting kernel ...
xmtech # printenv
bootcmd=setenv setargs setenv bootargs ${bootargs};run setargs;fload;bootm 0x820 00000
bootdelay=1
baudrate=115200
bootfile="uImage"
mdio_intf=rmii
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwri te
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwr ite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrit e
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwri te
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flw rite
ua=mw.b 0x82000000 ff 1000000;tftp 0x82000000 upall_verify.img;sf probe 0;flwrit e
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 uImage; bootm 0x82000000
ipaddr=192.168.1.10
serverip=192.168.1.107
netmask=255.255.255.0
bootargs=mem=${osmem} console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=cram fs mtdparts=hi_sfc:512K(boot),5M(romfs),6400K(user),1536K(web),1280K(custom),256 K(logo),1280K(mtd)
ethaddr=00:12:17:8f:a2:00
HWID=8043420006d48400
NID=0x0002
muxctl0=0x200f0088
muxval0=0
gpio0=0x96
gpioval0=0
osmem=57M
appSystemLanguage=SimpChinese
appVideoStandard=PAL
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn588 (Jul 22 2017 - 17:22:07)
Environment size: 1470/262140 bytes
что не так?
0 MiB
envcrc 0x978c8624
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
Image Name: linux
OK
Starting kernel ...
xmtech # printenv
bootdelay=1
baudrate=115200
bootfile="uImage"
mdio_intf=rmii
ipaddr=192.168.1.10
NID=0x0002
muxctl0=0x200f0088
muxval0=0
gpio0=0x96
gpioval0=0
osmem=57M
stdin=serial
stdout=serial
stderr=serial
verify=n
что не так?
- Fluffykrsk
Re: востановить камеру 83H40P-B
А что за модель камеры?)) У меня просто на столе такая же походу сейчас лежит с теми же симптомами))). Тоже на модуле стикер 83H40P-B. А сама камера HM-IP400V-VCG50 (2.8-12)
По LAN не видится кстати, линк есть)))). Тоже кофей пью, думаю чего делать. Только разобрал).
Так классика же, почистить jffs, накатить прошивку
- Fluffykrsk
1382
Оно же?
https://yadi.sk/d/b6Ysu3B53aeeHh" onclick="window.open(this.href);return false;
Конфиг стёр через UART не помогло, будем дальше думать. Дампик качнём сейчас с неё....
Оно же?
- Fluffykrsk
Там SPI так мерзко сидит))), прямо под BGA процом и вплотняк к пластиковым фишкам))). Как бы её не перегреть, всю эту историю. Лучше по UART дёргать дамп.... повозится лишний раз.dede писал(а):Так классика же, почистить jffs, накатить прошивку
Какая туда прошивка нужна, кто бы знал)))).
Паять нет смысла, бут живой же.
Это ж ХМ IPG-83H40P-B http://wiki.xm030.cn/index.php/Hi%E6%B5 ... A%E4%B9%89" onclick="window.open(this.href);return false;
- Fluffykrsk
Привычка бэкапитьсяdede писал(а):Паять нет смысла, бут живой же.
UART редко использую в основном от безысходности. Аппаратно сдуть и прилепить потом быстрее. Да и камеры не сильно часто носят.
Спасибо. Запустил. Стрельнул у Sonya на сайте 00014840 прошивку, по блочно влил через UART. Там ещё какие-то 2 лежат 00039840 и B9539840 интересно подойдут они мне или нет. Надо у Sonya спросить.
Я тут новый можно подробней
как почистить?
какую влил чтоб запустилось?
как почистить?
- Fluffykrsk
Я подложил дамп рабочий по прошлой ссылке с фотками. И прошивку для USB подложил.1382 писал(а):Я тут новый можно подробней
как почистить?
А так....
http://www.cctvsp.ru/articles/vosstanov ... os-parolya" onclick="window.open(this.href);return false;
а в каком блоке мак адрес и ID что не затереть?
а как скачать ExIPCam?
все проходит вроде нормально но после reset камера не перезагружаетя сколько подождать
0 MiB
lk[9 => 0x1000000]
envcrc 0x978c8624
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
Image Name: linux
OK
Starting kernel ...
Uncompress........Ok
0 MiB
lk[9 => 0x1000000]
envcrc 0x978c8624
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
xmtech # sf probe 0
xmtech # sf lock 0
unlock all block.
at hisfc350_set_bp_level() Set BP level end,SR.val:0x0.
xmtech # run du
ETH0: PHY(phyaddr=1, rmii) link UP: DUPLEX=FULL : SPEED=100M
MAC: 00-00-23-34-45-66
TFTP from server 192.168.1.107; our IP address is 192.168.1.10
Download Filename 'user-x.cramfs.img'.
Download to address: 0x82000000
Downloading: *
Abort
xmtech # run du
Downloading: #################################################
done
Bytes transferred = 4980800 (4c0040 hex)
PACK_ID error
## Checking Image at 0x82000000 ...
hdr->ih_magic=0x56190527
Header CRC Checking ... OK
Image Name: linux
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 4980736 Bytes = 4.8 MiB
Load Address: 00580000
Entry Point: 00bc0000
Data CRC Checking ... OK
Programing start at: 0x00580000
Programing end at: 0x00bc0000
Erasing at 0xbc0000 -- 100% complete.
done.
Erased sectors.
Saving Image to Flash ...
Writing at 0xbc0000 -- 100% complete.
done.
xmtech # run dc
Download Filename 'custom-x.cramfs.img'.
done
Bytes transferred = 32832 (8040 hex)
PACK_ID error
Image Name: linux
Image Type: ARM Linux Standalone Program (gzip compressed)
Data Size: 32768 Bytes = 32 KiB
Load Address: 00d40000
Entry Point: 00e80000
Programing start at: 0x00d40000
Programing end at: 0x00e80000
Erasing at 0xe80000 -- 100% complete.
done.
Erased sectors.
Writing at 0xe80000 -- 100% complete.
done.
xmtech # run dr
Download Filename 'romfs-x.cramfs.img'.
done
Bytes transferred = 3371072 (337040 hex)
PACK_ID error
Image Name: linux
Data Size: 3371008 Bytes = 3.2 MiB
Load Address: 00080000
Entry Point: 00580000
Programing start at: 0x00080000
Programing end at: 0x00580000
Erasing at 0x580000 -- 100% complete.
done.
Erased sectors.
Writing at 0x580000 -- 100% complete.
done.
xmtech # run dw
Download Filename 'web-x.cramfs.img'.
done
Bytes transferred = 1450048 (162040 hex)
PACK_ID error
Image Name: linux
Data Size: 1449984 Bytes = 1.4 MiB
Load Address: 00bc0000
Entry Point: 00d40000
Programing start at: 0x00bc0000
Programing end at: 0x00d40000
Erasing at 0xd40000 -- 100% complete.
done.
Erased sectors.
Writing at 0xd40000 -- 100% complete.
done.
xmtech # reset
resetting ...
что не так???
0 MiB
lk[9 => 0x1000000]
envcrc 0x978c8624
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
Image Name: linux
OK
Starting kernel ...
0 MiB
lk[9 => 0x1000000]
envcrc 0x978c8624
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
xmtech # sf probe 0
xmtech # sf lock 0
unlock all block.
xmtech # run du
Downloading: *
Abort
xmtech # run du
done
PACK_ID error
Image Name: linux
done.
Erased sectors.
done.
xmtech # run dc
done
PACK_ID error
Image Name: linux
done.
Erased sectors.
done.
xmtech # run dr
done
PACK_ID error
Image Name: linux
done.
Erased sectors.
done.
xmtech # run dw
done
PACK_ID error
Image Name: linux
done.
Erased sectors.
done.
xmtech # reset
resetting ...
что не так???
