multistar model no.9308
aavan
Сообщение aavan » 15 ноя 2018, 08:28
Принесли с повреждением железа,после ремонта попытался слить дамп через tftp,но потерпел фиаско.Как сдампить прошивку с такого рега? :
U-Boot 2008.10-svn57 (Oct 22 2011 - 08:24:10)
DRAM: 256 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
MAC: 00-0C-9F-A0-A4-E5
Press CTRL-C to abort autoboot in u-boot # help
? - alias for 'help'
erase - erase FLASH memory
flinfo - print FLASH memory information
fload - load binary file from a filesystem image for system boot
flwrite - write data into FLASH memory
help - print online help
lip - set local ip address but not save to flash
lload - load logo file
mac - set mac address and save to flash
mii - MII utility commands
protect - enable or disable FLASH write protection
sip - set server ip address but not save to flash
tftp - download or upload image via network using TFTP protocol
xmtest - test the hard ware and output result to LED
u-boot # printenv
bootargs=mem=54M console=ttyAMA0,115200 root=1f01 rootfstype=cramfs mtdparts=physmap-flash.0:192K(boot),2560K(romfs),2944K(usr),1920K(custom),64K(logo),512K(mtd) busclk=220000000
bootcmd=lload;xmtest;fload;bootm 0xC1000000
slave_bootcmd=bootm e0300000 e0a00000
bootdelay=1
baudrate=115200
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.0.0
bootfile="uImage"
da=protect off all;tftp 0xC1000000 u-boot.bin.img;flwrite
du=tftp 0xC1000000 user-x.cramfs.img;flwrite
dr=tftp 0xC1000000 romfs-x.cramfs.img;flwrite
dw=tftp 0xC1000000 web-x.cramfs.img;flwrite
dl=tftp 0xC1000000 logo-x.cramfs.img;flwrite
dc=tftp 0xC1000000 custom-x.cramfs.img;flwrite
up=tftp 0xC1000000 update.img;flwrite
tk=fload;tftp 0xC1000000 zImage.img; bootm 0xC1000000
dd=tftp 0xC1000000 mtd-x.jffs2.img;flwrite
ds=tftp 0xC1000000 slvfs-x.cramfs.img;flwrite
xmerr=ffffff9a
ethaddr=00:0c:9f:a0:a4:e5
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2008.10-svn57 (Oct 22 2011 - 08:24:10)
Environment size: 975/65532 bytes
u-boot #
С уважением Николай.
Re: multistar model no.9308
Сообщение dede » 15 ноя 2018, 08:38
Вы не указали, в чем именно проблема? Даже хелп на тфтп пишет, что он умеет аплоад делать, что тогда не получилось?
aavan
Сообщение aavan » 15 ноя 2018, 11:49
проблема в моей необразованности.Слить дамп могу на программаторе,благо сейчас в основном spi флеши везде.А со старыми аппаратами проблемно.Некоторое время назад,с Вашей помощью слил прошивку с рега с NOR флешью.Там команда cp.b.Регистраторы с SPI тоже знакомы,-командами sf ..,В данном случае,как я понял оперируют da.,du.,dr ...,с этим сталкиваюсь впервые.
Сообщение AlienP666 » 15 ноя 2018, 11:53
aavan писал(а):проблема в моей необразованности.Слить дамп могу на программаторе,благо сейчас в основном spi флеши везде.А со старыми аппаратами проблемно.Некоторое время назад,с Вашей помощью слил прошивку с рега с NOR флешью.Там команда cp.b.Регистраторы с SPI тоже знакомы,-командами sf ..,В данном случае,как я понял оперируют da.,du.,dr ...,с этим сталкиваюсь впервые.
Здесь на форуме много описано как слить дамп, есть даже отдельный мануал, спасибо Sonya, его можете посмотреть здесь http://www.cctvsp.ru/articles/vosstanov ... os-parolya" onclick="window.open(this.href);return false;
