После неудачной прошивки не загружается регистратор. Подключился консольным кабелем, вот полный лог загрузки:
Код: Выделить всё
Bootrom start
Boot from NAND
Starting fastboot ...
System startup
DDRS
Reg Version: v1.1.0
Reg Time: 2015/11/10 14:22:31
Reg Name: hi3798mdmo1a_hi3798mv100_ddr3_1gbyte_16bitx2_4layers_tvt_nand.reg
Relocate Boot to DDR
Jump to DDR
Compressed-boot v1.0.0
Uncompress.......Ok
System startup
Reg Version: v1.1.0
Jump to DDR
Fastboot 3.3.0 (lizihao@ubuntu) (Mar 07 2019 - 18:16:06)
Fastboot: Version 3.3.0
Build Date: Mar 7 2019, 18:16:30
CPU: Hi3798Mv100
Boot Media: NAND
DDR Size: 1GB
Check nand flash controller v610. found
Special NAND id table Version 1.36
Nand ID: 0x98 0xD1 0x90 0x15 0x76 0x14 0x01 0x00
Nand: Toshiba NAND 128MiB 3,3V 8-bit
Nand(HW-Auto): Block:128KB Page:2KB OOB:64B ECC:4bit/512 Chip:128MB*1
Boot Env on NAND
Env Offset: 0x00220000
Env Size: 0x00020000
Env Range: 0x00080000
boot_check_valid-->303, cmdBuf:mw.b 0x3F7FB000 0xFF 0x100000;nand read 0x3F7FB000 0x20000 0x100000
NAND read: device 0 offset 0x20000, size 0x100000
pure data length is 1048576, len_incl_bad is 1048576
request to read 0x100000, and read 0x100000 successfully!
1048576 bytes read: OK
do_start_boot-->338, boot from 0x20000
do_start_boot-->358, cmdBuf:go 0x3F7FB040
## Starting application at 0x3F7FB040 ...
System startup
Reg Version: v1.1.0
Jump to DDR
Uncompress....................Ok
System startup
Reg Version: v1.1.0
Jump to DDR
Fastboot 3.3.0 (lizihao@ubuntu) (Mar 07 2019 - 18:16:49)
Build Date: Mar 7 2019, 18:17:16
CPU: Hi3798Mv100
Boot Media: NAND
DDR Size: 1GB
Boot Env on NAND
HI_OTP_LockIdWord,313: ID_WORD have already been locked
SDK Version: HiSTBLinuxV100R003C00CP0003
keyled repeat init
>> Loading 'kernel' image.
flag:0x50465041, flash value:0xffffffff
check_update_file, 235, name:firmware3798p
USB0: Register 1212 NbrPorts 2
USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
USB1: Register 1111 NbrPorts 1
USB EHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
1 Storage Device(s) found
Interface: USB
Device 0: Vendor: JetFlash Rev: 1100 Prod: Transcend 16GB
Type: Removable Hard Disk
Capacity: 14745.0 MB = 14.3 GB (30197760 x 512)
Partition 1: Filesystem: FAT32 "NO NAME "
Reserve Memory
Start Addr: 0x3FFFE000
Bound Addr: 0x8CF9000
Free Addr: 0x3EB58000
Alloc Block: Addr Size
0x3FBFD000 4194304
0x3F8FC000 3145728
0x3F8F9000 8192
0x3F8C4000 212992
0x3F7C3000 1048576
0x3F7BF000 12288
0x3F4BE000 3145728
0x3F1BD000 3145728
0x3F09C000 1179648
0x3EC9B000 4194304
0x3EB9A000 1048576
0x3EB79000 131072
0x3EB58000 131072
Press Ctrl+C to stop autoboot
NAND read: device 0 offset 0x600000, size 0x700000
pure data length is 7340032, len_incl_bad is 7340032
request to read 0x700000, and read 0x700000 successfully!
7340032 bytes read: OK
## Booting kernel from Legacy Image at 01000000 ...
Image Name: Linux-3.10.0_s40
Data Size: 4574008 Bytes = 4.4 MiB
Load Address: 02000000
Entry Point: 02000000
Verifying Checksum ... OK
ZYFAN bootm_load_os 366, comp:0
Loading Kernel Image ... OK
OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 3.10.0_s40 (zyfan@zyfan-ubuntu) (gcc version 4.4.1 (Hisilicon_v200(gcc4.4-290+glibc-2.11+eabi+nptl)) ) #3 SMP Mon Nov 9 18:24:45 CST 2015
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: bigfish
Ignoring unrecognised tag 0x726d6d73
Ignoring unrecognised tag 0x726d6d74
Ignoring unrecognised tag 0x726d6d76
cma: CMA: reserved 500 MiB at 20000000
cma: CMA: reserved 4 MiB at 3fc00000
Memory policy: ECC disabled, Data cache writealloc
CPU: Hi3798Mv100
PERCPU: Embedded 8 pages/cpu @81152000 s11968 r8192 d12608 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
Kernel command line: mem=1G console=ttyAMA0,115200 root=/dev/romblock3 rootfstype=squashfs mtdparts=hinand:5M(boot),1M(baseparam),7M(kernel),18M(rootfs),64M(appfs),16M(qte),4M(config),12M(log),1M(logo) mmz=ddr,0,0,500M
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1024MB = 1024MB total
Memory: 509724k/509724k available, 538852k reserved, 0K highmem
Virtual kernel memory layout:
vmalloc : 0xc0800000 - 0xff000000 (1000 MB)
lowmem : 0x80000000 - 0xc0000000 (1024 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x80825d00 (8312 kB)
.init : 0x80826000 - 0x80881ec0 ( 368 kB)
.data : 0x80882000 - 0x808d5668 ( 334 kB)
.bss : 0x808d5668 - 0x8094b7f4 ( 473 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:192
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
Calibrating delay loop... 2383.87 BogoMIPS (lpj=1191936)
ftrace: allocating 20605 entries in 61 pages
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x80615278 - 0x806152d0
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated (9572.35 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
DMA: preallocated 256 KiB pool for atomic coherent allocations
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
uart:0: ttyAMA0 at MMIO 0xf8b00000 (irq = 81) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0xf8006000 (irq = 82) is a PL011 rev2
uart:2: ttyAMA2 at MMIO 0xf8b02000 (irq = 83) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Linux video capture interface: v2.00
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switching to clocksource timer3
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
CPU PMU: probing PMU on CPU 0
hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 2003
io scheduler noop registered
io scheduler cfq registered
brd: module loaded
loop: module loaded
Found Nand Flash Controller V610.
9 cmdlinepart partitions found on MTD device hinand
Creating 9 MTD partitions on "hinand":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000600000 : "baseparam"
0x000000600000-0x000000d00000 : "kernel"
0x000000d00000-0x000001f00000 : "rootfs"
0x000001f00000-0x000005f00000 : "appfs"
0x000005f00000-0x000006f00000 : "qte"
0x000006f00000-0x000007300000 : "config"
0x000007300000-0x000007f00000 : "log"
0x000007f00000-0x000008000000 : "logo"
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver pl2303
usbserial: USB Serial support registered for pl2303
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
usbcore: registered new interface driver btusb
hi_mci1: eMMC/MMC/SD Device NOT detected!
hi_mci0: eMMC/MMC/SD Device NOT detected!
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
oprofile: using timer interrupt.
Netfilter messages via NETLINK v0.30.
nfnl_acct: registering with nfnetlink.
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP: cubic registered
NET: Registered protocol family 10
Bridge firewalling registered
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
ALSA device list:
No soundcards found.
VFS: Mounted root (squashfs filesystem) readonly on device 240:3.
Freeing unused kernel memory: 364K (80826000 - 80881000)
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
Not find ldconfig
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S80network
UBI: attaching mtd4 to ubi0
root login: UBI: scanning is finished
UBI: attached mtd4 (name "appfs", size 64 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 512, bad PEBs: 0, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 4/1, WL threshold: 128, image sequence number: 250653281
UBI: available PEBs: 0, total reserved PEBs: 512, PEBs reserved for bad PEB handling: 20
UBI: background thread "ubi_bgt0d" started, PID 873
UBI device number 0, total 512 LEBs (65011712 bytes, 62.UBIFS: background thread "ubifs_bgt0_0" started, PID 876
0 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "ubifs"(null)
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 60567552 bytes (57 MiB, 477 LEBs), journal size 8634368 bytes (8 MiB, 68 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 00000000-0000-0008-0000-000000000001, small LPT model
UBI: attaching mtd5 to ubi1
UBI: attached mtd5 (name "qte", size 16 MiB) to ubi1
UBI: good PEBs: 128, bad PEBs: 0, corrupted PEBs: 0
UBI: max/mean erase counter: 11/3, WL threshold: 128, image sequence number: 213522928
UBI: available PEBs: 0, total reserved PEBs: 128, PEBs reserved for bad PEB handling: 20
UBI: background thread "ubi_bgt1d" started, PID 882
UBI device number 1, total 128 LEBs (16252928 bytes, 15.UBIFS: background thread "ubifs_bgt1_0" started, PID 885
5 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: mounted UBI device 1, volume 0, name "ubifs"(null)
UBIFS: FS size: 11935744 bytes (11 MiB, 94 LEBs), journal size 2412544 bytes (2 MiB, 19 LEBs)
now start mount block
yaffs: dev is 32505862 name is "mtdblock6" rw
yaffs: passed flags ""
yaffs: dev is 32505863 name is "mtdblock7" rw
UBIFS: un-mount UBI device 1, volume 0
UBIFS: background thread "ubifs_bgt1_0" stops
OR_clientConfig.xml nothing to do
OR_configVersionInfo.xml nothing to do
OR_runParameter.xml nothing to do
OR_systemInfo.xml nothing to do
diff: can't stat '/mnt/mtd/default/OR_funcpane.xml': No such file or directory
cp: can't stat '/mnt/mtd/default/OR_funcpane.xml': No such file or directory
cp: can't create '/etc/resolv.conf': File exists
Load hi_media.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Sep 25 2015, 15:12:02])
Load hi_mmz.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Sep 25 2015, 15:12:02])
Load hi_common.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Sep 25 2015, 15:11:58])
[WDG_DRV_ModInit][560], default parameters, index:0, enable:1, margin:120
Load hi_wdg.ko success (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Sep 5 2016, 14:24:03])
Load hi_gpio.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:43:57])
HI_DRV_GPIOI2C_Init OK(g_I2cNum=0, SCL=gpio No.0, SDA=gpio No.0).
HI_DRV_GPIOI2C_Init OK(g_I2cNum=3, SCL=gpio No.49, SDA=gpio No.50).
Load hi_gpioi2c.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Aug 13 2015, 13:58:30])
Load hi_i2c.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:44:59])
Mali: Mali device driver loaded
Load hi_tde.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:44:48])
DieID is locked!
Load hi_otp.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:45:16])
Load hi_demux.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:45:04])
Load hi_adec.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:45:49])
Load hi_vfmw.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Apr 14 2016, 09:35:09])
Load hi_svdec.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:48:12])
[00:00:03:589 ERROR-HI_PQ]:DRV_PQ_GetFlashPqBin[2611]:PQ bin param may not burned
[00:00:03:596 ERROR-HI_PQ]:HI_DRV_PQ_Init[225]:Load PQBin failed!
Load hi_pq.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Apr 19 2016, 11:20:24])
Load hi_vpss.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Apr 15 2017, 02:45:01])
Load hi_vdec.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Apr 5 2017, 11:27:20])
Load hi_cipher.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:45:14])
Load hi_hdmi.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Aug 17 2016, 14:50:13])
Load hi_adsp.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:45:32])
Load hi_aiao.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 25 2015, 17:33:55])
Load hi_vou.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Mar 22 2017, 14:40:33])
Load hi_pvr.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:49:05])
Load hi_fb.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:44:43])
Load hi_ir.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:43:59])
Load hi_jpegdec.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:44:56])
Load hi_jpegenc.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:49:03])
Load hi_png.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:48:46])
Load hi_venc.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Apr 14 2016, 09:29:32])
Load hi_aenc.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:49:29])
Load hi_keyled.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:49:25])
Load hi_vi.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:49:40])
enter temperature_control_thread
Load hi_pmoc.ko success. (SDK_VERSION:[HiSTBLinuxV100R003C00SPC060] Build Time:[Dec 11 2015, 16:48:56])
hiusb-ehci hiusb-ehci.0: irq 98, io mem 0xf9890000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hiusb-ehci hiusb-ehci.1: HIUSB EHCI
hiusb-ehci hiusb-ehci.1: new USB bus registered, assigned bus number 2
hiusb-ehci hiusb-ehci.1: irq 94, io mem 0xf9930000
hiusb-ehci hiusb-ehci.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 3
hiusb-ohci hiusb-ohci.0: irq 99, io mem 0xf9880000
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.1: HIUSB OHCI
hiusb-ohci hiusb-ohci.1: new USB bus registered, assigned bus number 4
hiusb-ohci hiusb-ohci.1: irq 95, io mem 0xf9920000
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
[00:00:04:517 ERROR-HI_HDMI]:SI_TimerHandler[509]:Read EDID Fail.Read 6 times
usb 1-2: new high-speed USB device number 2 using hiusb-ehci
usb-storage 1-2:1.0: USB Mass Storage device detected
scsi0 : usb-storage 1-2:1.0
---HDMI kernel event(no UserCallBack): HOTPLUG. ---
hiusb-xhci hiusb-xhci.0: xHCI Host Controller
hiusb-xhci hiusb-xhci.0: new USB bus registered, assigned bus number 5
hiusb-xhci hiusb-xhci.0: irq 101, io mem 0xf98a0000
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
hiusb-xhci hiusb-xhci.0: new USB bus registered, assigned bus number 6
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
tntfs: module license 'Commercial. For support email ntfs-support@tuxera.com.' taints kernel.
Tuxera NTFS driver 3014.6.29 [Flags: R/W MODULE].
keybaord 3798m gpio init version : Aug 13 2015 14:19:00
[RTC]g_chip_type = 0
[PT4307]HI_DRV_GPIOI2C_CreateGpioI2c OK(g_I2cNum=3, SCL=gpio No.49, SDA=gpio No.50).
[RTC]pt4307 init Success!
version - chips : 201512280940+->xxxchips
TVT hi3798m CryptoMemory Device Driver v1.0.0: Dec 28 2015 18:22:50
[RT5616]HI_DRV_GPIOI2C_CreateGpioI2c OK(g_I2cNum=3, SCL=gpio No.49, SDA=gpio No.50).
[RT5616]Find Rt5616! Initial now!... ...
usb 6-1: new SuperSpeed USB device number 2 using hiusb-xhci
usb 6-1: Parent hub missing LPM exit latency info. Power management will be impacted.
usb-storage 6-1:1.0: USB Mass Storage device detected
scsi1 : usb-storage 6-1:1.0
[RT5616]Rt5616 Version:2015-8-13
libphy: himii: probed
scsi 0:0:0:0: Direct-Access JetFlash Transcend 16GB 1100 PQ: 0 ANSI: 6
sd 0:0:0:0: [sda] 30197760 512-byte logical blocks: (15.4 GB/14.3 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
udisk1210 -> /dev/sda
udisk1210p1 -> /dev/sda1
Up port phy at 0x01 is connect
libphy: PHY himii:1f not found
hieth_init ok version is 201512161630 rx cnt:1
netpnp init ok version : 201603021130
Setup mv88e6071 SWITCH...
smi_i2c_init ok
smi_i2c_phy_init ok
---the id 1 value:2000
smiRead failed i:1
the mv88e6071 chip cnt is 1
Setup mv88e6071 SWITCH OK
Register mv88e6071_phy_ops successfully 201708101600.
scsi 1:0:0:0: Direct-Access ASMT 2115 0 PQ: 0 ANSI: 6
sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
sd 1:0:0:0: [sdb] Write Protect is off
sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sdb: unknown partition table
sd 1:0:0:0: [sdb] Attached SCSI disk
udisk6110 -> /dev/sdb
[AppPackInfo]
softwareVersion=1.2.9.0
launchDate=20180530.0905
productInfo=3798M_POE
pkgId=
srcPkgDate=20180530.0905
branchVersion=0
productName=N0K
UILayout=UI1-X
UIStyle=UI1-A
pkgType=1290_prerelease
pkgFlag=4A414
pkgBatch=V
pkgOrder=0
pkgTimes=0
realSrcDate=20180602.1237
extInfo=058,Revision17279
This is PrepareUpgradeTo13X
modprobe: chdir(/lib/modules): No such file or directory
cat: can't open '/etc/init.d/mac.dat': No such file or directory
current flash param ==
------get 1------current param type == 130080, lenth:32, ver_type:1
data = 00:18:AE:7D:F4:99, type = 4065
IPv6: ADDRCONF(NETDEV_UP): phyeth0: link is not ready
mount: mounting none on /proc/bus/usb failed: No such file or directory
/mnt/mtd/dep2.sh: line 29: can't create /proc/irq//smp_affinity: nonexistent directory
argc = 2
[RTC_RD_TIME]
Current time value:
2021-3-2 5:9:36
Wait_HDIntoOS done.
Wait_DumpDiskIntoOS done.
appDaemon is ready..., pid=1321
update open close fb ++++++++++++++
1111 current set fb width 1280, height 1024, pstFrameBufParam->buf_number=2
xres_virtual = 1280, yres_virtual = 2048, xres = 1280, yres = 1024, pixel_fmt_size = 16, xoffset = 0, yoffset = 0
fb width 1280, height 1024, len 5242880, 2560
[1322@A#R@02-08:09:36]VAC_FBInitForUpdate ret=0[main.cpp:48]
[1322@A#R@02-08:09:36]nRet=18,_Dsize=38, [FrameBufferCtrl.cpp:884]
[1322@A#R@02-08:09:36]config part is /dev/mtdblock6, fs=yaffs2[Upgrade_1_0_X.cpp:112]
[1322@A#R@02-08:09:36]get UI=1A, sPfType=N0K[Upgrade_1_0_X.cpp:181]
[1322@A#R@02-08:09:36]=========== find /mnt/nfs/factoryConfig/OR_factoryConfig.xml ==============[Upgrade_1_0_X.cpp:329]
[1322@A#R@02-08:09:36]get customerID=25[Upgrade_1_0_X.cpp:337]
[1322@A#R@02-08:09:36]get byCustomModel=LTV-RNE-040-0G[Upgrade_1_0_X.cpp:342]
[1322@A#R@02-08:09:36]get byModel=TD-3204H1-4P, TVTproduct=TD_3204H1_4P[Upgrade_1_0_X.cpp:369]
[1322@A#R@02-08:09:36]get byPanelType=Q23[Upgrade_1_0_X.cpp:382]
[1322@A#R@02-08:09:36]get bySN=NF49902B44CP[Upgrade_1_0_X.cpp:387]
[1322@A#R@02-08:09:36]=========== find /mnt/nfs/factoryConfig/OR_volatileFactoryConfig.xml ==============[Upgrade_1_0_X.cpp:428]
<?xml version="1.0" encoding="UTF-8"?>
<factoryConfig>
<factoryParam>
<videoFormat>PAL</videoFormat>
<timeZone>MSK-3</timeZone>
<resolution type="resolution">
<item scale="false" index="0">1920x1080</item>
</resolution>
<languageCode>0x0419</languageCode>
<customerID id="025">RU32</customerID>
<deviceName>Device Name</deviceName>
</factoryParam>
</factoryConfig>
[1322@A#R@02-08:09:36]get videoFormat=PAL, byVideoFormat=1[Upgrade_1_0_X.cpp:438]
[1322@A#R@02-08:09:36]get byTimezone=MSK-3[Upgrade_1_0_X.cpp:443]
[1322@A#R@02-08:09:36]get byFactoryLanguage=0x0419[Upgrade_1_0_X.cpp:448]
[1322@A#R@02-08:09:36]get dwCustomID=25[Upgrade_1_0_X.cpp:454]
[1322@A#R@02-08:09:36]FillProductInfo tip:The customerID(25) not support in 1.3!, ret=0[main.cpp:64]
[1322@A#R@02-08:09:36]nRet=38,_Dsize=78, [FrameBufferCtrl.cpp:884]
libphy: himii:01 - Link is Down
libphy: himii:01 - Link is Up - 100/Full
IPv6: ADDRCONF(NETDEV_CHANGE): phyeth0: link becomes ready
Дальше загрузка не идёт, через пару минут сам перезагружается и всё по новой.
Вывод printenv:
Код: Выделить всё
fastboot# printenv
bootdelay=1
baudrate=115200
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.255.0
bootfile="uImage"
bootargs_2G=mem=2G mmz=ddr,0,0,600M
update_force=1
gatewayip=192.168.4.1
ethaddr=A6:89:0D:90:65:29
update_force_boot=0
update_force_others=0
bootargs_1G=mem=1G mmz=ddr,0,0,500M
updated_appfs_special_flag=1
stdin=serial
stdout=serial
stderr=serial
bootargs=mem=1G console=ttyAMA0,115200 root=/dev/romblock3 rootfstype=squashfs mtdparts=hinand:5M(boot),1M(baseparam),7M(kernel),18M(rootfs),64M(appfs),16M(qte),4M(config),12M(log),1M(logo)
bootcmd=nand read 0x1000000 0x600000 0x700000;bootm 0x1000000
bootargs_512M=mem=512M mmz=ddr,0,0,328M
ver=Fastboot 3.3.0 (lizihao@ubuntu) (Mar 07 2019 - 18:16:49)
Environment size: 709/131068 bytesКод: Выделить всё
fastboot# help
? - alias for 'help'
clear_bootf- clear Hibernate!! bootflag
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
ddr - ddr training function
hibernate- Hibernate!! boot
md - memory display
mii - MII utility commands
mw - memory write (fill)
nand - NAND sub-system
nboot - boot from NAND device
otp_burntoecurechipset- Burn to secure chipset, please be careful !!!
otp_getcustomerkey- otp_getcustomerkey
otp_getstbprivdata- otp_getstbprivdata
otp_setstbprivdata- StbPrivData
otpreadall- read otp ,for example otpreadall
otpwrite- write otp ,for example otpwrite adddress value
unzip - unzip a memory region
uploadx - upload binary file over serial line (xmodem mode)
usb - USB sub-system
usbburn - burn file from USB device
version - print monitor versionКод: Выделить всё
setenv auversion0
setenv auversion1
setenv auversion2
setenv auversion3
setenv auversion4
setenv auversion5
setenv auversion6
saveenv
resetКод: Выделить всё
ubt3798
rfs3798
krn3798
fastboot.bin
baseparam3798
appfs3798
