Доброго всем дня. Регистратор(модель на фото во вложении) постоянно перезагружается. Куда копать?
лог загрузки:
U-Boot 2008.10 (Jun 29 2010 - 22:30:03)
DRAM: 128 MB
In: serial
Out: serial
Err: serial
MAC: 36-81-33-A9-89-26
Press CTRL-C to abort autoboot in 1 seconds## Booting kernel from Legacy Image at e2a00000 ...
Image Name: Linux-2.6.24-rt1-hi3520v100
Data Size: 1417160 Bytes = 1.4 MB
Load Address: e2800000
Entry Point: e2800000
## Loading init Ramdisk from Legacy Image at e3000000 ...
Image Name: initrd in cramfs
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 3571712 Bytes = 3.4 MB
Load Address: 00000000
Entry Point: 00000000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.......................................................................................... done, booting the kernel.
Linux version 2.6.24-rt1-hi3520v100 (pub@BVT-SDK-63) (gcc version 3.4.3 (release) (CodeSourcery ARM Q3cvs 2004)) #1 Tue Jun 29 22:33:30 CST 2010
CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387f
Machine: hi3520v100
CPU0: D VIPT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line: mem=32M console=ttyAMA0,115200 mac=36:81:33:A9:89:26
PID hash table entries: 128 (order: 7, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 32MB = 32MB total
Memory: 25960KB available (2580K code, 238K data, 100K init)
HI_VERSION=LINUX_2_6_24-M01C04FB01F @Hi3520v100R001_C_0_2_0 2010-06-29 22:31:34
net_namespace: 64 bytes
Hisilicon clock system V0.01
pci clk devider is out of range:0~3!
SCSI subsystem initialized
Time: hisi_timer1 clocksource has been installed.
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
checking if image is initramfs...it isn't (bad gzip magic numbers); looks like an initrd
Freeing initrd memory: 3488K
JFFS2 version 2.2. (NAND) A© 2001-2006 Red Hat, Inc.
yaffs Jun 29 2010 22:33:15 Installing.
io scheduler noop registered
uart:0: ttyAMA0 at MMIO 0x20090000 (irq = 12) is a AMBA/PL011
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x200a0000 (irq = 12) is a AMBA/PL011
RAMDISK driver initialized: 4 RAM disks of 16384K size 4096 blocksize
loop: module loaded
physmap platform flash device: 04000000 at 80000000
physmap-flash physmap-flash.0: map_probe failed
No NAND device found!!!
h2v100-ehci h2v100-ehci.0: h2v100-ehci
h2v100-ehci h2v100-ehci.0: new USB bus registered, assigned bus number 1
h2v100-ehci h2v100-ehci.0: irq 23, io mem 0x100b0000
h2v100-ehci h2v100-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
h2v100-ohci h2v100-ohci.0: h2v100-ohci
h2v100-ohci h2v100-ohci.0: new USB bus registered, assigned bus number 2
h2v100-ohci h2v100-ohci.0: irq 22, io mem 0x100a0000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
TCP cubic registered
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 3488KiB [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/done.
VFS: Mounted root (cramfs filesystem) readonly.
init started: BusyBox v1.1.2 (2010.06.29-14:29+0000) multi-call binary
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S80network
HISI_PCI-MF @Hi3520v100R001_C_0_2_0 2010-06-29 22:34:31
hi3520_pci_driver.c: v0.0
is_host 0
@@@@,slot num:0
share memory: phys addr (c0000000), size(800000)
************************ load pci trans ok ********************************
base 0xc3000000 end 0xc3800000
hal_dev->slot = 0
local id = 1
PCI: slot 1
PCI: host communicate hw layer setup!
************************ load pci mcc ok ********************************
*** Board tools : ver0.0.1_20060106 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x20110104: 0x00009876 --> 0x00009654
0x20110100: 0x00000888 --> 0x00000886
0x2011010c: 0x00000001 --> 0x00000002
0x20110110: 0x00000002 --> 0x00000006
0x20110114: 0x00000003 --> 0x00000007
0x20110118: 0x00000005 --> 0x00000006
0x2011011c: 0x00000006 --> 0x00000007
0x20110128: 0x00000007 --> 0x00010020
0x2011012c: 0x00000007 --> 0x000103A1
0x20110130: 0x00000007 --> 0x00000005
0x20110134: 0x00000007 --> 0x00000005
0x20110138: 0x00000007 --> 0x00000004
0x2011013c: 0x00000007 --> 0x00000004
0x20050078: 0x00000000 --> 0x00008002
0x20120100: 0x00000444 --> 0x00000444
0x20120104: 0x00009876 --> 0x00009654
0x2012010c: 0x00000001 --> 0x00010640
0x20120110: 0x00000002 --> 0x00000003
0x20120114: 0x00000003 --> 0x00000004
0x20120118: 0x00000005 --> 0x00000001
0x2012011c: 0x00000006 --> 0x00000002
[debug]: {sourcHisilicon Media Memory Zone Manager
0x20120128: 0x00000007 --> 0x00000005
0x2012012c: 0x00000007 --> 0x00000005
0x20120130: 0x00000007 --> 0x00000005
0x20120134: 0x00000007 --> 0x00000005
0x20120138: 0x00000007 --> 0x00000005
0x2012013c: 0x00000007 --> 0x00000005
[ipcm_vdd_init, 422]: local_cpu_id = 36
[ipcm_vdd_close, 268]: handle 0xc1e16a40
[ipcm_vdd_init, 455]: IPCM hardware initialized successfully 0
Software Watchdog Timer: 0.07 initialized. soft_noboot=0 soft_margin=60 sec (nowayout= 0)
hifb: module license 'Proprietary' taints kernel.
hifb info: HIFB_MAIN_VERSION[v1.0.0.2] Build Time[Jun 29 2010, 23:55:55]
hifb info: video:vram0_size=4000000,vram1_size=2000000,vram2_size=2000000,vram3_size=2000000,vram4_size=2000000
hifb info: succeed in registering the fb0: ovl0 frame buffer device
hifb info: succeed in registering the fb1: ovl1 frame buffer device
hifb info: succeed in registering the fb2: ovl2 frame buffer device
hifb info: succeed in registering the fb3: ovl3 frame buffer device
hifb info: succeed in registering the fb4: ovl4 frame buffer device
TDE_MAIN_VERSION[v2.0.0.0] Build Time[Jun 29 2010, 23:55:58]
TDE_ADP_VERSION[hi3520adp v2.0.0.0] Build Time[Jun 29 2010, 23:55:58]
tde run on master arm
tde run for graphic service
tde map reg:basePhyAddr:20140000 baseVirAddr:c2878000 size:3000
Chip Version: Hi35200100
load vd.ko ....OK!
load simd.ko OK
load vdec.ko ....OK
load vpp.ko ....OK!
load md.ko....OK!
************************ load hi3520 mpp ok ********************************
subscribe event 5
Auto login as root ...
Jan 1 00:00:03 login[398]: root login on `ttyS000'
BusyBox v1.1.2 (2010.06.29-14:29+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
[1;32mWelcome to HiLinux.[0;39m
None of nfsroot found in cmdline.
receive doorbell 5 from host ok [ IPCM_Check, 222]: remote not ready, now connect and wait ...
receive pid >>>>>> (22311)
*ProductType = PROD_D8416 *
**********************************************[ IPCM_Check, 252]: remote connected
Product: 22113 CapVer: Mar 6 2012 09:54:31
MPP Init..............
pci local id is 1
PCIV_WaitConnect....
open msg dev ok, fd:19
start check pci target id:0 ... ... ...
have checked pci target id:0 ok !
PF AHB address:0xc0000000
<<<<<<<<<<<<Processing PCIV Slave Message>>>>>>>>>>>>>>
<<<<<<<<<<<<Lexus King is now Testing!!!!>>>>>>>>>>>>>>
Recv Message : SYS
slave set time successful...
Recv Message : SYS
watchdog timeout enabled
watchdog timeout was set to 10 seconds
watchdog port was set to 238
Recv Message : VIDEO
VI_Create() OK MaxChn (8) ...............
VO_CascadeCreateDev(vodev=0, s32Pos = 0 &&&&&&&&&&&&&&&&
VO_Create(0) VoChn(9)==============================>
Slave 2 chip Video is running ...
VI_SetUserPic, u32PhyAddr ===============> 0xc528a000 ..
length = 506880
MPP_MapMemory: phyaddr = 0xc528a000, length = 506880, virAddr = 0x400a5000 !!!
VI_SetUserPic, pVirAddr ===============> 0x400a5000 ..
PCIV_SlaveBlindCreate
Recv Message : CAPTURE
PCIV_SlaveCaptureCreate ......
open 142.............
open 174.............
PCIV_Trans_InitSender ok, handle:0x1470e8, remote:0, dma_buf:0xc8ce2000,len:3145728; tmp_buf:(0xc811e000,0x40121000), msgport:(174,142)
open 143.............
open 175.............
PCIV_Trans_InitSender ok, handle:0x147130, remote:0, dma_buf:0xc8fe2800,len:3145728; tmp_buf:(0xc841e800,0x40421800), msgport:(175,143)
open 144.............
open 176.............
PCIV_Trans_InitSender ok, handle:0x147178, remote:0, dma_buf:0xc92e3000,len:3145728; tmp_buf:(0xc871f000,0x40722000), msgport:(176,144)
open 145.............
open 177.............
PCIV_Trans_InitSender ok, handle:0x1471c0, remote:0, dma_buf:0xc95e3800,len:3145728; tmp_buf:(0xc8a1f800,0x40a22800), msgport:(177,145)
open 146.............
open 178.............
PCIV_Trans_InitSender ok, handle:0x147208, remote:0, dma_buf:0xc98e4000,len:3145728; tmp_buf:(0xc8d20000,0x40d23000), msgport:(178,146)
open 147.............
open 179.............
PCIV_Trans_InitSender ok, handle:0x147250, remote:0, dma_buf:0xc9be4800,len:3145728; tmp_buf:(0xc9020800,0x41023800), msgport:(179,147)
open 148.............
open 180.............
PCIV_Trans_InitSender ok, handle:0x147298, remote:0, dma_buf:0xc9ee5000,len:3145728; tmp_buf:(0xc9321000,0x41324000), msgport:(180,148)
open 149.............
open 181.............
PCIV_Trans_InitSender ok, handle:0x1472e0, remote:0, dma_buf:0xca1e5800,len:3145728; tmp_buf:(0xc9621800,0x41624800), msgport:(181,149)
CaptureCreate(0) ok.
CaptureCreate(1) ok.
CaptureCreate(2) ok.
CaptureCreate(3) ok.
CaptureCreate(4) ok.
CaptureCreate(5) ok.
CaptureCreate(6) ok.
CaptureCreate(7) ok.
Recv Message : SYS
Pciv_SlaveSysInitWinVb ....
Recv Message : SYS
PF AHB addr:0xc0000000
func:PCIV_SlaveSysMalloc, phyaddr:0x168000 = 0xc0168000 - 0xc0000000
Recv Message : PLAY
STREAM_Proc pid = 424.......
VDEC_BindToVo(0, VO_DEV_HD, 9);PCIV_Trans_InitReceiver ok, remote:0, addr:(0xc0168000,0x41b22000), buflen:262144, msgport:(222,206)
Recv Message : SYS
func:PCIV_SlaveSysMalloc, phyaddr:0x1a8000 = 0xc01a8000 - 0xc0000000
Recv Message : PLAY
STREAM_Proc pid = 428.......
VDEC_BindToVo(1, VO_DEV_HD, 10);PCIV_Trans_InitReceiver ok, remote:0, addr:(0xc01a8000,0x41cf7000), buflen:262144, msgport:(223,207)
Recv Message : SYS
func:PCIV_SlaveSysMalloc, phyaddr:0x1e8000 = 0xc01e8000 - 0xc0000000
Recv Message : PLAY
STREAM_Proc pid = 432.......
VDEC_BindToVo(2, VO_DEV_HD, 11);PCIV_Trans_InitReceiver ok, remote:0, addr:(0xc01e8000,0x41ecc000), buflen:262144, msgport:(224,208)
Recv Message : SYS
func:PCIV_SlaveSysMalloc, phyaddr:0x228000 = 0xc0228000 - 0xc0000000
Recv Message : PLAY
STREAM_Proc pid = 436.......
VDEC_BindToVo(3, VO_DEV_HD, 12);PCIV_Trans_InitReceiver ok, remote:0, addr:(0xc0228000,0x420a1000), buflen:262144, msgport:(225,209)
Recv Message : AUDIO
Recv Message : PLAY
Recv Message : PLAY
Recv Message : PLAY
Recv Message : PLAY
Recv Message : SPLIT
set VO Chn 0 attribute(0,0,1280,720) ok ! 0
PCIV_SlaveCaptureSetTimeFormat ......
PCIV_SlaveCaptureSetFormat ......
CaptureSetFormat(0, 0, 4, 0) ......
pFormat->FramesPerSecond = 25 pFormat->CodeSize = 1638
CaptureSetFormat(0, 1, 4, 4) ......
pFormat->FramesPerSecond = 25 pFormat->CodeSize = 217
CaptureSetFormat(1, 0, 4, 0) ......
CaptureSetFormat(1, 1, 4, 4) ......
CaptureSetFormat(2, 0, 4, 0) ......
CaptureSetFormat(2, 1, 4, 4) ......
CaptureSetFormat(3, 0, 4, 0) ......
CaptureSetFormat(3, 1, 4, 4) ......
CaptureSetFormat(4, 0, 4, 0) ......
CaptureSetFormat(4, 1, 4, 4) ......
CaptureSetFormat(5, 0, 4, 0) ......
CaptureSetFormat(5, 1, 4, 4) ......
CaptureSetFormat(6, 0, 4, 0) ......
CaptureSetFormat(6, 1, 4, 4) ......
CaptureSetFormat(7, 0, 4, 0) ......
CaptureSetFormat(7, 1, 4, 4) ......
PCIV_SlaveCaptureSetCover ......
CaptureSetTitle ============================>
chanel = 0, idx=1, x=0, y=264, w=56, h=24, bmp=0xbddff83c, enable=1
chanel = 1, idx=1, x=0, y=264, w=56, h=24, bmp=0xbddff83c, enable=1
chanel = 2, idx=1, x=0, y=264, w=56, h=24, bmp=0xbddff83c, enable=1
chanel = 3, idx=1, x=0, y=264, w=56, h=24, bmp=0xbddff83c, enable=1
chanel = 4, idx=1, x=0, y=264, w=56, h=24, bmp=0xbddff83c, enable=1
chanel = 5, idx=1, x=0, y=264, w=56, h=24, bmp=0xbddff83c, enable=1
chanel = 6, idx=1, x=0, y=264, w=56, h=24, bmp=0xbddff83c, enable=1
chanel = 7, idx=1, x=0, y=264, w=56, h=24, bmp=0xbddff83c, enable=1
SoftDog: Initiating system reboot. <-- В этом месте постоянный перезапуск
DVR 1916D Перезагрузка во время запуска
