лог загрузки китайца
Код: Выделить всё
U-Boot 2010.06 (May 14 2019 - 11:25:22)
DRAM: 128 MiB
SF: Got idcode c2 20 18 c2 20
status register: 0x40
spi_flash_probe_macronix multi wire open flag is 103
spic use FH_SPIC_DUAL_READ && 3bytes mode
In: serial
Out: serial
Err: serial
MMC: FH_MMC: 0
MMC FLASH INIT: No card on slot!
Net: set to RMII
FH EMAC
16384 KiB MX25L12805D at 0:0 is now current device
## Booting kernel from Legacy Image at a1000000 ...
Image Name: Linux-3.0.8
Created: 2019-06-19 1:46:42 UTC
Data Size: 3126700 Bytes = 3 MiB
Load Address: a0008000
Entry Point: a0008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
prepare atags
Starting kernel ...
[ 0.000000] Linux version 3.0.8 (jacky@ubuntu) (gcc version 4.3.2 (crosstool-NG 1.19.0) ) #1 Wed Jun 19 09:46:40 CST 2019
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: FH8852
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 11430
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/ram0 mem=45M mtdparts=spi_flash:256k(bootstrap),64k(uboot-env),256k(uboot),3584k(kernel),10M(app),1536k(var),448K(param)
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 45MB = 45MB total
[ 0.000000] Memory: 40480k/40480k available, 5600k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xc3000000 - 0xfe000000 ( 944 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2d00000 ( 45 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0134000 (1200 kB)
[ 0.000000] .text : 0xc0134000 - 0xc04c1000 (3636 kB)
[ 0.000000] .data : 0xc04c2000 - 0xc04e2920 ( 131 kB)
[ 0.000000] .bss : 0xc04e2944 - 0xc05001c4 ( 119 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:128
[ 0.000000] timer mult: 0xfa000000, timer shift: 0x16
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [ttyS0] enabled
[ 0.177334] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.240035] pid_max: default: 32768 minimum: 301
[ 0.244636] Mount-cache hash table entries: 512
[ 0.249386] CPU: Testing write buffer coherency: ok
[ 0.254548] devtmpfs: initialized
[ 0.259716] NET: Registered protocol family 16
[ 0.264310] FH8856 board init
[ 0.292850] bio: create slab <bio-0> at 0
[ 0.296839] fh_dmac fh_dmac.0: FH DMA Controller, 6 channels
[ 0.304777] cfg80211: Calling CRDA to update world regulatory domain
[ 0.310525] Switching to clocksource fh_clocksource
[ 0.320101] Switched to NOHz mode on CPU #0
[ 0.351008] NET: Registered protocol family 2
[ 0.352672] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.359717] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.366468] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.372686] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.378978] TCP reno registered
[ 0.382081] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.387906] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.394397] NET: Registered protocol family 1
[ 0.398868] RPC: Registered named UNIX socket transport module.
[ 0.404320] RPC: Registered udp transport module.
[ 0.408936] RPC: Registered tcp transport module.
[ 0.413593] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.839452] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.860576] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.873156] msgmni has been set to 79
[ 0.883196] NET: Registered protocol family 38
[ 0.884880] io scheduler noop registered (default)
[ 0.899077] fh_pwm_probe: clk_rate: 50000000
[ 0.904811] PWM driver, Number: 8, IO base addr: 0xc3068000
[ 0.916346] ttyS.0: ttyS0 at MMIO 0xf0700000 (irq = 30) is a ttyS
[ 0.923760] ttyS.1: ttyS1 at MMIO 0xf0800000 (irq = 31) is a ttyS
[ 0.945748] brd: module loaded
[ 0.979358] CLK misc driver init successfully
[ 1.012806] m25p80 spi0.0: found mx25l12805d, expected m25p80
[ 1.019884] m25p80 spi0.0: mx25l12805d (16384 Kbytes)
[ 1.022293] DEBUG-CMDLINE-PART: parsing <256k(bootstrap),64k(uboot-env),256k(uboot),3584k(kernel),10M(app),1536k(var),448K(param)>
[ 1.035156] DEBUG-CMDLINE-PART: partition 6: name <param>, offset ffffffff, size 70000, mask flags 0
[ 1.045098] DEBUG-CMDLINE-PART: partition 5: name <var>, offset ffffffff, size 180000, mask flags 0
[ 1.055004] DEBUG-CMDLINE-PART: partition 4: name <app>, offset ffffffff, size a00000, mask flags 0
[ 1.064890] DEBUG-CMDLINE-PART: partition 3: name <kernel>, offset ffffffff, size 380000, mask flags 0
[ 1.075036] DEBUG-CMDLINE-PART: partition 2: name <uboot>, offset ffffffff, size 40000, mask flags 0
[ 1.085036] DEBUG-CMDLINE-PART: partition 1: name <uboot-env>, offset ffffffff, size 10000, mask flags 0
[ 1.095397] DEBUG-CMDLINE-PART: partition 0: name <bootstrap>, offset ffffffff, size 40000, mask flags 0
[ 1.105735] DEBUG-CMDLINE-PART: mtdid=<spi_flash> num_parts=<7>
[ 1.112212] 7 cmdlinepart partitions found on MTD device spi_flash
[ 1.118972] Creating 7 MTD partitions on "spi_flash":
[ 1.124492] 0x000000000000-0x000000040000 : "bootstrap"
[ 1.144397] 0x000000040000-0x000000050000 : "uboot-env"
[ 1.164920] 0x000000050000-0x000000090000 : "uboot"
[ 1.185030] 0x000000090000-0x000000410000 : "kernel"
[ 1.205249] 0x000000410000-0x000000e10000 : "app"
[ 1.225200] 0x000000e10000-0x000000f90000 : "var"
[ 1.245188] 0x000000f90000-0x000001000000 : "param"
[ 1.295745] console [netcon0] enabled
[ 1.296685] netconsole: network logging started
[ 1.315126] fh_rtc fh_rtc.0: rtc core: registered rtc as rtc0
[ 1.327014] i2c /dev entries driver
[ 1.332052] I2C driver:
[ 1.332067] platform registration...
[ 1.335560] Clock: 50000khz, Standard-mode HCNT:LCNT = 212:249
[ 1.342230] tx fifo depth: 16, rx fifo depth: 16
[ 1.356209] I2C - (dev. name: fh_i2c - id: 0, IRQ #11
[ 1.356223] IO base addr: 0xc30a8000)
[ 1.362948] I2C driver:
[ 1.362959] platform registration...
[ 1.369565] Clock: 50000khz, Standard-mode HCNT:LCNT = 212:249
[ 1.376156] tx fifo depth: 16, rx fifo depth: 16
[ 1.398605] I2C - (dev. name: fh_i2c - id: 1, IRQ #12
[ 1.398619] IO base addr: 0xc30b0000)
[ 1.431485] card0 disconnected!
[ 1.436004] card1 disconnected!
[ 1.445073] TCP cubic registered
[ 1.445493] NET: Registered protocol family 17
[ 1.450458] lib80211: common routines for IEEE802.11 drivers
[ 1.456582] Registering the dns_resolver key type
[ 1.461692] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 1.497761] GMAC driver:
[ 1.497776] platform registration...
[ 1.501466] using random MAC address: ba:b5:9a:73:e8:5e
[ 1.513082] fh_gmac fh_gmac.0: eth0: mixed HW and IP checksum settings.
[ 1.517272] fh_gmac fh_gmac.0: eth0: mixed no checksumming and other settings.
[ 1.525299] eth0 - (dev. name: fh_gmac - id: 0, IRQ #15
[ 1.525313] IO base addr: 0xc30d0000)
[ 1.549332] fh_rtc fh_rtc.0: setting system clock to 1970-01-01 01:05:57 UTC (3957)
[ 1.557073] aes driver registered
[ 1.561794] Freeing init memory: 1200K
starting pid 401, tty '': '/etc/init.d/rcS'
[RCS]: /etc/init.d/S01udev
Starting udev: [ OK ]
[RCS]: /etc/init.d/S02init_rootfs
INITRAM_FS
[RCS]: /etc/init.d/S03network
[RCS]: /etc/init.d/S99longse
[ 3.436422] gmac_rmii: probed
[ 3.436953] eth0: PHY ID 02430c54 at 0 IRQ -1 (0:00) active
[ 3.443053] fh_gmac fh_gmac.0: eth0: mixed HW and IP checksum settings.
[ 3.448642] fh_gmac fh_gmac.0: eth0: mixed no checksumming and other settings.
s32GPIO = 0
fADC = 1.753666
LS_DEV_ModifyVersion 259 ========= no need to modify version
longse app mtd is OK!!
[ 3.881072] Video Memory Manager
[ 4.200441] load rtthread_arc_FH8856.bin at 0xa7e00000, set ring buffer at 0xa7df0000 with size 0x10000
[ 4.207063] get irq offset: 0
[ 4.214963] chn0 dev nr: 252
[ 4.226854] VBus loaded: 255 in blocks, 255 out blocks
[ 4.229151] VBUS driver loaded.
[ 4.232247] VBUS load rtthread_arc_FH8856.bin for rtvbus
[ 4.265529] firmware: rtthread_arc_FH8856.bin loaded
[ 4.267803] firmware: rtthread_arc_FH8856.bin started
[ 4.272660] ARC is running.
[ 4.326931] media_process: module license 'Proprietary' taints kernel.
[ 4.330656] Disabling lock debugging due to kernel taint
[ 4.361636] [MEDIA]media_process_module_init 268: media process init success!!
[ 4.389300] module->phys_addr=0xe8400000 module->virt_addr=0xc3400000
[ 4.393078] isp - (dev. name: ispp - IRQ #7
[ 4.393089] IO base addr: 0xc3400000)
[ 4.401198] module->phys_addr=0xe8500000 module->virt_addr=0xc3600000
[ 4.407699] isp - (dev. name: ispf - IRQ #8
[ 4.407710] IO base addr: 0xc3600000)
[ 4.415721]
[ 4.415728] stat buffer size: 67KBytes
[ 4.498955] [VPU]vpu_module_init 675: vpu init success!!
[ 4.637540] [ENC]pae_module_init 327: PAE init success!
[ 4.888964] [HEVC]hevc_module_init 226: HEVC init success!
[ 4.952495] [JPEG]jpeg_module_init 190: JPEG init success!
[ 5.012506] [BGM]bgm_module_init 466: bgm init success!!
[ 5.034566] ACW_VBUS version: V1.1.0-RC3(ga6aaaaa)
[ 5.655344] GPIO0:
[ 5.655388]
[ 5.656313] GPIO1:
[ 5.658041]
[ 5.659814] GPIO4:
[ 5.661439]
[ 5.663176] GPIO7:
[ 5.664950]
starting pid 597, tty '': '/sbin/inetd -f -e /etc/inetd.conf'
starting pid 598, tty '': '-/bin/sh'console.
BusyBox v1.19.3 (2019-01-18 16:29:39 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
fh-linux# ./AVServer: '/opt/app/lib/libFuhan8856MIspDev.so' is not an ELF file
./AVServer: can't load library 'libFuhan8856MIspDev.so'
[ 6.155292] card1 connected!
[ 6.437684] PHY: 0:00 - Link is Up - 100/Full
create tcp connect success 3,start listen...
Creat queue id:0
queue id:0
Kill queue id:0
Creat queue id:32768
queue id:32768
SetupEnv:mFileId=0
SetupEnv:Share Memory Addr=0x4000b000
FileMngInit_1 2173 0x4000b000
DEBUG Semaphore_Init-41: Semaphore id:0
DEBUG Semaphore_SetValue-58: Semaphore Set Value:1
Global value size:7996
cloud size:32, ptz size:64....
ptz serial size:12
ReadGlobal 1761: filename = /opt/app/bin/sysenv_custom.cfg, nConfigSize = 7996
open System file /opt/app/bin/sysenv_custom.cfg fail
[File_Mng] Mac = 10:20:30:40:50:60
ReadGlobal 1761: filename = /param/sysenv.cfg, nConfigSize = 7996
nfilesize=7996 , configsize=7996
MagicNum: 2593849357, MagicNumConfig: 2593849357
FileMngInit_1 2192: ReadGlobal: ret = 0 .......................
FileMngInit_1 2221: psysInfo->relUniqueId1 = 11264
ListenSocketThread 243: fd = 3
create_log_file 1354 NULL
[ReadDevConfigFile] Mac = 2C:6F:51:06:50:A8
ReadNetConfigFile 1603: free_sn = 8801517649792EndEnd
FileMngInit_1 2414 This is new p2p
[Trace]: LS_GetDevTypeEnableFileName 2088 $$$$$$ u8AudioFlag = 1, u8TFCardFlag = 4, u8CDSFlag = 15
[Trace]: LS_GetDevTypeEnableFileName 2146 : fileName = /var/etc/BitdogDevTypeEnableSmartTF.ini
FileMngInit_1 2457 ucHkXmPort = 1
[Trace]: FileMngInit_1 2564 ucMDVideoStreamType: 1
FileMngInit 2735 FileMngInit_1 fail
FileMngInit_2 2603 0x4000cf3c
Global value size:16848
ReadGlobal 1761: filename = /param/sysenv_ex.cfg, nConfigSize = 16848
nfilesize=16848 , configsize=16848
FileMngInit_2 2616: ReadGlobal: ret = 0 .......................
FileMngInit_2 2632: psysInfo->relUniqueId1 = 1023
[Trace]: Common_Init 465
[Trace]: Common_Init 478 #####################value 1
[Trace]: Common_Init 481 PROCESS_BOA
Creat queue id:98306
queue id:98306
SysDrvInit 86 gSysProcId 2
shared memory size 147456
shared memory id:0
pSysConfig:0x400a0000
[Trace]: libCloudStorageAccessInit 79
Semaphore id:32769
[Trace]: libGoogleAccessInit 31
[Trace]: libDropBoxAccessInit 27
[Trace]: libCloudStorageStartGetRefreshToken 223
[Trace]: Common_Init 555 $$$$$$ CardFlag = 1, AudioFlag = 4
[Trace]: Common_Init 556 $$$$$$ CardFlag = 1, AudioFlag = 4
[Trace]: Common_Init 557 $$$$$$ CardFlag = 1, AudioFlag = 4
[Trace]: Common_Init 558 $$$$$$ CardFlag = 1, gCDSFlag = 15
[Trace]: Common_Init 571
[Trace]: Longse protocol starting...
Longse server is running...
Platform: FUHAN8856
Console: enable
Devname: eth0
Server port: 80
Version: V1.0 Build Mar 4 2020 16:13:48
[Trace]: Now, starting the server thread...
[Trace]: LongseServerStart 128: port = 0
[Trace]: StartLSVideoProcess 1183: start!
[Trace]: LSStartNetwork 1184: port = 0
[Trace]: GetAVStreamInit 114:type = 2 func = 0x4c5b7c
[Trace]: GetAVControlInit 106
[Trace]: GetAVControlInit 124: gGetAVStreamSysInfo.StreamSharememID[0] = 163845
[Trace]: GetAVControlInit 156: gGetAVStreamSysInfo.StreamSharememID[1] = 196614
[Trace]: main 866 OnvifPrivate Enable = 1, port = 8999
[Trace]: Onvif build Mar 4 2020 starting...
Onvif_server server is running...
Console: enable
Devname: eth0
Server port: 8999
Version: V1.0 Build Mar 4 2020 16:14:41
[Trace]: Now, Init config...
[Trace]: Onvif_ReadGlobal 51 : ONVIF_SYS_FILE = /param/onvif_ex.cfg
[Trace]: InitPreset ok!!!!
[Trace]: Now, starting the probe thread...
[Trace]: Now, starting the webservice thread...
[Trace]: Now, starting the event thread...
[Trace]: EventServiceStart 1867: Start event! alive_subscribe = 0
[Trace]: main 876 OnvifPrivate Enable = 1, port = 8999
[Trace]: main 885 HkPrivate Enable = 0, port = 8000
rtspSLib server starting .............
[Trace]: RTSP_ParamsInit 4247: RtpAlarmEnable 0
[Trace]: RTSP_ParamsInit 4248: ConnectLimitEnable 1
[Trace]: RTSP_ParamsInit 4249: #############RtpOverUdpEnable 1
--------------rs_rtsp.c 4070 sizeof(pRtspSvr->pRtpUdpSender ) 180
[Trace]: RtspBufferInit 732: start!
[Trace]: libAVSpsPpsProcessInit 33: libAVSpsPpsProcessInit libAVSpsPpsProcessInit!
Rtsp server is running...
Console: enable
Version: V1.0 Build Mar 4 2020 16:14:45
[Trace]: GetAVStreamInit 114:type = 4 func = 0x4d15b8
[Trace]: main 904 XmPrivate Enable = 0, port = 34567
[Trace]: WebService_Thread start
[Trace]: CheckStreamType 335: Change stream type!
FHWdtInit is ok
[Trace]: HASH_TABLE_SIZE = 240
HWatchDogPause 35 Pause, (300s)time up -21s
[Trace]: AVStreamGetAVDataThread 567: type = 4 index = 0
[Trace]: AVStreamGetAVDataThread 648: MsgAVType = 4 VideoIndex = 0
[Trace]: Common_GetArgeementProperty,6449
[Trace]: Common_GetArgeementProperty,6463:[guanfa]ucArgType = 8
[Trace]: Common_GetArgeementProperty,6533:ARG_AGREEMENT_ONVIF.......................................
[Trace]: Common_GetArgeementProperty,6539:onvifPro usPort = 8999, enable = 1
[Trace]: Common_GetArgeementProperty,6577:ucArgType = 0x8
[Trace]: Onvif_GetOnvifserverPort 1023 bbbbbbbbbbbbbbbbbbbbbbbbb
[Trace]: Onvif_GetOnvifserverPort 1024 bbbbbbbbbbbbbbbbbbbbbbbbb
[Trace]: Onvif_GetOnvifserverPort 1025 bbbbbbbbbbbbbbbbbbbbbbbbb
[Trace]: Onvif_GetOnvifserverPort 1026 bbbbbbbbbbbbbbbbbbbbbbbbb
[Trace]: Onvif_GetOnvifserverPort 1028 AgreementOut.property.onvifPro.ucEnable = 1, port = 8999
[Info]: [764][WebService_Thread] Socket connection successful: master socket = 36
queue id:32768
open /proc/driver/hevc is ok
open /proc/driver/vpu is ok
open /proc/driver/isp is ok
LS_GetFileNodeName is ok
LS_HardCheck_Proc thread Creat is OK
[Trace]: AVStreamGetAVDataThread 567: type = 4 index = 1
[Trace]: AVStreamGetAVDataThread 648: MsgAVType = 4 VideoIndex = 1
[Trace]: AVStreamGetAVDataThread 567: type = 2 index = 0
[Trace]: create tcp connect success 3,start listen...
[Trace]: SocketThread 456: fd = 3
[Trace]: AVStreamGetAVDataThread 567: type = 2 index = 1
rtspPort=:554
IpeyeVendor=
RUNCMD=/opt/app/bin/cloud_linux_arm_v[5-7].run -config_dir=/param/ipeye/ -streams=rtsp://127.0.0.1:554/0,rtsp://127.0.0.1:554/1 -http_camera_mode=1
WatchDog time = 0 3981 3981 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[Trace]: AVStreamGetAVDataThread 629: gTransFormStatusFunc[2](0) == 0
[Trace]: AVStreamGetAVDataThread 629: gTransFormStatusFunc[2](1) == 0
WatchDog time = 0 3983 3983 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Source 0 has die
stat error, errno = 2
WriteToLog 104 file size = 0
LS_SoftCheck_Proc 850: cmd = killall -9 boa
LS_SoftCheck_Proc 850: cmd = killall -9 SystemServer
LS_SoftCheck_Proc 850: cmd = killall -9 AVServer
killall: AVServer: no process killed
HWatchDogPause 35 Pause, (300s)time up 0s
LS_SoftCheck_Proc 856: cmd = echo 3 > /proc/sys/vm/drop_caches
LS_SoftCheck_Proc 866: cmd = reboot
The system is going down NOW!
Sent SIGTERM to all processes
[Trace]: SocketThreadStop 518: Thread Stop!
[Trace]: SocketThread 512: Thread end!
Requesting system rebootesses
[ 36.284861] m25p80 spi0.0: [m25] shutdown here?
[ ▒ROM: Use nor flash.
ERR: Param type error
RКод: Выделить всё
U-Boot> printenv
bootargs=console=ttyS0,115200 root=/dev/ram0 mem=45M mtdparts=spi_flash:256k(bootstrap),64k(uboot-env),256k(uboot),358 4k(kernel),10M(app),1536k(var),448K(param)
bootcmd=sf probe 0; sf read 0xA1000000 0x90000 0x380000; bootm
bootdelay=1
baudrate=115200
ethaddr=10:20:30:40:50:60
ipaddr=10.81.81.81
serverip=10.81.0.1
phymode=RMII
stdin=serial
stdout=serial
stderr=serial
ethact=FH EMACКод: Выделить всё
arc_go - start application at address 'addr'
bdinfo - print Board Info structure
chpart - change active partition
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
date - get/set/reset date & time
dhcp - boot image via network using DHCP/TFTP protocol
echo - echo args to console
editenv - edit environment variable
iminfo - print header information for application image
imxtract- extract a part of a multi-image
itest - return true/false on integer compare
loads - load S-Record file over serial line
md - memory display
mmc - MMC sub system
mmcinfo - mmcinfo <dev num>-- display MMC info
mtdparts- define flash/nand partitions
mw - memory write (fill)
nfs - boot image via network using NFS protocol
pinctrl - Pin Ctrl
sf - SPI flash sub-system
sleep - delay execution for some time
source - run script from memory
sspi - SPI utility commands
tftpboot- boot image via network using TFTP protocol
usb - USB sub-system
wdt - WDT utility commands
