пароль от ip-камер DAHUA
Re: пароль от ip-камер DAHUA
dimonster -это интересно,но я только дошел до речки.сейчас заброшу удочки и..........
только добрался до мастерской.К сожалению способ подмены команд в commands.txt не прошел.вот вывод с консоли:
Ncat: Version 7.40 ( https://nmap.org/ncat )
Ncat: Listening on 192.168.254.254:5002
gBootLogPtr:20b80008.
NAND: SPINAND: _MDrv_SPINAND_GET_INFO:error, Found SPINAND INFO
(0xC8) (0x1)
SPINAND: board_nand_init:error, CIS contains part info
128 MiB
partition file version 2
rootfstype squashfs root /dev/mtdblock12
gParameter[0]:node=bootargs, parameter=mem=130840K console=ttyS0,115200 root=/de
v/mtdblock12 rootfstype=squashfs LX_MEM=0x7fc6000 mma_heap=mma_heap_name0,miu=0,
sz=0x2442000.
gParameter[1]:node=upgradeMode, parameter=switchBootPart=1.
In: serial
Out: serial
Err: serial
TEXT_BASE:21000000
Net: fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
MAC Address 08:ED:ED:BF:BB:1D
Auto-Negotiation...
Link Status Speed:100 Full-duplex:1
MMC: DGS info:start addr=0x27f42000
dgsBufStart:0x27f42000
dgs offset:0x500000 size:0x100000
[DGS]:Dgs_BootCreate
[DGS]:readPtrC:0 writePtr:0 covered:0
[DGS]:Dgs_BootCreate end
Invalid addr 0x23000000, the fixed default addr is 0x22000000
MDrv_EMAC_start
RBQP_BASE=0x21080000
Using sstar_emac device
TFTP from server 192.168.254.254; our IP address is 192.168.1.251; sending throu
gh gateway 192.168.1.1Download Filename 'upgrade_info_7db780a713a4.txt'.Download
to address: 0x22000000
Downloading: *
done
Bytes transferred = 78 (4e hex)
disable wdt
cmd:(help) is not support!
cmd:(printenv>) is not support!
cmdLine mem=130840K root=/dev/mtdblock12 rootfstype=squashfs LX_MEM=0x7fc6000 mm
a_heap=mma_heap_name0,miu=0,sz=0x2442000
MDrv_EMAC_start
(0xC8) (0x1)
128 MiB
sz=0x2442000.
In: serial
Out: serial
Err: serial
TEXT_BASE:21000000
Auto-Negotiation...
MDrv_EMAC_start
Downloading: *
done
disable wdt
MDrv_EMAC_start
Весело, только относиться к другому бренду )).
Последний раз редактировалось UefLV 12 июл 2021, 13:44, всего редактировалось 1 раз.
У меня. 21 камера ,висят в очень труднодоступных местах.а так и кнопкой ресетнуть можно
Ничего себе. Даже эти безобидные команды не поддерживаются. Видать, китайцы перебдели с кибербезопасностью
IPL fd8e347
D-0a
128MB
BIST0_0001-OK
Load IPL_CUST from SPINAND
CIS in Block00
Match CIS ID( c8 01 )
BlSize 00004780
Checksum OK
IPL_CUST fd8e347
runUBOOT()
CIS in Block00
ChkHealthy: 0003: 0007: 0000
ChkHealthy: 0004: 0007: 0000
ChkHealthy: 0005: 0007: 0000
Load BL from SPINAND
-Verify CRC32 passed!
-Decompress XZ
u32HeaderSize=0x00000040
u32Loadsize=0x00006948
decomp_size=0x0000f294
Disable MMU and D-cache before jump to UBOOT
U-Boot 2010.06-svn8061 (Apr 17 2020 - 22:06:21)
это то,что выдал UART
D-0a
128MB
BIST0_0001-OK
CIS in Block00
BlSize 00004780
Checksum OK
IPL_CUST fd8e347
runUBOOT()
CIS in Block00
-Decompress XZ
Да, думаю сидя перед ПК в удобном кресле удобней, чем бегать по объекту со стремянкой, хотя вероятно как кому ))
И, да это не тот QR код который на корпусе камеры, но вероятно тут не все читатели ))), Вы хоть ссылки посмотрели?
что за ссылки?как через config tool сбросить пароль?Не зная ответа на контрольные вопросы,не зная электронной почты?
Если емайл активирован и нет к нему доступа, то удаленно только XML.
