Выполните
sf probe 0; sf erase 7b0000 50000
setenv bootargs mem=64M console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=squashfs mtdparts=hi_sfc:192K(boot),2432K(romfs),3520K(usr),1664K(custom),64K(logo),320K (mtd) coherent_pool=2M
saveenv
(это три команды, всего 3 строки)
saveenv
сделал, показать printenv?
U-Boot 2010.06-svn283 (Nov 05 2015 - 17:38:49)
Check Flash Memory Controller v100 ... Found
SPI Nor(cs 0) ID: 0xc2 0x20 0x17
Block:64KB Chip:8MB Name:"MX25L6406E"
SPI Nor total size: 8MB
In: serial
Out: serial
Err: serial
PHY 0x02: OUI = 0x01F0, Model = 0x0F, Rev = 0x01
change register for 8710
CONFIG MII
ETH0: PHY(phyaddr=2, rgmii) link UP: DUPLEX=FULL : SPEED=100M
MAC: 00-0B-3F-00-00-01
Press CTRL-C to abort autoboot in 2 secondshisilicon # <INTERRUPT>
hisilicon # printenv
bootcmd=sf probe 0;sf read 0x84000000 0x7a0000 0x10000;logoload 0x84000000;decjp g;sf read 0x82000000 0x30000 0x300000;squashfsload 82000000;bootm 0x82000000
bootdelay=1
baudrate=115200
ethaddr=00:0b:3f:00:00:01
ipaddr=192.168.1.10
serverip=192.168.1.12
netmask=255.255.0.0
gatewayip=192.168.1.1
bootfile="uImage"
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwri te
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwr ite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrit e
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwri te
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flw rite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
appVideoStandard=PAL
bootargs=mem=130M console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=squashfs mtdparts=hi_sfc:192K(boot),2432K(romfs),3520K(usr),1664K(custom),64K(logo),320K (mtd) coherent_pool=2M
appSystemLanguage=Russian
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn283 (Nov 05 2015 - 17:38:49)
Environment size: 1373/65532 bytes
hisilicon #
In: serial
Out: serial
Err: serial
CONFIG MII
bootdelay=1
baudrate=115200
ipaddr=192.168.1.10
netmask=255.255.0.0
bootfile="uImage"
stdin=serial
stdout=serial
stderr=serial
verify=n
hisilicon #
ничего не поменялось
вообще лог выполнения лучше показывать. После этих команд ничего не поменялось?
Залейте прошивку, которую я скидывал и повторите все команды опять
In: serial
Out: serial
Err: serial
CONFIG MII
hisilicon # run dr
CONFIG MII
TFTP from server 192.168.1.12; our IP address is 192.168.1.10
Download Filename 'romfs-x.cramfs.img'.
Download to address: 0x82000000
Downloading: # [ Connected ]
################################ [ 1.000 MB]
done
Bytes transferred = 1843264 (1c2040 hex)
8192 KiB hi_fmc at 0:0 is now current device
PACK_ID error
## Checking Image at 0x82000000 ...
Header CRC Checking ... OK
Image Name: linux
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 1843200 Bytes = 1.8 MiB
Load Address: 00030000
Entry Point: 00220000
Data CRC Checking ... OK
Programing start at: 0x00030000
Programing end at: 0x00220000
Erasing at 0x220000 -- 100% complete.
done.
Erased sectors.
Saving Image to Flash ...
Writing at 0x220000 -- 100% complete.
done.
hisilicon # run dc
CONFIG MII
Download Filename 'custom-x.cramfs.img'.
done
Bytes transferred = 1687616 (19c040 hex)
PACK_ID error
Image Name: linux
Image Type: ARM Linux Standalone Program (gzip compressed)
Data Size: 1687552 Bytes = 1.6 MiB
Load Address: 005f0000
Entry Point: 00790000
Programing start at: 0x005f0000
Programing end at: 0x00790000
Erasing at 0x790000 -- 100% complete.
done.
Erased sectors.
Writing at 0x790000 -- 100% complete.
done.
hisilicon # run du
CONFIG MII
Download Filename 'user-x.cramfs.img'.
################################ [ 2.000 MB]
################################ [ 3.000 MB]
done
Bytes transferred = 3924032 (3be040 hex)
PACK_ID error
Image Name: linux
Data Size: 3923968 Bytes = 3.7 MiB
Load Address: 00220000
Entry Point: 005f0000
Programing start at: 0x00220000
Programing end at: 0x005f0000
Erasing at 0x5f0000 -- 100% complete.
done.
Erased sectors.
Writing at 0x5f0000 -- 100% complete.
done.
hisilicon # run dw
CONFIG MII
Download Filename 'web-x.cramfs.img'.
Downloading: *
TFTP error: 'File not found' (1)
Not retrying...
PACK_ID error
DestAddr invalid!
DestAddr: 0x00000000~0x2000000
hisilicon # sf probe 0; sf erase 7b0000 50000
Erasing at 0x800000 -- 100% complete.
hisilicon # setenv bootargs mem=64M console=ttyAMA0,115200 root=/dev/mtdblock1 r ootfstype=squashfs mtdparts=hi_sfc:192K(boot),2432K(romfs),3520K(usr),1664K(cust om),64K(logo),320K (mtd) coherent_pool=2M
hisilicon # saveenv
Saving Environment to SPI Flash...
Erasing SPI flash, offset 0x00020000 size 64K ...done
Writing to SPI flash, offset 0x00020000 size 64K ...done
hisilicon #
In: serial
Out: serial
Err: serial
CONFIG MII
hisilicon # run dr
CONFIG MII
done
PACK_ID error
Image Name: linux
done.
Erased sectors.
done.
hisilicon # run dc
CONFIG MII
done
PACK_ID error
Image Name: linux
done.
Erased sectors.
done.
hisilicon # run du
CONFIG MII
done
PACK_ID error
Image Name: linux
done.
Erased sectors.
done.
hisilicon # run dw
CONFIG MII
Downloading: *
Not retrying...
PACK_ID error
DestAddr invalid!
hisilicon # saveenv
hisilicon #
С другой прошивкой тоже ничего не поменялось?
нет, так же первая заставка на экране и все
In: serial
Out: serial
Err: serial
CONFIG MII
ETH0: PHY(phyaddr=2, rgmii) not link!
higmac init fail!
bootcmd=sf probe 0;sf read 0x84000000 0x7a0000 0x10000;logoload 0x84000000;decjpg;sf read 0x82000000 0x30000 0x300000;squashfsload 82000000;bootm 0x82000000
bootdelay=1
baudrate=115200
ipaddr=192.168.1.10
netmask=255.255.0.0
bootfile="uImage"
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
bootargs=mem=130M console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=squashfs mtdparts=hi_sfc:192K(boot),2432K(romfs),3520K(usr),1664K(custom),64K(logo),320K(mtd) coherent_pool=2M
stdin=serial
stdout=serial
stderr=serial
verify=n
hisilicon #
In: serial
Out: serial
Err: serial
CONFIG MII
higmac init fail!
bootdelay=1
baudrate=115200
ipaddr=192.168.1.10
netmask=255.255.0.0
bootfile="uImage"
stdin=serial
stdout=serial
stderr=serial
verify=n
hisilicon #
так может вы не даете регу загрузиться, останавливая каждый раз загрузку?...покажите лог загрузки на нажимая ctrl-C
In: serial
Out: serial
Err: serial
CONFIG MII
higmac init fail!
Press CTRL-C to abort autoboot in 2 seconds8192 KiB hi_fmc at 0:0 is now current device
CFG_BOOT_ADDR:0x0
### /UbootLogo UbootLogoload complete: 55924 bytes loaded to 0x8e800000
jpeg decoding ...
<<addr=0x8e800000, size=0xb85f9, vobuf=0x8f000000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg success.
decode jpeg!
OpenDev vo:0 intf_type:36 out_sync:16
srcAddr 0x82000000, dstAddr 0x82000000
find_squashfs_file: name bin, start_block 0, offset 1342, type 1
find_squashfs_file: name boot, start_block 0, offset 1434, type 1
read inode: name boot, sb 0, of 1434, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 1374, type 2
read inode: name zImage.img, sb 0, of 1374, type 2
### FS load complete: 1591968 bytes loaded to 0x82000000
Image Name: linux
Data Size: 1591904 Bytes = 1.5 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
In: serial
Out: serial
Err: serial
CONFIG MII
higmac init fail!
CFG_BOOT_ADDR:0x0
jpeg decoding ...
decode success!!!!
decode jpeg!
Image Name: linux
OK
Starting kernel ...
...и висит на логотипе?
логотип потухает и все.. черный экран
а если включить режим "терпение", то после черного экрана не появляется раскладка по камерам?
