Need Dump file: Hi3520D+NVP6114 4ch DVR
7aman
Сообщение 7aman » 15 сен 2018, 14:17
Hi.
I need dump file for this DVR.
Thanks.
yuri1958
Re: Need Dump file: Hi3520D+NVP6114 4ch DVR
Сообщение yuri1958 » 15 сен 2018, 18:17
7aman писал(а):Hi.
Thanks.
Пробуйте вот отсюда http://rgho.st/8l45R8JvJ" onclick="window.open(this.href);return false;
7aman
Сообщение 7aman » 16 сен 2018, 11:16
Thanks.
before applying:
Black screen, no sound, 0.10 Ampere steady current. no reboot.
after applying this file:
It shows Color Bars (0.19 Amp) for some seconds, then buzzer makes steady noise (0.22 Amp) for some seconds then reboots. then again ...
Fluffykrsk
Сообщение Fluffykrsk » 16 сен 2018, 12:45
yuri1958 писал(а):Пробуйте вот отсюда http://rgho.st/8l45R8JvJ" onclick="window.open(this.href);return false;
Там env не кривой?) Или неизвестно.
7aman писал(а):Thanks.
before applying:
Check my message elsewhere. I gave you a dump. The PCB is identical.
Try again. I cleared the dump from this topic.
https://yadi.sk/d/ppxgwxYp1HSzgA" onclick="window.open(this.href);return false;
P.S: The current value does not help. You can not write.
Сообщение dede » 16 сен 2018, 13:22
Did you save contents of the flash before experimenting with dumps? If so, upload it somewhere.
Whats written on U18?
yuri1958, а почему именно этот дамп? Есть сомнения... Не juan ли это?
7aman
Сообщение 7aman » 16 сен 2018, 13:25
Fluffykrsk писал(а): Check my message elsewhere. I gave you a dump. The PCB is identical.
:good: :good:
thanks a lot.
i saw it in "elsewhere". :D
i applied. it is working now.
thank you again.
7aman
Сообщение 7aman » 16 сен 2018, 13:34
dede писал(а):Did you save contents of the flash before experimenting with dumps? If so, upload it somewhere.
i uploaded dump before. Fluffykrsk said it is useless.
if you interested:
https://uploadfiles.io/j5iqz
and yes, it is a product of Juan.
Fluffykrsk
Сообщение Fluffykrsk » 16 сен 2018, 14:21
От SARMATT DSR-410-h подошёл, такая же мать. На облако залью к себе (ссылка в профиле). Там можно будет качнуть.
Сообщение dede » 16 сен 2018, 14:30
Ну с вашим согласен, это ж juan, а yuri1958 выложил нечто вообще иное
Сообщение Sonya » 16 сен 2018, 15:12
dede писал(а):yuri1958 выложил нечто вообще иное
Какая-то разновидность на базе XM.
"Vendor" : "NOCRYPO",
"Hardware" : "TVI9304H_F",
shaker133
Сообщение shaker133 » 23 дек 2018, 13:03
Hi everyone i have dvr Hi3521D+NVP6114 4ch DVR
my dvr info.
AXB700XT8-3521A-NH V1.01b h.w
7004t-H-v2 for front end of board label s/w
did this dump work or not ,
if you have a dump please share it thanks.
Сообщение AlienP666 » 24 дек 2018, 07:07
shaker133 писал(а):Hi everyone i have dvr Hi3521D+NVP6114 4ch DVR
my dvr info.
Hi, make foto from from your DVR board and version FW. And say what the problem with your DVR.
