DVR. H.264 флэш s29gl064n90tf104 не коперует в DDR.
Добрый день. Не получается копировать с флэши s29gl064n90tf104 на DDR полный дамп чтоб сделать резервное копию дампа. Может я не правильно прописывают адреса?
U-Boot 2008.10 (Oct 13 2011 - 11:20:13)
DRAM: 128 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
Usb auto update detecting ......
USB: scanning bus for devices... 2 USB Device(s) found
0 Storage Device(s) found
ERR: usb storage scan failed
enable usb error
debug wyt new mac: 08:21:31:41:51:61
Press CTRL-C to abort autoboot in V-boot # help
? - alias for 'help'
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
detectmemory - detect mem
erase - erase FLASH memory
exit - exit script
flinfo - print FLASH memory information
updateuboot - u-boot update(update visiondigi u-boot)
help - print online help
hwinfo - show visiondigi hardware information
i2c_eeprom - communicate with eeprom through i2c bus
md - memory display
mf - do external chip manufacture write(update visiondigi external chip)
mm - memory modify (auto-incrementing)
mw - memory write (fill)
protect - enable or disable FLASH write protection
test - minimal test like /bin/sh
tftp - download or upload image via network using TFTP protocol
tst_bep JUST FOR 3515 platform!!!!
updateflash - flash image update(update visiondigi all flash)
usb - USB sub-system
zImage - start kernel
V-boot # printenv
bootdelay=3
baudrate=115200
bootfile="uImage"
filesize=1FBF2C
fileaddr=C0200000
gatewayip=192.168.1.1
netmask=255.255.255.0
ipaddr=192.168.1.177
serverip=192.168.1.39
bootcmd=bootm 0x80040000
bootargs=mem=54M root=/dev/mtdblock2 rootfstype=jffs2 ro mtdparts=physmap-flash. 0:256K(boot),1536K(kernel),1472K(rootfs),4160K(usr),704K(mnt),64K(e2prom) busclk =220000000
bootargs.nfs=mem=54M root=/dev/nfs nfsroot=192.168.1.211:/home/share/yu_xiangyun /sdk_3515/rootfs ip=192.168.1.105:::::eth0 busclk=220000000
console_debug=1
eeprom_exist=0
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2008.10 (Oct 13 2011 - 11:20:13)
ethaddr=08:21:31:41:51:61
Environment size: 654/65532 bytes
V-boot # cp.b 0x80040000 0x00000000 0x00800000
DRAM: 128 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
enable usb error
Press CTRL-C to abort autoboot in 1 seconds
## Booting kernel from Legacy Image at 80040000 ...
Image Name: Linux-2.6.24-rt1-hi3515v100
Data Size: 1543836 Bytes = 1.5 MB
Load Address: c0800000
Entry Point: c0800000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux............................................................. ..................................... done, booting the kernel.
Linux version 2.6.24-rt1-hi3515v100 (zxw@18server) (gcc version 3.4.3 (release) (CodeSourcery ARM Q3cvs 2004)) #6 Thu May 26 10:28:19 CST 2011
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: hi3515v100
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 13716
Kernel command line: mem=54M root=/dev/mtdblock2 rootfstype=jffs2 ro mtdparts=ph ysmap-flash.0:256K(boot),1536K(kernel),1472K(rootfs),4160K(usr),704K(mnt),64K(e2 prom) busclk=220000000 console=ttyAMA0,115200n8 ethaddr=08:21:31:41:51:61
PID hash table entries: 256 (order: 8, 1024 bytes)
Memory: 54MB = 54MB total
Memory: 51492KB available (2836K code, 257K data, 88K init)
HI_VERSION=LINUX_2_6_24-M01C06FB02F @Hi3515v100R001_C_0_0_0 2010-03-16 10:41:14
net_namespace: 64 bytes
Hisilicon clock system V0.01
SCSI subsystem initialized
Time: hisi_timer1 clocksource has been installed.
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
yaffs Apr 28 2011 10:27:13 Installing.
io scheduler noop registered
uart:0: ttyAMA0 at MMIO 0x20090000 (irq = 12) is a AMBA/PL011
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x200a0000 (irq = 12) is a AMBA/PL011
uart:2: ttyAMA2 at MMIO 0x200b0000 (irq = 13) is a AMBA/PL011
uart:3: ttyAMA3 at MMIO 0x200c0000 (irq = 13) is a AMBA/PL011
Hisilicon ETH net controler(ver May 26 2011 10:28:17).
Hisilicon ETH MDIO Bus: probed
phy:0:02
mac addr:08:21:31:41:51:61
PPP Deflate Compression module registered
PPP BSD Compression module registered
NET: Registered protocol family 24
SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
CSLIP: code copyright 1989 Regents of the University of California.
SLIP linefill/keepalive option.
Driver 'sd' needs updating - please use bus_type methods
physmap platform flash device: 04000000 at 80000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
6 cmdlinepart partitions found on MTD device physmap-flash.0
Creating 6 MTD partitions on "physmap-flash.0":
0x00000000-0x00040000 : "boot"
0x00040000-0x001c0000 : "kernel"
0x001c0000-0x00330000 : "rootfs"
0x00330000-0x00740000 : "usr"
0x00740000-0x007f0000 : "mnt"
0x007f0000-0x00800000 : "e2prom"
hi3515v100-ehci hi3515v100-ehci.0: hi3515v100-ehci
hi3515v100-ehci hi3515v100-ehci.0: new USB bus registered, assigned bus number 1
hi3515v100-ehci hi3515v100-ehci.0: irq 23, io mem 0x100b0000
hi3515v100-ehci hi3515v100-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 200 4
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hi3515v100-ohci hi3515v100-ohci.0: hi3515v100-ohci
hi3515v100-ohci hi3515v100-ohci.0: new USB bus registered, assigned bus number 2
hi3515v100-ohci hi3515v100-ohci.0: irq 22, io mem 0x100a0000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
mice: PS/2 mouse device common for all mice
usb 2-1: new low speed USB device using hi3515v100-ohci and address 2
usb 2-1: configuration #1 chosen from 1 choice
input: PIXART USB OPTICAL MOUSE as /class/input/input0
input: USB HID v1.10 Mouse [PIXART USB OPTICAL MOUSE] on usb-hisilicon-1
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
TCP cubic registered
VFS: Mounted root (jffs2 filesystem) readonly.
Freeing init memory: 88K
init started: BusyBox v1.1.2 (2011.05.11-08:48+0000) multi-call binary
Starting pid 220, console /dev/console: '/etc/init.d/rcS'
waiting for udev start......
wyt sysctl ...............
hifb: module license 'Proprietary' taints kernel.
hifb info: HIFB_MAIN_VERSION[v1.0.0.2] Build Time[Aug 11 2010, 18:11:30]
hifb info: video:vram0_size=2621440,vram1_size=256,vram2_size=1622016
hifb info: succeed in registering the fb0: ovl0 frame buffer device
hifb info: succeed in registering the fb1: ovl1 frame buffer device
hifb info: succeed in registering the fb2: ovl2 frame buffer device
TDE_MAIN_VERSION[v2.0.0.0] Build Time[Aug 11 2010, 18:11:32]
TDE_ADP_VERSION[hi3515adp v2.0.0.0] Build Time[Aug 11 2010, 18:11:32]
tde run on master arm
tde run for graphic service
tde map reg:basePhyAddr:20140000 baseVirAddr:c3874000 size:3000
Chip Version: Hi35150100
load vd.ko ....OK!
load vou.ko ....OK!
load vdec.ko ....OK
load vpp.ko ....OK!
load md.ko....OK!
load h264d.ko OK
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 0)
HISI_WDT-MDC030001 @Hi3511v110_OSDrv_1_0_0_8 2009-03-30 10:45:48<6>HISI_WDT-MDC0 30001 @Hi3511v110_OSDrv_1_0_0_8 2009-03-30 10:45:48
HISI_I2C-MDC030002 @Hi3511v110_OSDrv_1_0_0_1 2008-11-03 18:35:36
reg_cmd driver init successful!
hi3515-ahci-device hi3515-ahci-device.: controller can't do NCQ, turning off CAP _NCQ
scsi0 : hi3515-ahci-device
scsi1 : hi3515-ahci-device
ata1: SATA max UDMA/133 irq 29
ata2: SATA max UDMA/133 irq 29
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
crypt driver ds28e01 init successful!
crypt device ds28e01 open successfully.....
ver: Oct 10 2011,11:24:27
ln: /etc/resolv.conf: File exists
command: ifconfig eth0 hw ether ce:45:f2:f2:08:0e
"netinit help" for help
eth0:
IP+++++++++++++++++++++++++++: <192.168.1.108>
IP: <192.168.1.108> netmask: <255.255.255.0>
LIBDVR : Set Ip Successful
LIBDVR : Set NetMask Successful
netinit uses obsolete (PF_INET,SOCK_PACKET)
Gateway: <192.168.1.1>
LIBDVR : SetGateWay Successful
ln: /etc/ppp/pap-secrets: File exists
ln: /etc/ppp/chap-secrets: File exists
ln: /etc/ppp/firewall-masq: File exists
ln: /etc/ppp/firewall-standalone: File exists
ln: /etc/ppp/pppoe.conf: File exists
ln: /etc/ppp/pppoe-server-options: File exists
PPPoE is disabled...
[: 1: unknown operand
UNRAR 3.50 beta 1 freeware Copyright (c) 1993-2005 Alexander Roshal
Extracting from /usr/data/Data/Font.rar
Extracting /var/Font.bin OK
All OK
Extracting from /usr/Sofia.rar
Extracting /var/Sofia 86%PHY: 0: 02 - Link is Up - 100/Full OK
All OK
Ca in libhicap Start
RTC1338init successfull!
0x0000: 12 0 0 ea ff ff ff ff ff 1 ff ff ff ff ff ff
0x0010: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0x0020: ce 45 f2 f2 8 e ff
Reg_cmd device open successfully.....
0x0030: 56 52 39 37 31 36 53 43 2d 31 55 2d 2d 48 53 4b
0x0040: ff ff ff ff 56 0 0 80 ff ff ff ff c5 6 ff ff
0x0050: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0x0060: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
0x0070: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
LIBDVR : **********************************************************************
LIBDVR : | SYSTEM INFO
LIBDVR : | VR98XX PRODUCTID: 0x80000054 - Complie time Jan 11 2012 09 :06:09
SystemGetVGAPixel VGA <3> 0:1080p, 1:1280*1024, 2:1280*720, 3:1024*768, 4:800*6 00
LIBDVR : | VR98XX PRODUCT_TYPE:<84>. VGA <3>
LIBDVR : | svn:.
LIBDVR : | FrontBoard type 0x1
LIBDVR : Chip_Init------LocalChipID:0, 0#######
LIBDVR : ########total chip is : 1########
LIBDVR : ##############chipMode:0##############
LIBDVR : This Device ChipNum is 1, product type is 84.videoStd is 0
LIBDVR : total_chn:8
LIBDVR : #####DCM_Init########
rm: cannot remove `/var/usr/Sofia': No such file or directory
rm Sofia from RAM
16:31:40|trace main(1, /var/Sofia)
start Sofia on 2018-9-25 16:31:40
16:31:40|trace CChallenger::CChallenger()>>>>>>>>>
init at88() finish.
at88 init succ
DCR = 0xffffffeb
AAC1 = 0xffffffff
cm_VerifyCrypto fail
at88 crypeto failed
init at88() finish.
AT88 verify password success
16:31:40|info system check ok!!! return: 0.
* Lua Engine Version: Lua 5.0.2
* Supported Language: English,SimpChinese,TradChinese,French,German,Portugal,Tu rkey,Spanish,Farsi,Arabic,Russian,Hebrew,Greek,Italian
* SupportedVideoStand: All
CDevFrontboard::CDevFrontboard()>>>>
!!!!!!!!!CPU usage : pid : 468 : irda_thread
!!!!!!!!!CPU usage : pid : 469 : keypad_thread
16:31:40|trace CThreadManager::CThreadManager()>>>>>>>>>
>>>>>>>>>>>>>has audio 1 , MatrixBoard has 0 loop, VNMatrixBoard has 0.
--------g_CapsEx.ForATM = 0----------
16:31:40|trace CTimerManager::CTimerManager()>>>>>>>>>
16:31:40|trace CDeviceManager::CDeviceManager()>>>>>>>>>
16:31:40|trace CDeviceManager::Start()>>>>>>>>>
Create alarm module ok......
16:31:40|trace CDevComm::CommOpen failure*******
16:31:40|info digital chn num:0
16:31:40|trace logic chn:8, max:32
16:31:40|trace CLocales::CLocales()>>>>>>>>>
SystemGetUILanguage g_iFlags = 0xffff06c5, ret <6>.
16:31:40|trace CConfigLocation::getLatest().iLanguage = 6.
16:31:40|trace CLocales::SetLanguage Load Strings File Failed! file path /mnt/cu stom/StringsRu.txt, and Load from Default Directory
16:31:40|trace CPacketManager::CPacketManager()>>>>>>>>>
16:31:40|trace Packet usage : 0K / 17000K, 0%
16:31:40|trace
----------------------[09-25 16:31:40]
==>CPacketManager: allocate buffer:0x00775F6C size:167936
LIBDVR : PtzOpen Successful, /dev/ttyAMA1
16:31:40|trace PreRecLen = 5666
LIBDVR : func:CaptureDevInit
LIBDVR : VIM_Init==>total chn:8, chn_num:8
LIBDVR : enable the vi device 0 ,it is in ViPubConfig
LIBDVR : enable the vi channel 0 , ViDev[0], ViChn[0], it is in ViChnConfig
LIBDVR : enable the vi channel 1 , ViDev[0], ViChn[1], it is in ViChnConfig
LIBDVR : enable the vi channel 2 , ViDev[0], ViChn[2], it is in ViChnConfig
LIBDVR : enable the vi channel 3 , ViDev[0], ViChn[3], it is in ViChnConfig
LIBDVR : enable the vi device 2 ,it is in ViPubConfig
LIBDVR : enable the vi channel 4 , ViDev[2], ViChn[0], it is in ViChnConfig
LIBDVR : enable the vi channel 5 , ViDev[2], ViChn[1], it is in ViChnConfig
LIBDVR : enable the vi channel 6 , ViDev[2], ViChn[2], it is in ViChnConfig
LIBDVR : enable the vi channel 7 , ViDev[2], ViChn[3], it is in ViChnConfig
LIBDVR : func:VEncChn_Init_General-chn:0
LIBDVR : VEncChn_Create-chn:0, type:0
LIBDVR : HI_MPI_VENC_CreateChn:0-type:0, venchn:0
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:0, venchn:0, VeGroup:0
LIBDVR : HI_MPI_VENC_GetFd:0x17
LIBDVR : VEncChn_Create-chn:0, type:1
LIBDVR : HI_MPI_VENC_CreateChn:0-type:1, venchn:1
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:1, venchn:1, VeGroup:0
LIBDVR : HI_MPI_VENC_GetFd:0x19
LIBDVR :
#########################AIM_StartAi#####AiDevId 0## s32AiChnCnt 8#############
LIBDVR : create aenc chn 1
LIBDVR : Ai(0,0) bind to AencChn:1 ok !
LIBDVR : func:VEncChn_Init_General-chn:1
LIBDVR : VEncChn_Create-chn:1, type:0
LIBDVR : HI_MPI_VENC_CreateChn:0-type:0, venchn:2
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:0, venchn:2, VeGroup:1
LIBDVR : HI_MPI_VENC_GetFd:0x26
LIBDVR : VEncChn_Create-chn:1, type:1
LIBDVR : HI_MPI_VENC_CreateChn:0-type:1, venchn:3
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:1, venchn:3, VeGroup:1
LIBDVR : HI_MPI_VENC_GetFd:0x27
LIBDVR : create aenc chn 2
LIBDVR : Ai(0,1) bind to AencChn:2 ok !
LIBDVR : func:VEncChn_Init_General-chn:2
LIBDVR : VEncChn_Create-chn:2, type:0
LIBDVR : HI_MPI_VENC_CreateChn:0-type:0, venchn:4
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:0, venchn:4, VeGroup:2
LIBDVR : HI_MPI_VENC_GetFd:0x2a
LIBDVR : VEncChn_Create-chn:2, type:1
LIBDVR : HI_MPI_VENC_CreateChn:0-type:1, venchn:5
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:1, venchn:5, VeGroup:2
LIBDVR : HI_MPI_VENC_GetFd:0x2b
LIBDVR : create aenc chn 3
LIBDVR : Ai(0,2) bind to AencChn:3 ok !
LIBDVR : func:VEncChn_Init_General-chn:3
LIBDVR : VEncChn_Create-chn:3, type:0
LIBDVR : HI_MPI_VENC_CreateChn:0-type:0, venchn:6
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:0, venchn:6, VeGroup:3
LIBDVR : HI_MPI_VENC_GetFd:0x2f
LIBDVR : VEncChn_Create-chn:3, type:1
LIBDVR : HI_MPI_VENC_CreateChn:0-type:1, venchn:7
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:1, venchn:7, VeGroup:3
LIBDVR : HI_MPI_VENC_GetFd:0x30
LIBDVR : create aenc chn 4
LIBDVR : Ai(0,3) bind to AencChn:4 ok !
LIBDVR : func:VEncChn_Init_General-chn:4
LIBDVR : VEncChn_Create-chn:4, type:0
LIBDVR : HI_MPI_VENC_CreateChn:0-type:0, venchn:8
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:0, venchn:8, VeGroup:4
LIBDVR : HI_MPI_VENC_GetFd:0x33
LIBDVR : VEncChn_Create-chn:4, type:1
LIBDVR : HI_MPI_VENC_CreateChn:0-type:1, venchn:9
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:1, venchn:9, VeGroup:4
LIBDVR : HI_MPI_VENC_GetFd:0x34
LIBDVR : create aenc chn 5
LIBDVR : Ai(0,4) bind to AencChn:5 ok !
LIBDVR : func:VEncChn_Init_General-chn:5
LIBDVR : VEncChn_Create-chn:5, type:0
LIBDVR : HI_MPI_VENC_CreateChn:0-type:0, venchn:10
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:0, venchn:10, VeGroup:5
LIBDVR : HI_MPI_VENC_GetFd:0x37
LIBDVR : VEncChn_Create-chn:5, type:1
LIBDVR : HI_MPI_VENC_CreateChn:0-type:1, venchn:11
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:1, venchn:11, VeGroup:5
LIBDVR : HI_MPI_VENC_GetFd:0x38
LIBDVR : create aenc chn 6
LIBDVR : Ai(0,5) bind to AencChn:6 ok !
LIBDVR : func:VEncChn_Init_General-chn:6
LIBDVR : VEncChn_Create-chn:6, type:0
LIBDVR : HI_MPI_VENC_CreateChn:0-type:0, venchn:12
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:0, venchn:12, VeGroup:6
LIBDVR : HI_MPI_VENC_GetFd:0x3b
LIBDVR : VEncChn_Create-chn:6, type:1
LIBDVR : HI_MPI_VENC_CreateChn:0-type:1, venchn:13
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:1, venchn:13, VeGroup:6
LIBDVR : HI_MPI_VENC_GetFd:0x3c
LIBDVR : create aenc chn 7
LIBDVR : Ai(0,6) bind to AencChn:7 ok !
LIBDVR : func:VEncChn_Init_General-chn:7
LIBDVR : VEncChn_Create-chn:7, type:0
LIBDVR : HI_MPI_VENC_CreateChn:0-type:0, venchn:14
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:0, venchn:14, VeGroup:7
LIBDVR : HI_MPhifb info: vo max resolution w:720 h:576
I_VENC_GetFd:0x3f
LIBDVR : VEncChn_Create-chn:7, type:1
LIBDVR : HI_MPI_VENC_CreateChn:0-type:1, venchn:15
LIBDVR : HI_MPI_VENC_RegisterChn:0, type:1, venchnhifb info: vo max resolution w:1024 h:768
:15, VeGroup:7
LIBDVR : HI_MPI_VENC_GetFd:0x40
LIBDVR : create aenc chn 8
LIBDVR : Ai(0,7) bind to AencChn:8 ok !
!!!!!!VencGetThread!!!CPU usage : pid : 478 : VencGetThread
vstd is 0
16:31:41|trace CFilterHelper::registerFilter had been register!!
SplitCreate - 105
LIBDVR : VOM_Init!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LIBDVR : Chip Single
16:31:41|trace CDevAudio(), Create Audio Device.
LIBDVR : MotionCapData pid:482
LIBDVR : BlindDetectCapData pid:483
LIBDVR : GraphicsCreate!!!!!!!!!!!!!!!!!!!!!!!
16:31:41|info Device Local Captures g_nCaptures = 8
16:31:41|info Device Logic Captures g_nLogicNum = 8
LIBDVR : @@@@@@@@@@@@@@@@@ 1622016,1408
16:31:41|trace ======CDevGraphics::UpdateSurface====================
16:31:41|trace mem = 0x41307000 0x00000000 0x00000000
16:31:41|trace pitch = 1408 width = 704 height = 576
foramt = 0======CDevGraphics::UpdateSurface====================
g_nPlay is 8
16:31:41|trace CGUI::Start()>>>>>>>>>
16:31:41|info rect.bottom, rect.left, rect.right, rect.top 576 0 704 0
16:31:41|trace Load string 'info_vga.switch' failed!!!
16:31:42|trace CAlarm::CAlarm()>>>>>>>>>
16:31:42|trace CDriverManager::CDriverManager()>>>>>>>>>
16:31:45|trace Load string 'conf_img.channel25' failed!!!
16:31:45|trace Load string 'conf_img.channel26' failed!!!
16:31:45|trace Load string 'conf_img.channel27' failed!!!
16:31:45|trace Load string 'conf_img.channel28' failed!!!
16:31:45|trace Load string 'conf_img.channel29' failed!!!
16:31:45|trace Load string 'conf_img.channel30' failed!!!
16:31:45|trace Load string 'conf_img.channel31' failed!!!
16:31:45|trace Load string 'conf_img.channel32' failed!!!
16:31:52|trace CGeneral::CGeneral()>>>>>>>>>
16:31:52|trace CGeneral::Start()>>>>>>>>>
16:31:52|trace ======CDevGraphics::UpdateSurface====================
16:31:52|trace mem = 0x41b98000 0x00000000 0x00000000
16:31:52|trace pitch = 1408 width = 704 height = 576
LIBDVR : dec_v_chn_create-chn:0, width:720, height:576
LIBDVR : dec_v_chn_create-chn:1, width:352, height:288
LIBDVR : dec_v_chn_create-chn:2, width:352, height:288
LIBDVR : dec_v_chn_create-chn:3, width:352, height:288
LIBDVR : dec_v_chn_create-chn:4, width:352, height:288
LIBDVR : dec_v_chn_create-chn:5, width:352, height:288
LIBDVR : dec_v_chn_create-chn:6, width:352, height:288
LIBDVR : dec_v_chn_create-chn:7, width:352, height:288
SystemGetVGAPixel VGA <3> 0:1080p, 1:1Data CRC f24a22aa != calculated CRC 7360cb 1e for node at 0003f558
280*1024, 2:1280*720, 3:1024*768, 4:800Data CRC f24a22aa != calculated CRC 7360 cb1e for node at 0003f558
*600
16:31:52|iData CRC f24a22aa != calculated CRC 7360cb1e for node at 0003f558
nfo Set Pixel(0Unable to handle kernel NULL pointer dereference at virtual addr ess 00000000
--1080p, 1--1280pgd = c1f18000
*1024, 2--720p, [00000000] *pgd=c24e20313--1024*768) typ, *pte=00000000e is 3.
pte=000000007;40m16:31:52|tr
ace CLog::CLog()Internal error: Oops: 817 [#1]
Modules linked in: crypt_ds28e01 usb_storage ahci reg_cmd gpio_i2c hii2c hi_wdt hi3515_adec(P) hi3515_aenc(P) hi3515_ao(P) hi3515_ai(P) hi3515_sio(P) hi3515_jpe gd(P) hi3515_jpege(P) hi3515_h264d(P) hi3515_h264e(P) hi3515_md(P) hi3515_vpp(P) hi3515_group(P) hi3515_venc(P) hi3515_vdec(P) hi3515_chnl(P) hi3515_viu(P) hi35 15_vou(P) hi3515_vd(P) hi3515_dsu(P) hi3515_sys(P) hi3515_base(P) tde(P) hifb(P) hidmac fb mmz
CPU: 0 Tainted: P (2.6.24-rt1-hi3515v100 #6)
PC is at jffs2_write_end+0x64/0x2a0
LR is at generic_file_buffered_write+0x18c/0x680
pc : [<c00eb57c>] lr : [<c005e8a8>] psr: 68000013
sp : c2665cc8 ip : 00000000 fp : c2665d18
r10: c2664000 r9 : c2c47388 r8 : 00000000
r7 : 00000000 r6 : c315b600 r5 : 00000000 r4 : c2c4735c
r3 : 00000040 r2 : c315b800 r1 : 00000000 r0 : c0350620
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 0005317f Table: c1f18000 DAC: 00000015
Process Sofia (pid: 461, stack limit = 0xc2664258)
Stack: (0xc2665cc8 to 0xc2666000)
5cc0: c100a9e0 00000000 c100a9e0 00000001 00000000 00000040
5ce0: 00000000 00000000 00000040 00000000 c025c6e8 00000040 00000000 00000000
5d00: 00000040 00000000 c2664000 c2665db0 c2665d1c c005e8a8 c00eb528 00000040
5d20: 00000040 c0350620 c2665d94 00001000 c2c0662c c2665f0c c2665d8c c2c47388
5d40: 00000001 00000001 c315b800 00000000 00000000 c025c6e8 c2c4741c c2c47388
5d60: c025c6e8 c2c4741c c247ebe0 c2665ea0 c2665d94 c0350620 c2665e98 00000001
5d80: 00000000 00000040 00000000 00000000 00000000 00000000 c247ebe0 c2665dec
5da0: c2664000 c2665e4c c2665db8 c005f440 c005e730 00000000 00000000 c2665ee8
5dc0: 00000040 00000000 c0092600 c2c06990 c300d220 00000000 c2c4741c c2665ee8
5de0: c2665e98 c2665ea0 00000040 00000000 00000000 00000040 00000001 c2665f70
5e00: c2665f4c c007af8c c0091794 c3090000 00000001 00000000 c247e360 c2665f0c
5e20: c3026300 c2665ea0 00000000 00000000 c2665ee8 c2c47388 c2665e98 c2c473f0
5e40: c2665e8c c2665e50 c005f648 c005f07c c2665e6c c2665e60 c2c4741c c247ebe0
5e60: 00000001 c2665ea0 c2665ee8 c247ebe0 c2665e98 c2665f78 00000000 00000000
5e80: c2665f50 c2665e94 c007bc08 c005f5e0 00000000 00000000 00fbdbb0 00000040
5ea0: 00000041 0065d38d 00000000 00000001 ffffffff c247ebe0 00000000 00000000
5ec0: 00000000 00000000 c3095420 00000000 00000000 c0137b60 c3095420 c0048ba8
5ee0: c2665ee0 c2665ee0 00000000 00000000 c0137b08 c2664000 00000041 00000041
5f00: 00000000 00000040 c316ec0c 00000041 00000000 c031c180 c01383f8 c2665f58
5f20: c2665f2c c007b484 00000040 c247ebe0 00fbdbb0 c007bb40 c2665f78 c2664000
5f40: 00484794 c2665f74 c2665f54 c007bd00 c007bb50 c247ec00 c247ebe0 c2665f78
5f60: 00000000 00000000 c2665fa4 c2665f78 c007be14 c007bc64 00000000 00000000
5f80: 00000001 00000040 00000050 00fbdbb0 00000004 c001efe4 00000000 c2665fa8
5fa0: c001ee40 c007bdd8 00000040 00000050 00000050 00fbdbb0 00000040 00000000
5fc0: 00000040 00000050 00fbdbb0 00000040 00000001 00000000 00484794 beab6b08
5fe0: be600000 beab6a0c 003b398c 004071e0 68000010 00000050 00000000 00000000
Backtrace:
[<c00eb518>] (jffs2_write_end+0x0/0x2a0) from [<c005e8a8>] (generic_file_buffere d_write+0x18c/0x680)
[<c005e720>] (generic_file_buffered_write+0x4/0x680) from [<c005f440>] (__generi c_file_aio_write_nolock+0x3d4/0x560)
[<c005f06c>] (__generic_file_aio_write_nolock+0x0/0x560) from [<c005f648>] (gene ric_file_aio_write+0x7c/0xfc)
[<c005f5d0>] (generic_file_aio_write+0x4/0xfc) from [<c007bc08>] (do_sync_write+ 0xc8/0x114)
[<c007bb40>] (do_sync_write+0x0/0x114) from [<c007bd00>] (vfs_write+0xac/0xf8)
[<c007bc54>] (vfs_write+0x0/0xf8) from [<c007be14>] (sys_write+0x4c/0x7c)
r8:00000000 r7:00000000 r6:c2665f78 r5:c247ebe0 r4:c247ec00
[<c007bdc8>] (sys_write+0x0/0x7c) from [<c001ee40>] (ret_fast_syscall+0x0/0x2c)
r8:c001efe4 r7:00000004 r6:00fbdbb0 r5:00000050 r4:00000040
Code: e5926150 e50b4034 e249402c e50b303c (058cc000)
end trace 39827ee973c511f0 ]---
[37;40m16:31:52|trace CLog::CLog() check failed, init...0,
Segmentation fault
Starting pid 494, console /dev/console: '/bin/sh'
Auto login as root ...
Sep 25 16:31:53 login[494]: root login on `ttyS000'
BusyBox v1.1.2 (2011.05.11-08:48+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
Welcome to HiLinux.
~ $ MMB LEAK(pid=461): 0xC4E44000, 8192 bytes, ''
mmz_userdev_release: mmb<0xC4E44000> mapped to userspace 0x410ce000 will be forc e unmaped!
MMB LEAK(pid=461): 0xC4F3E000, 8192 bytes, ''
mmz_userdev_release: mmb<0xC4F3E000> mapped to userspace 0x41102000 will be forc e unmaped!
MMB LEAK(pid=461): 0xC5038000, 8192 bytes, ''
mmz_userdev_release: mmb<0xC5038000> mapped to userspace 0x41136000 will be forc e unmaped!
MMB LEAK(pid=461): 0xC5132000, 8192 bytes, ''
mmz_userdev_release: mmb<0xC5132000> mapped to userspace 0x4116a000 will be forc e unmaped!
MMB LEAK(pid=461): 0xC522C000, 8192 bytes, ''
mmz_userdev_release: mmb<0xC522C000> mapped to userspace 0x4119e000 will be forc e unmaped!
MMB LEAK(pid=461): 0xC5326000, 8192 bytes, ''
mmz_userdev_release: mmb<0xC5326000> mapped to userspace 0x411d2000 will be forc e unmaped!
MMB LEAK(pid=461): 0xC5420000, 8192 bytes, ''
mmz_userdev_release: mmb<0xC5420000> mapped to userspace 0x41206000 will be forc e unmaped!
MMB LEAK(pid=461): 0xC551A000, 8192 bytes, ''
mmz_userdev_release: mmb<0xC551A000> mapped to userspace 0x4123a000 will be forc e unmaped!
DRAM: 128 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
enable usb error
cp - memory copy
exit - exit script
md - memory display
V-boot # printenv
bootdelay=3
baudrate=115200
bootfile="uImage"
filesize=1FBF2C
fileaddr=C0200000
console_debug=1
eeprom_exist=0
stdin=serial
stdout=serial
stderr=serial
verify=n
DRAM: 128 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
enable usb error
OK
Starting kernel ...
Machine: hi3515v100
TCP reno registered
phy:0:02
load vd.ko ....OK!
load vou.ko ....OK!
load vdec.ko ....OK
load vpp.ko ....OK!
load md.ko....OK!
load h264d.ko OK
eth0:
All OK
All OK
LIBDVR : | svn:.
rm Sofia from RAM
init at88() finish.
at88 init succ
DCR = 0xffffffeb
AAC1 = 0xffffffff
at88 crypeto failed
init at88() finish.
16:31:40|trace
LIBDVR :
I_VENC_GetFd:0x3f
:15, VeGroup:7
vstd is 0
SplitCreate - 105
g_nPlay is 8
*600
Backtrace:
Segmentation fault
Welcome to HiLinux.
- Sonya
Re: DVR. H.264 флэш s29gl064n90tf104 не коперует в DDR.
Тут урезанный загрузчик. Попробуйте, дайте команду flinfo
Прописваю команду чтоб считат в DDR и на этом и зависает.
Осторожнее, вы пытаетесь не в том направлении скопировать. 80040000 это адрес во флеш памяти, а не в ОЗУ. NOR флеш адресуется напрямую. Выполните tftp без параметров, он напишет стандартный адрес в ОЗУ
Команда flinfo
V-boot # flinfo
Bank # 1: CFI conformant FLASH (8 x
Size: 8 MB in 135 Sectors
AMD Standard command set, Manufacturer ID: 0x14, Device ID: 0x00
Erase timeout: 16384 ms, write timeout: 2 ms
Buffer write timeout: 5 ms, buffer size: 32 bytes
Sector Start Addresses:
80000000 80002000 80004000 80006000 80008000
8000A000 8000C000 8000E000 80010000 80020000
80030000 RO 80040000 80050000 80060000 80070000
80080000 80090000 800A0000 800B0000 800C0000
800D0000 800E0000 800F0000 80100000 80110000
80120000 80130000 80140000 80150000 80160000
80170000 80180000 80190000 801A0000 801B0000
801C0000 801D0000 801E0000 801F0000 80200000
80210000 80220000 80230000 80240000 80250000
80260000 80270000 80280000 80290000 802A0000
802B0000 802C0000 802D0000 802E0000 802F0000
80300000 80310000 80320000 80330000 80340000
80350000 80360000 80370000 80380000 80390000
803A0000 803B0000 803C0000 803D0000 803E0000
803F0000 80400000 80410000 80420000 80430000
80440000 80450000 80460000 80470000 80480000
80490000 804A0000 804B0000 804C0000 804D0000
804E0000 804F0000 80500000 80510000 80520000
80530000 80540000 80550000 80560000 80570000
80580000 80590000 805A0000 805B0000 805C0000
805D0000 805E0000 805F0000 80600000 80610000
80620000 80630000 80640000 80650000 80660000
80670000 80680000 80690000 806A0000 806B0000
806C0000 806D0000 806E0000 806F0000 80700000
80710000 80720000 80730000 80740000 80750000
80760000 80770000 80780000 80790000 807A0000
807B0000 807C0000 807D0000 807E0000 807F0000
V-boot #
Команда tftp показал адрес 0xc0008000, прописал cp.b 0xc0008000 0x00000000 0x008000000 так же зависает.
V-boot # tftp
MAC: 08-21-31-41-51-61
TFTP from server 192.168.1.39; our IP address is 192.168.1.177
Download Filename 'uImage'.
Download to address: 0xc0008000
Downloading: %T %
Abort
V-boot # cp.b 0xC0008000 0x00000000 0x00800000
Что я делаю не так?
V-boot # flinfo
V-boot #
V-boot # tftp
Downloading: %T %
Abort
Что я делаю не так?
Бывают такие реги, которые виснут, в соседней теме как раз описывал такую ситуацию... Не знаю, попробуйте меньшими блоками, не 8000000, а 400000, 1000000 и тд
Попробовал разнми блоками изменение нет, так же виснит. Прогромматор имею с переходником но хотелось слить с tftp. Может есть еще варианты?
После долгих манипуляции получилось считать дамп. Правильно ли я задал адреса?
V-boot # cp.b 0xc0008000 0x80040000 0x00800000
Полный лог.
DRAM: 128 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
enable usb error
Press CTRL-C to abort autoboot in V-boot # <INTERRUPT>
Copy to Flash... Outside available Flash
V-boot # tftp 0xc0008000 dump8.bin 0x00800000
TFTP to server 192.168.1.39; our IP address is 192.168.1.177
Upload Filename 'dump8.bin'.
Upload from address: 0xc0008000, 8.000 MB to be send ...
Uploading: %T %T %T %T %T %T %T %T %T %T %T %T %T %T %T %# [ Connected ]
################################ [ 2.888 MB]
################################ [ 5.752 MB]
8.000 MB upload ok.
V-boot #
Полный лог.
DRAM: 128 MB
Flash: 8 MB
In: serial
Out: serial
Err: serial
enable usb error
8.000 MB upload ok.
V-boot #
Outside available Flash.
Надо было cp.b 0x80000000 0xc0008000 0x800000; tftp 0xc0008000 dump8.bin 0x800000
Это если бэкап нужен.
Так тоже пробовал аппарат виснит.M - 16. писал(а):Outside available Flash.
Судя по всему, у вас есть консоль после загрузки рега, сделайте дамп на usb-флеш из линукса
В линуксе не силен. А самом деле апарат принесли на ремонт с программным дефектом, что не грузится до конца то есть черный экран. Вот и я хочу сделать бекап дампа чтоб не убить загрузчик перед экспериментами.
Вопрос, если даю адрес командой cp.b 0xc0008000 0x80040000 0x00800000 то загрузка происходит в ddr, если даю команду cp.b 0xc0008000 0x000000000 0x00800000 то загрузка не происходит и регистратор замерзает?
И почем начальный адрес флэши не с нуля начинается как в sf флэшах ? Например sf probe 0 sf read 0 800000.
