Помогите восстановить DS-2CD2T22WD-i5
y_nosulych
Камера постоянно уходит в ребут, Пробовал шить через TFTP, прошивкой с платформой R6 с оф. сайта хика. Ничего не меняется. Судя из лога ругается на DaVinci
y_nosulych
Re: Помогите восстановить DS-2CD2T22WD-i5
U-Boot 3.1.6-266633 (Mar 23 2017-10:04:37)
boards:234948
Boot From: NAND 2048 RC
SYS_CONFIG: 0x30064059 POC: 100
Cortex freq: 600000000
ENET freq: 50000000
iDSP freq: 240000000
Dram freq: 564000000
Core freq: 288000000
AHB freq: 144000000
APB freq: 72000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model:DS-2CD2T22WD-I5
Hit Ctrl+u to stop autoboot: 2
Hit Ctrl+u to stop autoboot: 1
Hit Ctrl+u to stop autoboot: 0
|RCV UDP pack timeout|
cmd 'null' is not supported.
nand booting ...
booting from pri part...
load kernel...
init started: BusyBox v1.19.3 (2019-01-10 15:07:37 CST)
starting pid 46, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
UBI device number 1, total 272 LEBs (34537472 bytes, 32.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi1_0.
pri_iUpgSuccCnt:1, sec_iUpgSuccCnt:1
UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi3_0.
Check dir /davinci ok! (0)
UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi4_0.
Check dir /config ok! (0)
diagnose_way = 15, repair_way = 1, interval = 60
route: ioctl 0x890c failed: No such process
Default method to init without VIN drivers...
Cat this file to find out what VIN can be supported.
Default init without lens driver
Use default settings
/home/script/init.sh: line 553: which: not found
[ 19.879896] [ kernel version: svn-374828 ]
map_size = 0x400000, nr_item = 3
addr_offset = 0x00000000, filename = orccode.bin
addr_offset = 0x00300000, filename = orcme.bin
addr_offset = 0x003a0000, filename = default_binary.bin
mmap returns 0x76a72000
loading /home/firmware/orccode.bin...addr = 0x76a72000, size = 0x171cca
loading /home/firmware/orcme.bin...addr = 0x76d72000, size = 0x51644
loading /home/firmware/default_binary.bin...addr = 0x76e12000, size = 0x40000
ucode (S2L) version = 2017/5/25 271820.271498
ln: prtLensCurve: File exists
ln: /dev/ttyS1: File exists
ln: /bin/t1: File exists
cp: can't stat '/dav/libutils.so': No such file or directory
chmod: /lib/libutils.so: No such file or directory
ln: /dev/rtc: File exists
=====check_config start=====
===db file doesn't exist===
==== both config files are broken====
infd read End
Unix bus 0 .
Enter DB_main-------------------
netprocess Infomation:
version: 8.11.3 [14:45:39-Jun 22 2018]
Path: /Camera/Platform/Trunk/FSP_network_protocol
Last Changed Rev: 404021
Last Changed Date: 2018-06-22 14:14:20 +0800 (Fri, 22 Jun 2018)
shared memory address is: 0x76c3d000, sizeof(DEVICECONFIG) = 1159944
wait davinci set default...
[01-03 19:49:32][pid:574][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-03 19:49:32][pid:581][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-03 19:49:32][pid:581][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-03 19:49:32][pid:581][UNI_IF][ERROR]communicaite_to_davinci failed!!!
copy default.cls ok.
[01-03 19:49:33][pid:574][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-03 19:49:33][pid:581][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-03 19:49:33][pid:581][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-03 19:49:33][pid:581][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-03 19:49:34][pid:574][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-03 19:49:34][pid:581][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-03 19:49:34][pid:581][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-03 19:49:34][pid:581][UNI_IF][ERROR]communicaite_to_davinci failed!!!
Unix bus End
shared memory address is: 0x76963000, sizeof(DEV_CAPABILITY) = 464336
[01-03 19:49:34][pid:595][HW_IF][ERROR]ioctl error errno=5
[01-03 19:49:34][pid:595][SYSINIT][ERROR]hwif_getsecinfo failed.
[01-03 19:49:34][pid:595][SYSINIT][ERROR]sys app init failed to reboot!
[01-03 19:49:35][pid:574][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-03 19:49:35][pid:581][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-03 19:49:35][pid:581][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-03 19:49:35][pid:581][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-03 19:49:36][pid:574][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-03 19:49:36][pid:581][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-03 19:49:36][pid:581][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-03 19:49:36][pid:581][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[ 30.782879] Restarting system.
[4l
boards:234948
ENET freq: 50000000
AHB freq: 144000000
APB freq: 72000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
nand booting ...
load kernel...
infd read End
Unix bus 0 .
Unix bus End
[4l
На сайте производителя есть программа для сброса пароля.
https://hikvision.org.ua/ru/articles/sp ... -hikvision
- VirtualLink
Лог восстановления прошивки?!
Снимай дамп!
Снимай дамп!
очень похоже на мою проблему.хоелось бы узнать чем дело закончилось
