Имеется IP-камера Honeywell H4D3PRV2. Перестала быть доступной.
Сняли, напрямую подключили к ПК. Есть только пинг на стандартный для Honeywell IP 192.168.1.108. По web нет доступа.
Просканировали nmap.
Код: Выделить всё
wpcap.dll present, library version: Npcap version 1.50, based on libpcap version 1.10.1-PRE-GIT
Starting Nmap 7.91 ( https://nmap.org ) at 2021-07-29 14:17 RTZ 2 (ceia)
--------------- Timing report ---------------
hostgroups: min 1, max 100000
rtt-timeouts: init 1000, min 100, max 10000
max-scan-delay: TCP 1000, UDP 1000, SCTP 1000
parallelism: min 0, max 0
max-retries: 10, host-timeout: 0
min-rate: 0, max-rate: 0
NSE: Using Lua 5.3.
NSE: Arguments from CLI:
NSE: Loaded 123 scripts for scanning.
NSE: Script Pre-scanning.
NSE: Starting runlevel 1 (of 2) scan.
NSE: Starting runlevel 2 (of 2) scan.
Packet capture filter (device eth2): arp and arp[18:4] = 0x10E7C60C and arp[22:2] = 0xC0C2
Overall sending rates: 8.33 packets / s, 350.00 bytes / s.
mass_rdns: Using DNS server 10.160.1.21
mass_rdns: Using DNS server 8.8.8.8
mass_rdns: 0.06s 0/1 [#: 2, OK: 0, NX: 0, DR: 0, SF: 0, TR: 1]
DNS resolution of 1 IPs took 0.06s. Mode: Async [#: 2, OK: 0, NX: 1, DR: 0, SF: 0, TR: 1, CN: 0]
Packet capture filter (device eth2): dst host 192.168.1.10 and (icmp or icmp6 or ((tcp or udp or sctp) and (src host 192.168.1.108)))
Overall sending rates: 868.68 packets / s, 38221.77 bytes / s.
Packet capture filter (device eth2): dst host 192.168.1.10 and (icmp or (tcp and (src host 192.168.1.108)))
NSE: Script scanning 192.168.1.108.
NSE: Starting address-info against 192.168.1.108.
NSE: Finished address-info against 192.168.1.108.
Nmap scan report for 192.168.1.108
Host is up (0.0018s latency).
Scanned at 2021-07-29 14:17:40 RTZ 2 (ceia) for 77s
Not shown: 65417 closed ports
PORT STATE SERVICE
1045/tcp filtered fpitp
1908/tcp filtered dawn
2714/tcp filtered raventdm
3404/tcp filtered unknown
3485/tcp filtered celatalk
3537/tcp filtered ni-visa-remote
3580/tcp filtered nati-svrloc
3700/tcp filtered lrs-paging
4658/tcp filtered playsta2-app
6431/tcp filtered unknown
6462/tcp filtered unknown
7084/tcp filtered unknown
7959/tcp filtered unknown
8362/tcp filtered unknown
8462/tcp filtered unknown
10873/tcp filtered unknown
11769/tcp filtered unknown
13168/tcp filtered unknown
13386/tcp filtered unknown
13531/tcp filtered unknown
13848/tcp filtered unknown
14962/tcp filtered unknown
16456/tcp filtered unknown
16884/tcp filtered unknown
17428/tcp filtered unknown
17549/tcp filtered unknown
19323/tcp filtered unknown
20736/tcp filtered unknown
21283/tcp filtered unknown
21927/tcp filtered unknown
22318/tcp filtered unknown
22332/tcp filtered unknown
22613/tcp filtered unknown
22810/tcp filtered unknown
23932/tcp filtered unknown
24512/tcp filtered unknown
25458/tcp filtered unknown
27046/tcp filtered unknown
27434/tcp filtered unknown
28315/tcp filtered unknown
28750/tcp filtered unknown
28809/tcp filtered unknown
28917/tcp filtered unknown
28928/tcp filtered unknown
29046/tcp filtered unknown
29576/tcp filtered unknown
30161/tcp filtered unknown
30360/tcp filtered unknown
30431/tcp filtered unknown
30492/tcp filtered unknown
30991/tcp filtered unknown
31877/tcp filtered unknown
32171/tcp filtered unknown
32307/tcp filtered unknown
35203/tcp filtered unknown
35878/tcp filtered unknown
36097/tcp filtered unknown
37301/tcp filtered unknown
37756/tcp filtered unknown
37821/tcp filtered unknown
38193/tcp filtered unknown
38703/tcp filtered unknown
38867/tcp filtered unknown
38984/tcp filtered unknown
39159/tcp filtered unknown
39881/tcp filtered unknown
40076/tcp filtered unknown
40134/tcp filtered unknown
40723/tcp filtered unknown
41118/tcp filtered unknown
41257/tcp filtered unknown
41433/tcp filtered unknown
41585/tcp filtered unknown
42318/tcp filtered unknown
42919/tcp filtered unknown
43070/tcp filtered unknown
43294/tcp filtered unknown
44151/tcp filtered unknown
44169/tcp filtered unknown
44199/tcp filtered unknown
44235/tcp filtered unknown
44698/tcp filtered unknown
44715/tcp filtered unknown
45641/tcp filtered unknown
45956/tcp filtered unknown
47319/tcp filtered unknown
47361/tcp filtered unknown
48289/tcp filtered unknown
49064/tcp filtered unknown
50744/tcp filtered unknown
52040/tcp filtered unknown
52072/tcp filtered unknown
52902/tcp filtered unknown
52990/tcp filtered unknown
53317/tcp filtered unknown
54261/tcp filtered unknown
54408/tcp filtered unknown
54503/tcp filtered unknown
54903/tcp filtered unknown
56632/tcp filtered unknown
57233/tcp filtered unknown
57317/tcp filtered unknown
58482/tcp filtered unknown
58686/tcp filtered unknown
59857/tcp filtered unknown
60514/tcp filtered unknown
61277/tcp filtered unknown
62467/tcp filtered unknown
62702/tcp filtered unknown
62837/tcp filtered unknown
63041/tcp filtered unknown
63105/tcp filtered unknown
63163/tcp filtered unknown
64039/tcp filtered unknown
64221/tcp filtered unknown
64317/tcp filtered unknown
64424/tcp filtered unknown
64922/tcp filtered unknown
MAC Address: 00:1F:55:2D:0C:1E (Honeywell Security (China))
Too many fingerprints match this host to give specific OS details
TCP/IP fingerprint:
SCAN(V=7.91%E=4%D=7/29%OT=%CT=1%CU=33649%PV=Y%DS=1%DC=D%G=N%M=001F55%TM=61028EA1%P=i686-pc-windows-windows)
SEQ(CI=I%II=I)
T5(R=Y%DF=Y%T=40%W=0%S=Z%A=S+%F=AR%O=%RD=0%Q=)
T6(R=Y%DF=Y%T=40%W=0%S=A%A=Z%F=R%O=%RD=0%Q=)
T7(R=Y%DF=Y%T=40%W=0%S=Z%A=S+%F=AR%O=%RD=0%Q=)
U1(R=Y%DF=N%T=40%IPL=164%UN=0%RIPL=G%RID=G%RIPCK=G%RUCK=G%RUD=G)
IE(R=Y%DFI=N%T=40%CD=S)
Network Distance: 1 hop
Final times for host: srtt: 1769 rttvar: 1794 to: 100000
NSE: Script Post-scanning.
Read from C:\Program Files (x86)\Nmap: nmap-mac-prefixes nmap-os-db nmap-payloads nmap-services.
OS detection performed. Please report any incorrect results at https://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 79.02 secondsПодскажите, пожалуйста, в правильном ли я направлении мыслю? Может, у кого-то был опыт решения подобной проблемы?
Заранее благодарю за помощь!
