Сброс пароля на Hikvision DS-7116HQHI-K1
Diypro
Сообщение Diypro » 27 июн 2024, 17:15
Гибридный рег DS-7116HQHI-K1, пароль неизвестен, есть возможность сбрасывать в официальном сервисе своего региона но сервис отказал т.к. рег не нашего региона. Загрузчик не понимают команду UPF но понимает U либо UPDATE, однако прошивка скачивается с TFTP сервера и далее следует ошибка:
Код: Выделить всё
Hit ctrl+u to stop autoboot:  0
HKVS $ setenv ';u'
using update v3...
### CRAMFS load complete: 4415536 bytes loaded to 0x42000000
the uImage support update_v3.
   Verifying RSA ... OK
## Booting kernel from Legacy Image at 42000000 ...
   Loading Kernel Image ... OK
OK
Starting kernel ...
[    4.843088] init(1) called reboot syscall, cmd: 0x0.
Thu Jan  1 00:00:04 UTC 1970
mv: can't rename 'ubi*': No such file or directory
Starting udev:      [ OK ]
Jun 21 17:55:15 udevd-work[125]: kernel-provided name 'sdb' and NAME= 'sda' disagree, please use SYMLINK+= or change the kernel to provide the proper name
Jun 21 17:55:15 udevd-work[127]: kernel-provided name 'sdb3' and NAME= 'sda3' disagree, please use SYMLINK+= or change the kernel to provide the proper name
Jun 21 17:55:15 udevd-work[126]: kernel-provided name 'sdb2' and NAME= 'sda2' disagree, please use SYMLINK+= or change the kernel to provide the proper name
Jun 21 17:55:15 udevd-work[125]: kernel-provided name 'sdb1' and NAME= 'sda1' disagree, please use SYMLINK+= or change the kernel to provide the proper name
This program will download and upgrade software.
*  ATTENTION!! PLEASE READ THIS NOTICE CAREFULLY!     *
*  Don't reset machine,or anything that interrupt it. *
*  The upgrade process must finish in 10 minutes!     *
*  If this program fails,machine might be unusable,   *
*  and you will need to reflash again.                *
*  If you find this too risky,power off machine now.  *
waiting for net_link [10]...
waiting for net_link [9]...
[    9.238210] hi_gmac_v200 100a0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
ftp server not exit[-111]!
tftp transmit over,file size[8192][ 0.008 MB].
################################        [ 8.000 MB]
################################        [16.000 MB]
################################        [24.000 MB]
################################        [32.000 MB]
################################        [40.000 MB]
################################        [48.000 MB]
################################        [56.000 MB]
tftp transmit over,file size[61562988][58.728 MB].
mmap failed.
 failed(-14)!
Press ENTER key to reboot
посоветуйте, что можно предпринять
Re: Сброс пароля на Hikvision DS-7116HQHI-K1
Сообщение GenaSPB » 28 июн 2024, 00:42
Запросить сброс на глобальном Hikvision или у индусов им ваще фиолетово для какого рынка железка.
Сообщение oleglevsha » 28 июн 2024, 11:55
Diypro писал(а):
27 июн 2024, 17:15
Код: Выделить всё
HKVS $ setenv ';u'
using update v3...
OK
Starting kernel ...
mmap failed.
 failed(-14)!
прошивка не та
Diypro
Сообщение Diypro » 01 июл 2024, 17:39
GenaSPB писал(а):
28 июн 2024, 00:42
Подскажите куда именно писать
Diypro
Сообщение Diypro » 01 июл 2024, 17:42
oleglevsha писал(а):
28 июн 2024, 11:55
прошивка не та
[/quote]
Пробовал 3 прошивки, с российского FTP, с европейского и с глобального сайта. Все одно. Предложите правильную
Сообщение oleglevsha » 05 июл 2024, 19:57
Diypro
Сообщение Diypro » 08 июл 2024, 13:57
Сбросил через глобальную поддержку хика. Спасибо всем кто откликнулся
