Need Dump file: DVR Chasis: "H2_ V_2.2N /2010/12/1"
Hi.
I need flash dump for this dvr.
thanks.
thanks.
Re: Need Dump file: DVR Chasis: "H2_ V_2.2N /2010/12/1"
Why do you need it, whats wrong with dvr atm? UART console logs?
hangs on logo then restarts.
I have current flash dump. I can upload if it helps.
There is a 4 pin that could be UART, but I don't have the firmware.
There is nothing helpful on device, no label, no brand, no model.
Upload it, also connect UART and attach boot log
You can try erasing last 128KB... but i dont think that will help. It seems that JFFS2 that holds system modules is corrupt and this board is nothing i have seen before...
Anyway, post boot log, it might help.
- VirtualLink
Better console log, as already said dede!
I put the IC back to try serial console.
But it doesn't show logo anymore. It doesn't restart.
and no console output.
Well, check soldering quality also maybe you've overheated flash memory during soldering.
