Нужна прошивка Optimus dvr-2008e
Alexander1990
Re: Нужна прошивка Optimus dvr-2008e
Вот что получилось
U-Boot 2010.06-svn109 (Jun 07 2013 - 09:54:25)
DRAM: 256 MiB
Spi(cs1): Block:64KB Chip:16MB Name:"W25Q128B"
envcrc 0x98806965
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
Hisilicon ETH net controler
Press CTRL-C to abort autoboot in 0 seconds16384 KiB hi_sfc at 0:0 is now current device
CFG_BOOT_ADDR:0x58080000
0ff:0x84000000
### boot load complete: 2798716 bytes loaded to 0x82000000
### SAVE TO 80008000 !
Image Name: linux
Data Size: 2798652 Bytes = 2.7 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
DRAM: 256 MiB
envcrc 0x98806965
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
Press CTRL-C to abort autoboot in 0 secondshisilicon # printenv
Unknown command 'зк▒printenv' - try 'help'
bootcmd=lload;sf probe 0;sf read 84000000 80000 400000;fload 84000000;bootm 0x82000000
bootdelay=1
baudrate=115200
bootfile="uImage"
da=tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
du=tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
up=tftp 0x82000000 update.img;sf probe 0;flwrite
tk=tftp 0x82000000 zImage.img; bootm 0x82000000
dd=tftp 0x82000000 mtd-x.jffs2.img;sf probe 0;flwrite
filesize=286C4
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.0.0
gatewayip=192.168.0.1
ethaddr=00:0b:3f:00:00:01
bootargs=mem=64M console=ttyAMA0,115200 root=1f01 rootfstype=cramfs mtdparts=hi_sfc:512K(boot),4M(romfs),5632K(usr),1536K(web),3M(custom),256K(logo),1280K(mtd)
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn109 (Jun 07 2013 - 09:54:25)
Environment size: 1004/262140 bytes
hisilicon #
DRAM: 256 MiB
envcrc 0x98806965
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
0ff:0x84000000
Image Name: linux
OK
Starting kernel ...
DRAM: 256 MiB
envcrc 0x98806965
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
bootdelay=1
baudrate=115200
bootfile="uImage"
filesize=286C4
ipaddr=192.168.1.10
netmask=255.255.0.0
stdin=serial
stdout=serial
stderr=serial
verify=n
hisilicon #
- Fluffykrsk
Особо секретное FAQ. Кидается в каждой теме на форуме
Так и не нашёл в своё время толковый словарь с расшифровками этих письмён и как в них разбираться правильно, ну или какой-то адекватной инфы по которой можно было бы прокачаться.
А вообще, теперь неплохо было бы найти мастера чтения логов тут, и спросить чего там пишет, означают ли письмена в консоле, что загрузчик встал ровно? Я то в этом плохо разбираюсь в письменах. Но, то что пишет хоть чото это хорошо, это я понимаюAlexander1990 писал(а): da=tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
Alexander1990
ладно будем пробовать что нибудь
Alexander1990
Все вопрос решён! 1. Замена неисправной флеш памяти.
2. Залив дампа от пользователя fobos. 3. Обновление прошивки через usb флешку (обновление с официального сайта).
- Fluffykrsk
Ладно, хорошо. Так и запишем)))). Всё же любопытно, какая по итогу версия прошивки стала в "сведениях" в меню рега, после обновления через USB.Alexander1990 писал(а):Все вопрос решён! 1. Замена неисправной флеш памяти.
117-яFluffykrsk писал(а):Ладно, хорошо. Так и запишем)))). Всё же любопытно, какая по итогу версия прошивки стала в "сведениях" в меню рега, после обновления через USB.Alexander1990 писал(а):Все вопрос решён! 1. Замена неисправной флеш памяти.
- Fluffykrsk
А.. ну в принципе логично. Вспомнил, что на сайте Оптимуса оно подписано было, как AHB7004T-EL, это типа "новая" должна быть, т.е 117-я.fobos писал(а):117-я
В вашем дампе u-boot отличался, похоже я не угадал с процессором или более старая версия матери попалась.... Чего-то вон логи писали, но не дали через USB обновиться ему... Где-то косяк был. Буду теперь пол ночи ворочаться, думать где лоханулся...
Alexander1990
Всем спасибо за помощь.
- а можно попросить перезалить дамп, а то ссылка дохлая.. абсолютно та же проблема что и у топикстартера.fobos писал(а): ↑07 апр 2019, 00:49Alexander1990 пробуйте https://cloud.mail.ru/public/pvvm/5z6XwNPo3" onclick="window.open(this.href);return false; потом можно накатить optimus
Помогите! Нужна прошивка!!! Помогите пожалуйста!!!!!!
А это прошивка подойдет для этой платы платы T4-3520D-v1.02 20130816. Флеш память 25FL064.
