Помогите с прошивкой камеры Dahua IPC HFW2201R-VF
Danakkroid
Сообщение Danakkroid » 17 ноя 2025, 21:26
Камера циклически перезагружается , вот лог файл
U-Boot 2010.06-svn2362 (Dec 30 2014 - 05:34:29)
DRAM: 256 MiB
reset/hold pin now is RESET
Spi(cs1): Block:64KB Chip:16MB Name:"W25Q128B"
boot from spi
partition file version 2
rootfstype squashfs root /dev/mtdblock7
In: serial
Out: serial
Err: serial
TEXT_BASE:81000000
Hisilicon ETH net controler
MAC: 4C-11-BF-99-94-07
UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Download Filename 'upgrade_info_7db780a713a4.txt'.
Download to address: 0x84000000
Downloading:
Retry count exceeded; starting again
Fail to get info file!
Init error!
miiphy_register: non unique device name '0:0'
miiphy_register: non unique device name '0:2'
Download Filename 'failed.txt'.
Download to address: 0x82000000
Downloading:
SPI probe: 16384 KiB hi_sfc at 0:0 is now current device
Image Name: Linux-3.0.8
Data Size: 1372744 Bytes = 1.3 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ...OK
OK
cmdLine mem=77M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
Starting kernel ...
DRAM: 256 MiB
boot from spi
In: serial
Out: serial
Err: serial
TEXT_BASE:81000000
Downloading:
Init error!
Downloading:
OK
Starting kernel ...
Danakkroid
Re: Помогите с прошивкой камеры Dahua IPC HFW2201R-VF
Сообщение Danakkroid » 17 ноя 2025, 21:27
printenv
bootdelay=1
baudrate=115200
ipaddr=192.168.1.108
serverip=192.168.1.1
gatewayip=192.168.1.1
netmask=255.255.255.0
bootfile="uImage"
wifiaddr=00:12:34:56:78:91
dh_keyboard=1
appauto=1
loglevel=4
BSN=1C039D5PAQ00025
HWID=IPC-HFW2201R-VF:01:02:02:12:13:0B:01:00:00:00:04:1B8:00:00:02:00:00:00:00:00:80
icrtype=1
devalias=IPC-HFW2201R-VFS
ID=1C03704PAW00027
ethaddr=4C:11:BF:99:94:07
filesize=BD77A9
fileaddr=82000000
da=tftp 0x82000000 dhboot.bin.img;flwrite;tftp 0x82000000 dhboot-min.bin.img;flwrite;
dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite;
dk=tftp 0x82000000 kernel.img;flwrite;
du=tftp 0x82000000 user-x.squashfs.img; flwrite
dw=tftp 0x82000000 web-x.squashfs.img; flwrite
dp=tftp 0x82000000 partition-x.cramfs.img;flwrite;
dc=tftp 0x82000000 custom-x.squashfs.img; flwrite
up=tftp 0x82000000 update.img;flwrite;
tk=tftp 0x82000000 uImage;bootm;
bootcmd=sf read 0x82000000 0x180000 0x280000;bootm 0x82000000;
bootargs=mem=77M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn2362 (Dec 30 2014 - 05:34:29)
Environment size: 1101/262140 bytes
fobos
Сообщение fobos » 18 ноя 2025, 22:54
покажите полный лог загрузки, чтобы увидеть на чем крашится
