Falcon Eye FE-0216DE заставка
Добрый день! Регистратор висит на цветных полосах. Скиньте, пожалуйста, прошивку или дамп флеши на данный рег, если есть. Логи help&printenv
hisilicon # help
? - alias for 'help'
boot - boot default, i.e., run 'bootcmd'
bootd - boot default, i.e., run 'bootcmd'
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
fload - fload - load binary file from a filesystem image for system boot
flwrite - SPI flash sub-system
lip - lip - set local ip address but not save to flash
lload - lload - load logo file
md - memory display
mii - MII utility commands
mw - memory write (fill)
run - run commands in an environment variable
sf - SPI flash sub-system
sip - sip - set server ip address but not save to flash
squashfsload- fsload - load binary file from a filesystem image
usb - USB sub-system
hisilicon # printenv
bootcmd=lload;fload;bootm 0x82000000
bootdelay=1
baudrate=115200
bootfile="uImage"
da=mw.b 0x82000000 ff 1000000;tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
up=mw.b 0x82000000 ff 1000000;tftp 0x82000000 update.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
dd=mw.b 0x82000000 ff 1000000;tftp 0x82000000 mtd-x.jffs2.img;sf probe 0;flwrite
netmask=255.255.0.0
gatewayip=192.168.0.1
ethaddr=00:0b:3f:00:00:01
bootargs=mem=120M console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=cramfs mtdparts=hi_sfc:512K(boot),4M(romfs),5632K(user),1536K(web),3M(custom),256K(logo),1280K(mtd)
ipaddr=192.168.0.110
serverip=192.168.0.102
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn104 (Sep 07 2013 - 16:29:50)
Environment size: 1197/262140 bytes
hisilicon #
hisilicon # help
cp - memory copy
md - memory display
bootdelay=1
baudrate=115200
bootfile="uImage"
netmask=255.255.0.0
stdin=serial
stdout=serial
stderr=serial
verify=n
hisilicon #
Re: Falcon Eye FE-0216DE заставка
Вам нужно узнать модель платы, для этого нужно слить дамп с вашего регистратора, ну или плату осмотреть
фото платы https://cloud.mail.ru/public/8bXn/M2CFK2rqD" onclick="window.open(this.href);return false;
дамп https://cloud.mail.ru/public/Mu7V/kGNFM5vND" onclick="window.open(this.href);return false;
Попробуйте эти
https://pan.sohu.net/f/MTY3NDgsaGRpbXU.htm" onclick="window.open(this.href);return false;
https://pan.sohu.net/f/MTY3NjEsaGRpZGg.htm" onclick="window.open(this.href);return false;
Регистратор вроде ХМ, но что вы туда заливали, почему только цветные полосы?
поступил в таком виде...пытаюсь восстановитьoleglevsha писал(а):Регистратор вроде ХМ, но что вы туда заливали, почему только цветные полосы?
В дампе только custom-x.cramfs.img в нормальном виде, остальное непонятно что.
Не знаю, может для Falcon используется шифрование, но я не понимаю тогда почему custom-x.cramfs.img не шифрован...
Есть два варианта восстановления, пересобрать дамп, или используя консоль восстановить прошивку нормальными образами user-x.cramfs.img, romfs-x.cramfs.img, web-x.cramfs.img...
На форуме информации по этому поводу полно.
Да всё там есть, просто заголовки повреждены. И никакого шифрования там и близко быть не может, всё что Falcon может, так это свои логотипы клеить, ну и там, иконки поменять
fobos, от 6504E не подошла?
по обеим Вашим ссылкам закачка идет со скоростью 6-10кб/с и на 1/3 обрывается...буду еще пробовать, пока не закачаю. По результату обязательно отпишусь.
https://ufile.io/0xsx8" onclick="window.open(this.href);return false;
https://ufile.io/ar2qz" onclick="window.open(this.href);return false;
лог после поблочной прошивке MBD6405E
DRAM: 256 MiB
boardvalue: 0x0
Check spi flash controller v300. found
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
Spi(cs1): Block:64KB Chip:16MB Name:"MX25L128"
envcrc 0x3dd6b2b3
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
PHY 0x02: OUI = 0x01F0, Model = 0x0F, Rev = 0x01
MAC: 00-0B-3F-00-00-01
user init finish.
Press CTRL-C to abort autoboot in 0 secondsCFG_BOOT_ADDR:0x58080000
cramfs: wrong magic
### boot/zImage.img LOAD ERROR<ffffffff> !
Image Name: linux
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 4194240 Bytes = 4 MiB
Load Address: 00080000
Entry Point: 00480000
Uncompressing Kernel Image ... Error: Bad gzipped data
GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to recover
resetting ...
и циклично...
DRAM: 256 MiB
boardvalue: 0x0
envcrc 0x3dd6b2b3
ENV_SIZE = 0x3fffc
In: serial
Out: serial
Err: serial
user init finish.
cramfs: wrong magic
Image Name: linux
resetting ...
и циклично...
