Балуюсь в поисках
sergvl
Re: Балуюсь в поисках
Попробуй установить это http://www.jufenginfo.com/download-deta ... 7-269.html" onclick="window.open(this.href);return false;
- pelentron
171 прошивка без доп микрухи.
под 171 от jufeng сразу поставлен, давно. ибо больше нравится =)
под 194 ничего не делали =(
- pelentron
Код: Выделить всё
hisilicon # printenv
bootcmd=sf probe 0;sf read 0x84000000 0xf60000 0x20000;logoload 0x84000000;decjpg;sf read 0x82000000 0x50000 0x500000;squashfsload 82000000;bootm 0x82000000
bootdelay=1
baudrate=115200
ethaddr=00:0b:3f:00:00:01
ipaddr=192.168.1.10
serverip=192.168.1.12
netmask=255.255.0.0
gatewayip=192.168.1.1
bootfile="uImage"
da=mw.b 0x82000000 ff 1000000;tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
up=mw.b 0x82000000 ff 1000000;tftp 0x82000000 update.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
dd=mw.b 0x82000000 ff 1000000;tftp 0x82000000 mtd-x.jffs2.img;sf probe 0;flwrite
bootargs=mem=80M console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=squashfs mtdparts=hi_sfc:320K(boot),3968K(romfs),7104K(usr),1536K(web),2816K(custom),128K(logo),512K(mtd) coherent_pool=2M
appVideoStandard=PAL
appSystemLanguage=Russian
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06 (Jan 14 2017 - 11:24:40)
Environment size: 1377/65532 bytes
hisilicon # sf probe 0
16384 KiB hi_fmc at 0:0 is now current device
hisilicon # run up
PHY 0x02: OUI = 0x01F0, Model = 0x0F, Rev = 0x01
change register for 8710
PHY reg: 0x12, value:0x62
CONFIG MII
ETH0: PHY(phyaddr=2, mii) link UP: DUPLEX=FULL : SPEED=100M
MAC: 00-0B-3F-00-00-01
TFTP from server 192.168.1.12; our IP address is 192.168.1.10
Download Filename 'update.img'.
Download to address: 0x82000000
Downloading: # [ Connected ]
################################ [ 1.000 MB]
################################ [ 2.000 MB]
################################ [ 3.000 MB]
################################ [ 4.000 MB]
################################ [ 5.000 MB]
################################ [ 6.000 MB]
################################ [ 7.000 MB]
################################ [ 8.000 MB]
################################ [ 9.000 MB]
################################ [10.000 MB]
################################ [11.000 MB]
################################ [12.000 MB]
################################ [13.000 MB]
################################ [14.000 MB]
################################ [15.000 MB]
################################ [16.000 MB]
done
Bytes transferred = 16777216 (1000000 hex)
PACK_ID error
DestAddr invalid!
DestAddr: 0x00000000~0x2000000Re: Балуюсь в поисках
Вы что, просто дамп переименовали в update.img и пытаетесь залить в рег?
- pelentron
я прашивал выше, что ищу что делать с дампом для залития его обратно..... но пока не нашёл ничего.dede писал(а):Вы что, просто дамп переименовали в update.img и пытаетесь залить в рег?
У вас все нормально с головой?
несколько страниц монолога ни о чем:)
Читай форум, все разжевали давно и на все ваши вопросы уже даны ответы.
- pelentron
oleglevsha писал(а):У вас все нормально с головой?
не разжевано. ибо пытался сделать некий ФАК или типа того, шапками забросали. везде по крупицам, а чтобы более мнее в одном месте, такого нет. поэтому и пишу для себя же, в виде монолога. часть вопросов оставлены без ответа. а в наличии некоторых режимов не верили, а они есть и работают. а раз уж так нервно, то ткните носом, про создание дампа для заливки обратно. про клонирование одинаковых плат с разным ПО. А я тогда в своём монологе распишу пошагово. чего делать.
Параллельно общаюсь с заводом. для меня там прошивку готовят. с моими хотелками, под старые регистраторы. впринципе и SDK могут дать, только что с ним делать. я и старый SDK не видел. все его только хают, но не дают.
В новых камерах от ХМ есть интеллигентная функция, вот скрины.
- pelentron
в AHD нет такого. только на регистраторах. и то не на всех. это и непонятно - почему.kROOT писал(а):В новых камерах от ХМ есть интеллигентная функция, вот скрины.
по ip много вопросов.
возможность управления камерами с регистратора - вроде нет такого. заходить с мобилы на каждую камеру - не гуманно.
цена выше.
визуально подключать проще и красиво, но спец инструмент нужен.
первоначальная настройка дачникам сложна =)
пример, валятся письма на емейл по движению с дома. редко. но если приехали рабочие , зачем получать столько писем. залез мобилкой, галочку одну убрал на регистраторе, и всё ок. пишь по движению, но писем не шлёт. с ip это в каждую камеру лезть, а с мобилы это проблема.
пару ip камер от ХМ я хочу прикупить, для изучения. ибо надо понять чем так лучше ip . но пока из того что у меня, всё печально. дорогая sony оказалось полным г, самый дешовый кЕтай не ХМ , не плох, но управлять с регистратора не получилось. и на работе стоят камеры в моём доступе, тоже как то не орошает. да ещё и детекцию движения надо на каждой камере крутить. что в моём варианте не вариант.
пока AHD!!!
- pelentron
и как и всё от ХМ, порой сложно угадать, где есть какая функция. =)
Похоже вы их порядочно достали.pelentron писал(а):Параллельно общаюсь с заводом. для меня там прошивку готовят. с моими хотелками, под старые регистраторы. впринципе и SDK могут дать, только что с ним делать. я и старый SDK не видел. все его только хают, но не дают.oleglevsha писал(а):У вас все нормально с головой?
Читай форум, все разжевали давно и на все ваши вопросы уже даны ответы.![]()
Завод ничего не будет менять просто так, только для крупного клиента.
Удивительно что они что то вам обещали и будут удовлетворять ваши хотелки.
Для чего они тогда разделили одну ревизию платы на разные модели с различным функционалом, подумайте на досуге...
Я бы не стал утверждать, что все разжевано, если бы не знал наверняка.
- pelentron
ревизии плат - разные наборы качества. гдето 1080n, гдето 4Мр, функционал одинаков. просто новые фичи забывают добавлять . т.к. теже отсылка фото на емейл, мало кому нужно.oleglevsha писал(а):pelentron писал(а):Завод ничего не будет менять просто так, только для крупного клиента.oleglevsha писал(а):У вас все нормально с головой?
7004/7008/7016 — это главная/основная разработка
7804/7808/7816 — это эконом вариант
R — 1/2 жестких диска)
Т — 1/2/4 жестких диска)
H — (4/8 жестких диска)
F — (2/4/8 жестких диска )
LM =720P&1080N,
MH =1080P non realtime,
H =1080P real time.
GS =3.0M@10FPS&4.0M@8FPS ,
GL =3.0M@18FPS&4.0M15FPS&5.0@11FPS.
G =3.0M@30FPS&4.0M@25FPS&5.0M@18FPS
(http://imatra.ru/opisanie-i-rasshifrov ... rn false;)
