Fakeoke
Сообщение Fakeoke » 12 окт 2020, 08:01
еще столкнулся вот с чем когда начал шить через юарт
Код: Выделить всё
** Partition 1 not valid on device 0 **
Unable to use mmc 1 for fatls
error:read from mmc.
error: upfsd.
HKVS #
это флешка не подходит или камера рип?
Fakeoke
Сообщение Fakeoke » 12 окт 2020, 09:06
нашел дамп в инете, залил... потом подержал ресет через WPS к вафле подрубился... вот какие то логи мало ли помогут кому
Код: Выделить всё
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.10.12 10:07:38 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot 2010.06-189285 (Apr 18 2016 - 18:06:24)
DRAM:  128 MiB
Flash: 16 MiB
MMC:   MID:0x12 RBlock:512 WBlock:512 Chip:7624MB Name:"SDSD:   Ver:2.0 High Capacity Speed:25000000Hz Bus Width:4bit
Hit Ctrl+u to stop autoboot:  3  2  1  0
Up/Down PHY not link.
TFTP server auto connect disabled
load kernel to 0x80007fc0 ... Done!
## Booting kernel from Legacy Image at 80007fc0 ...
   Image Name:   Linux-3.0.8
   Data Size:    3502244 Bytes = 3.3 MiB
   Load Address: 80008000
   Entry Point:  80008000
   XIP Kernel Image ... OK
OK
Starting kernel ...
шStarting udev:      [ OK ]
diagnose_way = 14, repair_way = 0, interval = 60
route: ioctl 0x890c failed: No such process
ifconfig: SIOCSIFADDR: No such device
cp: can't stat '/dav/libhikosip.so.lzma': No such file or directory
cp: can't stat '/dav/libosip2.so.lzma': No such file or directory
cp: can't stat '/dav/libosipparser2.so.lzma': No such file or directory
chmod: /dav/libcrypto.so: Read-only file system
lzma: libhikosip.so.lzma: No such file or directory
lzma: libosip2.so.lzma: No such file or directory
lzma: libosipparser2.so.lzma: No such file or directory
chmod: /home/applib/libosip2.so: No such file or directory
chmod: /home/applib/libosipparser2.so: No such file or directory
chmod: /home/applib/libhikosip.so: No such file or directory
/home
ln: setAgingMode: File exists
ln: getAgingMode: File exists
ln: setAgingTime: File exists
ln: getAgingTime: File exists
chmod: /bin/prtLockList: Read-only file system
Insmod ko start...
mv: can't rename 'r2_modules/8192cu.ko': No such file or directory
insmod: can't insert '/home/ipc_stm8.ko': unknown symbol in module, or unknown parameter
Insmod ko end...
Press Ctrl-C to stop ...
Enter DB_main-------------------
shared memory address is: 0x403fa000, sizeof(DEVICECONFIG) = 887608
netprocess Infomation FSP_network_protocol_5.4.4_R2:
version: 1.7.1.208027 [14:44:08-Jan  9 2018].
Path: /Camera/Platform/Branches/branches_FSP_network_protocol/FSP_network_protocol_5.4.4_R2
Last Changed Rev: 354160
Last Changed Date: 2018-01-08 16:36:02 +0800 (Mon, 08 Jan 2018)
wait davinci set default...
[01-01 01:21:42][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:42][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:42][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:42][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
infd read End
Unix bus   0 .
[01-01 01:21:43][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:43][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:43][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:43][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
App Start ...
[01-01 01:21:44][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:44][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:44][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:44][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 01:21:45][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:45][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:45][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:45][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 01:21:46][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:46][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:46][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:46][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 01:21:47][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:47][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:47][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:47][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 01:21:48][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:48][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:48][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:48][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 01:21:49][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:49][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:49][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:49][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 01:21:50][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:50][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:50][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:50][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
IEfile uncompressed.
BusyBox v1.2.1 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
MAC ioctl error!
# [01-01 01:21:51][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:51][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:51][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:51][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 01:21:52][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:52][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:52][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:52][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 01:21:53][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:53][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:53][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:53][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 01:21:54][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:54][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:54][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:54][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 01:21:55][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 01:21:55][pid:321][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10012]
[01-01 01:21:55][pid:321][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:55][pid:321][UNI_IF][ERROR]communicaite_to_davinci failed!!!
Bingo errno 2  /home/davinci.lzma
Unix bus  End
=========main
=========user_sysinit  =====
[01-01 01:21:55][pid:0][OTHER][ERROR]CUSTOM_PATH open error.No such file or directory
[01-01 01:21:55][pid:0][OTHER][ERROR]analysis_custom_devtype error
-------Goint to init_database-4915
davinci enter init_database
shared memory address is: 0x40513000, sizeof(DEVICECONFIG) = 887608
davinci init_shared_memory success.
powerLineFrequencyMode = 0
[01-01 01:21:55][pid:0][UNI_IF][ERROR]stream request out range 3(2)
After set_devcfg_default, database need to init
[01-01 01:21:55][pid:316][IPC][ERROR]daemon can not find Dst process.load_type 0x10026 is_need_ack 1
[01-01 01:21:55][pid:320][IPC][ERROR] from daemon ack, dst not work  len 0 , load_type is [0x10026]
[01-01 01:21:55][pid:320][DATABASE][ERROR][uni_process/DB_uni_process.c 203][get_devcapa_data]65574:ipc_unix_call_service failed, ret = -3.
[01-01 01:21:55][pid:320][DATABASE][ERROR][main/DB_main.c 139][main]get capa chan_num failed...
going to init database:1
Davinci wait for init dababase
davinci receive cmd_query_davinci_param.
S: cmd_query_davinci_param
[01-01 01:21:57][pid:320][DATABASE][DEBUG][main/dbutil.c 1600][db_checkandrecovery]db_main check num=0
[01-01 01:21:57][pid:320][DATABASE][DEBUG][main/dbutil.c 1605][db_checkandrecovery]main db is ok
[01-01 01:21:58][pid:320][DATABASE][ERROR][main/dbutil.c 8149][init_database]db version = 299264
db_enc_version = 16777472
[01-01 01:21:58][pid:320][DATABASE][DEBUG][main/dbutil.c 6424][db_getdata_byversion]The database need patch up
S: cmd_check_capa_support  ,ack -1
[01-01 01:21:58][pid:320][DATABASE][DEBUG][uni_process/DB_uni_process.c 137][communicaite_to_davinci]communicaite_to_davinci 65566 : service_result 255
[01-01 01:21:58][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[10].get is null
[01-01 01:21:58][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[34].get is null
[01-01 01:21:58][pid:320][DATABASE][DEBUG][main/dbshell.c 20111][db_get_ipdome_ptzparam] ipdome_ptzparam_table is not exist
[01-01 01:21:58][pid:320][DATABASE][DEBUG][main/dbshell.c 16801][db_get_roi_param] roi_param_table is not exist
get 0-0-0-0.000000-0-0-0
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[93].get is null
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[94].get is null
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[95].get is null
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[96].get is null
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[97].get is null
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[98].get is null
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[99].get is null
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[100].get is null
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[121].get is null
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 535][get_alldata_from_db]tables_fun[122].get is null
[01-01 01:21:59][pid:320][DATABASE][DEBUG][main/dbshell.c 43049][db_get_sdi_local_output_config]select sdi_local_output_enable, local_output_hd from front_other_config where idx=1;
[01-01 01:21:59][pid:320][DATABASE][DEBUG][main/dbshell.c 43189][db_get_sdi_485_enable_config]select rs485_enable from serial_config_table where serial_type=2;
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 528][get_alldata_from_db]device do not support intell monitor
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 518][get_alldata_from_db]device do not support color filter
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 508][get_alldata_from_db]device do not support judicial
[01-01 01:21:59][pid:320][DATABASE][DEBUG][main/dbutil.c 1751][add_column]add column pt_mode to table ipdome_osdparam_table
[01-01 01:21:59][pid:320][DATABASE][DEBUG][main/dbutil.c 1756][add_column]column pt_mode already exists in table ipdome_osdparam_table
[01-01 01:21:59][pid:320][DATABASE][DEBUG][main/dbutil.c 1751][add_column]add column revise_mode to table revise_gps_param_config
[01-01 01:21:59][pid:320][DATABASE][DEBUG][main/dbutil.c 1756][add_column]column revise_mode already exists in table revise_gps_param_config
[01-01 01:21:59][pid:320][DATABASE][DEBUG][main/dbutil.c 1751][add_column]add column byBackgroundPic to table intelligent_face_detect_config
[01-01 01:21:59][pid:320][DATABASE][DEBUG][main/dbutil.c 1756][add_column]column byBackgroundPic already exists in table intelligent_face_detect_config
[01-01 01:21:59][pid:320][DATABASE][DEBUG][main/dbutil.c 1751][add_column]add column satellite_interval to table ntp_config_info
[01-01 01:21:59][pid:320][DATABASE][DEBUG][main/dbutil.c 1756][add_column]column satellite_interval already exists in table ntp_config_info
[01-01 01:21:59][pid:320][DATABASE][ERROR][main/dbutil.c 8159][init_database]ipc_db_backup need backup.
[01-01 01:22:00][pid:320][DATABASE][DEBUG][main/DB_main.c 154][main]After init_database...
goint to set_semvalue 1...
This is database process,  table_name = 0,load_type = 0x6001e
channel_no = 0, sensor_no = 0, smd_type = 0, scene_no = 0
EN_GET_CURRENT_DB_VERSION----
This is database process,  table_name = 302080,load_type = 0x6001f
EN_GET_OLD_DB_VERSION----
current_db_version = 302080,  old_db_version = 299264
current_db_version = (302080-1180),  old_db_version = (299264-1169)
This is database process,  table_name = 299264,load_type = 0x6001c
EN_SET_DB_VERSION----
This is database process,  table_name = 0,load_type = 0x6006d
---------------------This is backup_dev_cfg-------------------
database going to sleep----------
This is database process,  table_name = 0,load_type = 0x6001c
database init success, davinci wait sem success
init_database success...
-------end to init_database-4920
This is database process,  table_name = 0,load_type = 0x6001d
channel_no = 887608, sensor_no = 0, smd_type = 0, scene_no = 0
EN_CHECK_DEVCFG_THE_SAME----
reboot reason is not valid, do nothing
<init_run>4414:capture_mode(5) value. 83978265
<MEGA_DSP>Platform Value:
<MEGA_DSP>Main mux type [0x1].
<MEGA_DSP>Sub	mux type [0x4].
<MEGA_DSP>Thi  mux type [0x2].
<MEGA_DSP>audio enc type[0x1].
<MEGA_DSP>voicetalk type[0x1].
<MEGA_DSP>Need PS SysHdr[1].
rmmod: can't unload 'hi3518_adec': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_aenc': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_ao': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_ai': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_sio': unknown symbol in module, or unknown parameter
rmmod: can't unload 'acodec': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hidmac': unknown symbol in module, or unknown parameter
remove audio
rmmod: can't unload 'uart232': unknown symbol in module, or unknown parameter
rmmod: can't unload 'ssp_iris': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_ive': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_vda': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_region': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_rc': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_jpege': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_h264e': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_chnl': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_group': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_venc': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_vou': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_vpss': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_isp': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_viu': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_dsu': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_tde': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hiuser': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_sys': unknown symbol in module, or unknown parameter
rmmod: can't unload 'hi3518_base': unknown symbol in module, or unknown parameter
rmmod: can't unload 'mmz': unknown symbol in module, or unknown parameter
insert audio
[01-01 01:22:06][pid:0][SYSINIT][ERROR]device not support RS485
[01-01 01:22:06][pid:0][HW_IF][ERROR]r2 transfer_485_config_options error [options:57]
fpga_info.beuse is 0, not use fgpa
*** Board tools : ver0.0.1_20120501  ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x200f00c0: 0x00000000 --> 0x00000001
[END]
@@@@@@@@@@@@@@CAPA_SUPPORTEDss 2 led
<lib>pDspInitParaArmlib = 0x411f0008,share buf len 0x84db0, fontInfo=0x41274d9c, bBufStatus = 1, vpfont=0x412af008, fontLen=766080
 ******viType :   [32]********************************************
[dsp]InitHeapMem
[dsp]pDspInitPara->AbilityInitSet = 0xa0100140
[dsp]DENOISE ability is initialized
[dsp]pDspInitPara->memAllocAppSet = 0xa0000050
[dsp]###encChanCnt 4, dspMemSize 59 MB
[dsp]pDspInitPara->VideoInitParam.max_viW 1280,pDspInitPara->VideoInitParam.max_viH 720
[dsp]g_video_param.captureMode.imageW 1280
[dsp]g_video_param.captureMode.imageH 720
[dsp]g_video_param.captureMode.original_viW 1280
[dsp]g_video_param.captureMode.original_viH 720
[dsp]g_video_param.max_viW 1280
[dsp]g_video_param.max_viH 720
[dsp]g_video_param.sensor_type 0
[dsp]g_video_param.captureMode.frame_rate 6400
[dsp]g_video_param.videoProcParam.b3dNf 1
[dsp]g_video_param.videoProcParam.viewMirror 0
[dsp]@@@@@@@@pDspInitPara->viType=32, sensor_id=3
[dsp]ISP_GetMemSize  =  8688
ISP_Create:sensor id = 3.
[dsp]pDspInitPara->dspDynParam.bSmart264 = 0
<lib> dspTaskCreat ok!
[dsp]after ISP_Create sensor_id 3
[dsp]r2ViStartChn. orgW=1280, orgH=720. imgW=1280, imgH=720
[dsp]x/y/w/h, 0,0,1280,720
[dsp]############################-g_video_param.viewMirror 0x0
[dsp]@HI_MPI_VI_SetRotate!!!!!!!!!!!!!
[dsp]VI caprect.x=0,caprect.y=0,capw=1280,caph=720,desw=1280,desh=720
[dsp](g_video_param.captureMode.viStandard == 2)
[dsp]r2ViInit OK!
[dsp]create vpss grp 0 success
[dsp]grp 0, chn 0, w=1280, h=720
[dsp]grp 0, chn 1, w=720, h=576
[dsp]grp 0, chn 3, r2EncCtrl w=0, r2EncCtrl h=0
[dsp]grp 0, ext chn 3, w=64, h=64
[dsp]create vpss grp 1 success
[dsp]grp 1, chn 1, w=704, h=576
[dsp]videoProcessInit successful!
[DSP][INF]---Enter R2VDA_MDInit
[DSP][INF]---R2VDA_MDInit success
[dsp]error:pDspInitPara->fontShareInfo.bBufStatus != SHARE_BUF_LOAD. status=1
[dsp]osdLineMaxWidth=1280
[dsp]setup_water_mark_buffer
[dsp]idx=0, pInfo->vAddr=43bf7000
[dsp]idx=1, pInfo->vAddr=41f1c000
[dsp][µЪИэВ·Ншґ«УлµЪ¶юВ·К№УГН¬Т»»єіеЗш]
[dsp]idx=0, pInfo->vAddr=421fe000
[dsp]idx=1, pInfo->vAddr=429a0000
[dsp]idx=0, pInfo->vAddr=40066000
[dsp]idx=1, pInfo->vAddr=401f1000
[dsp]Upload stream buffer physic addr:0x43cf7000,Len:2097152
[dsp]HI_UNF_CIPHER_CreateHandle Audio chan 0
[dsp]HI_UNF_CIPHER_CreateHandle Audio chan 1
[dsp]HI_UNF_CIPHER_CreateHandle Audio chan 2
[dsp]HI_UNF_CIPHER_CreateHandle Audio chan 3
[dsp]HI_UNF_CIPHER_CreateHandle Video chan 0
[dsp]HI_UNF_CIPHER_CreateHandle Video chan 1
[dsp]HI_UNF_CIPHER_CreateHandle Video chan 2
[dsp]r2InitAudio!!!!!!!!!
[dsp][wq]samprate = 8000
[dsp]ACODEC_SET_MIC_MUTE 1
[dsp]ACODEC_SET_ADCL_VOL vol_ctrl_mute 1
[dsp]r2AcodecCfgAudio = 0
AEC_Init error framelen(320)
[Func]:MPI_AI_AecInit [Line]:369 [Info]:aec open fail.
[dsp]r2AudioStartAi = 0
[dsp]r2AudioStartAo = 0
[dsp](HI_TRUE == gs_bUserGetMode)
[dsp]InitAudioEncode pParam->encType 0
[dsp]InitAudioTalkBack pParam->talkBackType 7
[dsp]InitAudioTalkBack: INVALID audio param!!!
[dsp]  audioType                = 7
[dsp]  talkBackSamplesPerSecond = 32000
[dsp]  talkBackBitRate          = 64000
[dsp]  talkBackSamplesPerFrame  = 1024
[dsp]  boardSamplesPerSecond    = 8000
[dsp]  boardOutSamplesPerSecond = 32000
[dsp]pAudioTB->frameLen = 1[dsp]dsp_mmzZone_init done!!!!!!
[dsp]TSK_processTimer
[dsp]Start TSK_Encode!
[dsp]TSK_ProcessOsdRefresh
[dsp]TSK_ViSignal
[dsp]TSK_ProcessVDA Start!!!
[dsp]TSK_UpdateAi
[dsp]start Audio_Changed
[dsp]!!!!!!!!!!!!!TSK_EncodeAudio
[dsp]!!!!!!!!!!!!!TSK_TalkBack
[dsp]TSK_Init successful
[dsp]task_dpc
host cmd. start!!!!!! HostSetAesSecretKey 0 !!!!!!!!
NOTIFY:HostSetAesSecretKey not Enable![01-01 01:22:09][pid:0][DSP][ERROR]Initial: the permanent code is disable.
[dsp]---host cmd. HostSetSoundLevel
[dsp]ACODEC_SET_MIC_MUTE 0
[dsp]ACODEC_SET_ADCL_VOL vol_ctrl_mute 0
[dsp]audInVolume=85 1a,audOutVolume=a
This is database process,  table_name = 0,load_type = 0x60032
[01-01 01:22:09][pid:0][UNI_IF][ERROR]iFd=32(/dev/hikio),errno=5(Input/output error) ioctl error!
[01-01 01:22:09][pid:0][SYSINIT][ERROR]######### sys upg part info set error! ########
[PSWD][0070]:public_base64_len 188  len 140
[dsp]host cmd. HostSetEncOsd
[dsp]SetOsd invalid encode chan 0 is not start
[dsp]SetOsd invalid encode chan 1 is not start
[dsp]SetOsd invalid encode chan 2 is not start
[dsp]SetOsd invalid encode chan 3 is not start
[dsp]host cmd. HostSetEncOsd over, attrType=0 chan = 0
[01-01 01:22:09][pid:0][OTHER][ERROR]Cannot get current device settings
[01-01 01:22:09][pid:321][UNI_IF][ERROR]
 ===eth0===starting DHCP...
[01-01 01:22:09][pid:0][OTHER][ERROR]set_mtu ioctl error and errno=19
[01-01 01:22:09][pid:0][OTHER][ERROR]initNetIf: set_mtu failed.
[01-01 01:22:09][pid:321][UNI_IF][ERROR]start DHCP client failed.
[01-01 01:22:10][pid:321][UNI_IF][ERROR]
 ===Davinci  Init Finish...
S: cmd_get_enable_list
[01-01 01:22:11][pid:321][UNI_IF][ERROR]
[01-01 01:22:11][pid:0][OTHER][ERROR]Bind to interface failed.
[01-01 01:22:11][pid:0][OTHER][ERROR]Open fd failed.
--------------usrapp:maxEnChanNo = 1 ----------------
[01-01 01:22:11][pid:0][SYSLOG][ERROR]no main log. system log will not work.
[01-01 01:22:11][pid:0][SD][ERROR]do not support
[01-01 01:22:11][pid:0][SD][ERROR]<sdctrl>access_times = 1, partition /dev/mmc01 don't exist and errno=2.
[01-01 01:22:11][pid:321][UNI_IF][ERROR]start DHCP client failed.
[dsp]HostSetWatermarkSecretKey chan 0
[dsp]chan 0 type:0,mode:1,keylen:12
[dsp]chan 0 :h,i,k,v,i,s,i,o,n,k,e,y
[dsp]HostSetWatermarkSecretKey chan 1
[dsp]chan 1 type:0,mode:1,keylen:12
[dsp]chan 1 :h,i,k,v,i,s,i,o,n,k,e,y
[dsp]host cmd. HostSetCapMode
[01-01 01:22:12][pid:321][UNI_IF][ERROR]
 isDm365WifiIPCAM=1
[01-01 01:22:12][pid:321][UNI_IF][ERROR]g_wifi_chip_type :[3], line = 1117
[01-01 01:22:12][pid:321][UNI_IF][ERROR]g_wifi_chip_type : 3, line = 1223.
[01-01 01:22:12][pid:0][SD][ERROR]<sdctrl>access_times = 2, partition /dev/mmc01 don't exist and errno=2.
[01-01 01:22:12][pid:0][SD][ERROR]<sdctrl>access_times = 3, partition /dev/mmc01 don't exist and errno=2.
[01-01 01:22:13][pid:0][SD][ERROR]<sdctrl> partition /dev/mmc01 don't exist and errno=2.
[01-01 01:22:13][pid:0][HDMANAGER][ERROR]hard disk(0, 0) has no partition.
[01-01 01:22:13][pid:0][SD][ERROR]The sd card is inserted and begin to set_sd_status_for_alarm.
This is database process,  table_name = 0,load_type = 0x60028
S: cmd_save_wlan_param
[01-01 01:22:13][pid:321][UNI_IF][ERROR]wifi start.
S: cmd_initSADP
[01-01 01:22:14][pid:0][OTHER][ERROR]get_netmask ioctl error and errno=99
Event SCAN_RESULTS (3) received[01-01 01:22:14][pid:321][UNI_IF][ERROR]>>>>>>>>>> init wifi net work
S: cmd_check_capa_support  ,ack 1
 ssid not equal davinci or read ssid param erro
 try to connect  TP-LINK_CTAC.
[DSP][INF]host cmd. HostSetVoStandard. is vostart = 1
[DSP][WRN]HostSetVoStandard. device has no cap of vo
[dsp]HostSetEncoderParam chan = 0
[dsp]pInit->IFrameInterval = 125
[dsp]pInit->BFrameNum = 0
[dsp]pInit->streamType = 1003
[dsp]pInit->resolution = 4115
[dsp]pInit->quarter = 0
[dsp]pInit->quality = 9
[dsp]pInit->bpsType = 0
[dsp]pInit->max_delay = 4
[dsp]pInit->max_quant = 38
[dsp]pInit->min_quant = 0
[dsp]pInit->bps = 1048576
[dsp]pInit->avgbps = 1048576
[dsp]pInit->fps = 0/0
[dsp]pInit->encType.videoType = 2
[dsp]pInit->encType.profile = 1
[dsp]pInit->i_qp_offset_level = 50
[dsp]<r2CfgBitRateAdaptor>AbilityInitSet not support dyn bitrate encode ,just use high bit rate param config!
[dsp]##################encode param changed
[dsp]r2EncCtrl[0].bStart: 0
[dsp]warning:HI_MPI_VENC_UnRegisterChn 0 faild, err=0xa0078005
[dsp]warning:HI_MPI_VENC_DestroyChn 0 faild, err=0xa0078005
[dsp]warning:HI_MPI_VENC_DestroyGroup 0 faild, err=0xa0078005
[dsp]!!!!!!!!!!!!!HI_MPI_VENC_DestroyGroup 0
[dsp]r2EncCtrl->encW == 0 || r2EncCtrl->encH == 0
[dsp]HostInsertIFrame chan=0
[dsp]warning: enc 0 is not started, just return ok
[dsp]HostSetMask setType=0
[dsp]HostSetMask INVALID region param, region=0, x=0, y=0, w=0, h=0
[dsp]HostSetMask INVALID region param, region=1, x=0, y=0, w=0, h=0
[dsp]HostSetMask INVALID region param, region=2, x=0, y=0, w=0, h=0
[dsp]HostSetMask INVALID region param, region=3, x=0, y=0, w=0, h=0
[dsp]r2SetMcdSkip cnt 5
[dsp]r2SetScdSkip cnt 15
[dsp]HostSetMask setType=1
[dsp]HostSetMask setType=2
[dsp]HostSetCd enable=1, level=2, delay=1
[01-01 01:22:14][pid:0][DSP][ERROR]read_logofile_to_buf failed: width=0, height=0
streamRecord[1]: start...
[dsp]HostSetEncoderParam chan = 1
[dsp]pInit->IFrameInterval = 50
[dsp]pInit->streamType = 1001
[dsp]pInit->resolution = 4097
[dsp]pInit->quality = 17
[dsp]pInit->bps = 524288
[dsp]pInit->avgbps = 419430
[dsp]pInit->fps = 25/1
[dsp]r2EncCtrl[1].bStart: 0
[dsp]warning:HI_MPI_VENC_UnRegisterChn 1 faild, err=0xa0078005
[dsp]warning:HI_MPI_VENC_DestroyChn 1 faild, err=0xa0078005
[dsp]warning:HI_MPI_VENC_DestroyGroup 1 faild, err=0xa0078005
[dsp]!!!!!!!!!!!!!HI_MPI_VENC_DestroyGroup 1
[dsp]HostInsertIFrame chan=1
[dsp]warning: enc 1 is not started, just return ok
FAIL
[01-01 01:22:16][pid:0][OTHER][ERROR]get_ipaddr failed.
[01-01 01:22:16][pid:0][OTHER][ERROR]inet_aton failed ,errno = 2, ip =
Event SCAN_RESULTS (3) receivedOK
0
OK
OK
OK
[01-01 01:22:16][pid:0][OTHER][ERROR]get_netmask ioctl error and errno=99
OK
appweb: 1: MPR services are ready
OK
OK
appweb: 1: Starting host named: "::"
appweb: 1: Starting host named: "httpsHost"
appweb: 1: appwebTask: mprStartEventsThread Success.....
[01-01 01:22:19][pid:0][ALARM_EXP][ERROR]hwif_setalarmout err.
[dsp]pEncStatus[chan]->bImageMasked = 1
[dsp]HostStartEncode chan = 0
[dsp]####In the beginning of r2StartEncode, pCtrl->bStart = 0
[dsp]SetEncRes :chan=0, w=1280 ,h=720,pitch=1280/1280,bAllocMem=1,bDeinterlace=0
[dsp]r2SetEncRes success
[dsp]bSmart264 =0 h264Mode=1
[dsp]enType 96,pCtrl->encW 1280, pCtrl->encH 720, pParam->bps 938840, pParam->encType.profile 1, pParam->fps 0x10019,g_video_param.frame_rate 0x1900, bitRateAdaptor[chan]->statTime 4,bitRateAdaptor[chan]->bfixMaxQp 0
[dsp]r2ConfigEncode, viFps = 25
[dsp]@@!!!!!!stH264Vbr.u32ViFrmRate 25,stH264Vbr.fr32TargetFrmRate 65561,fps=10019
[dsp]pParam->encType.b_svc_mode 0
[dsp]enc_setDefaultEncRef ok!!!!
[dsp]set h264 ipcm false
[dsp]encFps&0xffff = 25
[dsp]group 0, chn 0, r2EncCtrl w=1280, r2EncCtrl h=720
[dsp]group 0, chn 3, r2EncCtrl w=0, r2EncCtrl h=0
[dsp]grp 2 don't exist, continue
[dsp]grp 3 don't exist, continue
[dsp]grp 4 don't exist, continue
[dsp]grp 5 don't exist, continue
[dsp]####charCnt = 24####
[dsp]<SetOsd> osdScaleW=1, osdScaleV=1, charCnt 15, x 0,y 672
[dsp]<SetOsd> osdScaleW=1, osdScaleV=1, charCnt 9, x 928,y 672
[dsp]x 320  pLine->x 32 ,pLine->y 672, w 16
[dsp]x 1056  pLine->x 928 ,pLine->y 672, w 16
[dsp]!!!!valid line num 0
[dsp]!!!!valid line num 1
[dsp]warning: AbilityInitSet has no user pic, just return ok
[dsp][wqtest2]VencGrp=0,bEnable=0
[dsp]#######################r2StartEncode success. chan = 0
[dsp]StartAudioEncode: chan=0, audioType=0
[dsp]r2ViStop
[dsp]start Aud_checkHandle srcChan=0,procType=0,audioType=7110
[dsp]srcChan=0,procType=0,audCtrl[0].bValid=1,audCtrl[0].bUsed=0
[dsp]UpdateEncWindowRect:g_video_param.captureMode.image_viW 1280,  g_video_param.captureMode.image_viH 720
[dsp]HostStartEncode chan = 0 success
[dsp]HostSetWatermark chan 0
[DSP][INF]---host cmd. HostSetMd.level=0
[DSP][INF]---R2VDA_MDStop. mdState=1, is not runing, just return
[DSP][INF]---cfg model is 1
[DSP][INF]---enter R2VDA_MDConfigModelNew
[DSP][INF]---region[0] bRegionEnable is 0
[DSP][INF]---mdRegion[0] is vaild. level is 50. param is 0
[DSP][INF]---region[1] bRegionEnable is 0
[DSP][INF]---region[2] bRegionEnable is 0
[DSP][INF]---region[3] bRegionEnable is 0
[DSP][INF]---region[4] bRegionEnable is 0
[DSP][INF]---region[5] bRegionEnable is 0
[DSP][INF]---region[6] bRegionEnable is 0
[DSP][INF]---region[7] bRegionEnable is 0
[DSP][INF]---R2VDA_MDConfigModelNew success
[DSP][INF]---R2VDA_MDStart. mdState is stop, will bind and receive pic
[dsp]R2VDA_MDStart mdState is 3
[DSP][INF]---host cmd. HostStartMd
[DSP][INF]---R2VDA_MDStart. md is already started, just return OK
[dsp]Host cmd Set Roi, chan=0
[dsp]roiMode=0 regionCnt=0, fdLevel=2
[dsp]HostSetEncRoi: valid region cnt = 0
[dsp]HostSetEncRoi: encode type=2
[dsp]Host cmd Set Roi, chan=1
[dsp]HI_MPI_VENC_GetRoiCfg chan 1 failed with 0xa0078005!
<lib>cmd error!!cmd =139,cmdIdx =39 err==0xffffffff(-1)
[dsp]Host cmd Set Roi, chan=2
[dsp]HostSetEncRoi: encode type=0
[dsp]warning: HostSetEncRoi, encType is not h264. type=0
[01-01 01:22:19][pid:0][CAPA][ERROR]Get capa error, the type is [0], the pData is NULL .
[dsp]host cmd. stop ivs
[01-01 01:22:19][pid:0][PREVIEW][ERROR]in pDevCfgParam max packetlen = 1440
[01-01 01:22:19][pid:0][PREVIEW][ERROR]packetlen = 1440
[dsp]/********************Config Pack Param*******************/
[dsp]chan=0, packId=0, packType=4
[dsp]setRtpMuxInfo: video payload = 96, audio payload = 0
[dsp]chan=0, packId=1, packType=4
[dsp]chan=0, packId=2, packType=16
[dsp]info:r2SetEncoderParam chan=1, param not changed, return ok
[dsp]HostStartEncode chan = 1
[dsp]SetEncRes :chan=1, w=352 ,h=288,pitch=352/352,bAllocMem=1,bDeinterlace=0
[dsp]enType 96,pCtrl->encW 352, pCtrl->encH 288, pParam->bps 501760, pParam->encType.profile 1, pParam->fps 0x10019,g_video_param.frame_rate 0x1900, bitRateAdaptor[chan]->statTime 4,bitRateAdaptor[chan]->bfixMaxQp 0
[dsp]group 0, chn 3, r2EncCtrl w=352, r2EncCtrl h=288
[dsp]<SetOsd> osdScaleW=0, osdScaleV=0, charCnt 15, x 0,y 272
[dsp]<SetOsd> osdScaleW=0, osdScaleV=0, charCnt 9, x 256,y 272
[dsp]x 160  pLine->x 16 ,pLine->y 272, w 8
[dsp]x 320  pLine->x 256 ,pLine->y 272, w 8
[dsp][wqtest2]VencGrp=1,bEnable=0
[dsp]#######################r2StartEncode success. chan = 1
[dsp]StopAudioEncode
[dsp]HostStartEncode chan = 1 success
[dsp]HostSetWatermark chan 1
[01-01 01:22:19][pid:0][PREVIEW][ERROR]g_metadata_mem[1].base = 2f1f418
[01-01 01:22:19][pid:0][PREVIEW][ERROR]g_metadata_mem[1].totalsize = 92160
[01-01 01:22:19][pid:0][PREVIEW][ERROR]g_metadata_mem[1].ridx = 0
[01-01 01:22:19][pid:0][PREVIEW][ERROR]g_metadata_mem[1].widx = 0
[01-01 01:22:19][pid:0][PREVIEW][ERROR]g_metadata_mem[1].packetlen = 1440
[01-01 01:22:19][pid:0][PREVIEW][ERROR]g_metadata_mem[1].peer_packetlen = 1440
[dsp]chan=1, packId=0, packType=4
[dsp]chan=1, packId=1, packType=32
[dsp]chan=1, packId=2, packType=16
maxEnChanNo=1 is_support_mpeg4=1
[01-01 01:22:19][pid:0][PTZ][ERROR]read  PTZFILEHEAD error!,1 0
[01-01 01:22:19][pid:0][PTZ][ERROR]fread erro 2242
[01-01 01:22:19][pid:0][SYSINIT][ERROR]initSADP failed
[01-01 01:22:19][pid:0][ARP][ERROR]get_ipaddr err!
[01-01 01:22:19][pid:0][ARP][ERROR]send_arp ping  faild!
[01-01 01:22:19][pid:0][OTHER][ERROR]Bind to interface failed.
[01-01 01:22:19][pid:0][OTHER][ERROR]Open fd failed.
[01-01 01:22:19][pid:0][SNTP][ERROR]tcp_connect_hik: hik_getaddrinfo failed ru.pool.ntp.org,123,Name or service not known
[01-01 01:22:19][pid:0][SNTP][ERROR]Get time form ru.pool.ntp.org:123 failed
[01-01 01:22:19][pid:0][SNTP][ERROR]startSNTP: hiksntpc failed ret -1. ntpSrv[ru.pool.ntp.org], timeZone[3:0]
[01-01 01:22:20][pid:0][SYSINIT][ERROR]all player header have got success!
[dsp]HostStopEncode chan = 1
[dsp]#######################r2StopEncode, chan=1
[dsp][wqtest1]VencGrp=1,bEnable=0
[dsp]RefreshPackIdx ####pCtrl->netPackParam[0].pInfo->lastFrmIdx = pCtrl->netPackParam[0].pInfo->packetWIdx = 0
[dsp]RefreshPackIdx ####pCtrl->netPackParam[1].pInfo->lastFrmIdx = pCtrl->netPackParam[1].pInfo->packetWIdx = 0
[dsp]RefreshPackIdx ####pCtrl->netPackParam[2].pInfo->lastFrmIdx = pCtrl->netPackParam[2].pInfo->packetWIdx = 0
[dsp]HostStopEncode chan = 1 success
[01-01 01:22:20][pid:0][SENSOR][ERROR]infraredFbVal [-1] err
[DSP][INF]---R2VDA_MDStop. unbind vi and stop receive pic
[01-01 01:22:20][pid:0][ONVIF][ERROR]is_discovery_init, before wait_net_available
[01-01 01:22:20][pid:0][SYSINIT][ERROR]before onvif_discovery_init_wifi g_wifi_interface,
[01-01 01:22:20][pid:0][ONVIF][ERROR]is_discovery_init, before wait_wireless_net_available
[01-01 01:22:20][3][719]RemoteSession::~RemoteSession()
[01-01 01:22:20][3][719]RemoteSession::Free
firmware_version: V5.4.81 build 180203, firmware_id_code: 00000001000000010000010000110b0b00000001000000080000000000000002
start_ezviz_service, dinfo 4d3c87c4, token 4d3c8e84
[01-01 01:22:20][3][719]unix socket file path: /tmp/ipc_230633170
[01-01 01:22:20][3][719]access token begin
decrypt begin
decrypt end
[01-01 01:22:20][3][719]access token success
[01-01 01:22:20][1][719]################ezviz main start################
[01-01 01:22:20][1][719]opensdk version: V1.5.6 build 161227
[01-01 01:22:20][1][719]################ezviz main start, over################
[01-01 01:22:20][2][721]check remote session thread begin
[01-01 01:22:20][2][722]main routine begin
[01-01 01:22:20][2][722]session init finish!
[01-01 01:22:20][2][722]port init finish!
[01-01 01:22:20][3][722]max p2p link num 3
start dev log ctrl!
[01-01 01:22:20][3][724]process message routine begin...
gethostbyname_r: Network is unreachable
[01-01 01:22:20][1][724]ezviz_das DNS dev.hik-connect.com parse error
[01-01 01:22:20][3][725]open socket 62 success
[01-01 01:22:20][3][725]BindToDeviceName
[01-01 01:22:20][3][725]start to accept new connection, listen port 9010
[01-01 01:22:20][3][726]open socket 63 success
[01-01 01:22:20][3][726]BindToDeviceName
[01-01 01:22:20][3][726]start to accept new connection, listen port 9020
[01-01 01:22:20][3][727]detec_stun_routine begin
[01-01 01:22:20][3][727]detec_stun_routine start.........
[01-01 01:22:20][1][727]the stun server is not valid
[01-01 01:22:20][3][727]open socket 64 success
[01-01 01:22:20][3][727]BindToDeviceName
[01-01 01:22:20][3][727]start to connect lbs dev.hik-connect.com:8555, type 1...
[01-01 01:22:20][1][727]connect lbs domain dev.hik-connect.com:8555 error, errno 101: Network is unreachable
[01-01 01:22:20][3][727]close socket 64 success
[01-01 01:22:20][3][727]on_get_user_id 0x296454
[01-01 01:22:20][3][727]userid 0000000000000000
[01-01 01:22:20][3][727]detec_stun_routine end, sleep 300 s
[01-01 01:22:20][3][728]start udp hole punch thread..., link count = 3
[01-01 01:22:20][1][728]RLIMIT getrlimit rlim_cur = 2048 max = 20480
[01-01 01:22:20][1][728]RLIMIT X fd rlim_cur = 2048 max = 20480
[01-01 01:22:21][pid:0][OTHER][ERROR]get_netmask ioctl error and errno=99
[01-01 01:22:21][pid:0][ONVIF][ERROR]ptz not support
[DSP][INF]---host cmd. HostStopMd
[01-01 01:22:22][pid:0][OTHER][ERROR]eth0 get_ipaddr error
[01-01 01:22:25][pid:0][SENSOR][ERROR]infraredFbVal [-1] err
Fakeoke
Сообщение Fakeoke » 12 окт 2020, 17:13
Fakeoke писал(а):
12 окт 2020, 08:01
Код: Выделить всё
error: upfsd.
HKVS #
сам спросил сам отвечу.
это флешка не подходит.
должна быть FAT флешка.
прошил с помощью флешки 4гб, почему то только она форматировалась в фат. остальные в нтфс или фат32 не хотели шить.
серийный номер указана также сзади, штрих код не надо.
настроил и облачный просмотр и на микросд запись, вроде ок все
p1tr0l1um
Сообщение p1tr0l1um » 20 окт 2020, 13:45
Fakeoke писал(а):
12 окт 2020, 09:06
Код: Выделить всё
DRAM:  128 MiB
Flash: 16 MiB
OK
Starting kernel ...
/home
Insmod ko start...
Insmod ko end...
infd read End
Unix bus   0 .
App Start ...
MAC ioctl error!
Unix bus  End
=========main
remove audio
insert audio
[END]
[dsp]InitHeapMem
[dsp]r2ViInit OK!
[dsp]  audioType                = 7
[dsp]TSK_ViSignal
[dsp]TSK_UpdateAi
[dsp]task_dpc
 isDm365WifiIPCAM=1
S: cmd_initSADP
FAIL
0
OK
OK
OK
OK
OK
OK
[dsp]r2ViStop
decrypt begin
decrypt end
start dev log ctrl!
Добрый день, не поделитесь дампом f2irc.org@gmail.com? :oops: Каким програматором шили, если не секрет?
Alex744
Сообщение Alex744 » 21 ноя 2020, 14:02
VirtualLink писал(а):
06 сен 2020, 20:24
У ростелекома свои номера, не связанные с хиквижн никак!
Либо попадешь пальцем в небо и найдешь 9 символов от какого-то заведомо не работающего устройства, которое еще не зарегистрировано ни где, либо клон, либо не пользоваться облаком и номер любой!
У меня работает после прошивки с облаком и номер вписал который и был на камере ростелеком
Alex744
Сообщение Alex744 » 21 ноя 2020, 14:13
павел064 писал(а):
26 июл 2020, 21:15
изображение_viber_2020-07-26_22-13-39.jpgизображение_viber_2020-07-26_22-13-38.jpg11.jpg
Внизу слева она Macronix в SOP16
Mistertwister
Сообщение Mistertwister » 08 дек 2020, 08:57
Всем здравствуйте!
Прошу помощи специалистов. Имеется услуга видеонаблюдения от РТ. Установлена камера hikvision ds-i122 (в проге такое наименование, но на коробке - другое - hikvision ds-2cd3vc) с питанием по PoE. Проблема в том, что камера отваливается раз в 4 дня, примерно. Помогает только снятие питания с камеры (выдернуть провод из PoE-инжектора). Что было сделано: заменён свитч, к которому подключена камера, заменён PoE-инжектор, но, к сожалению, это не помогло. Как найти причину? Или сразу менять камеру и дело точно в ней? Спасибо!
Сообщение Рустам » 08 дек 2020, 09:31
Ещё вариант, что она отваливается при атаках по сети из интернета - можно попробовать её временно отключить от и-нета, но тогда она и у Вас показывать перестанет. Но, скорее она сама виснет ...
Сообщение AlienP666 » 08 дек 2020, 10:30
Много жалоб на глючные камеры от РТ в том числе и на этом форуме. Люди обновляются на родные прошивки и после никто не жаловался.
Amwey
Сообщение Amwey » 16 дек 2020, 21:54
Здравствуйте. Помогите пожалуйста разобраться, почему моя камера отказывается работать. Камера ds-i120. Была предпринята попытка прошить ее прошивкой с 24 страницы темы. По неопытности убил при прошивке родную флэшку в самопальном программаторе, а потому остается только идти до конца без возможности откатиться назад. Вот логи прошивки. Все шьется, но при загрузке получаю циклический ребут. И самое неприятное, ни каких ошибок в логах нет. Возможно я не правильно подготовил прошивку для флэшки (не верно прописал ID и MAC). Если не сложно покажите на примере как будут смотреться рандомные ID и MAC в HEX редакторе. В общем помогите кто чем может. Уже год бодаюсь с этой камерой, не могу заставить ее работать. Ваш форум последняя надежда ее оживить.
Код: Выделить всё
U-Boot 2010.06-243125 (Dec 15 2016 - 18:40:28)
DRAM:  128 MiB
Flash: 16 MiB
MMC:   MMC FLASH INIT: No card on slot!
Hit Ctrl+u to stop autoboot:  0
UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M
TFTP server found
TFTP from server 192.168.1.128; our IP address is 192.168.1.64
Download Filename 'digicap.dav'.
Download to address: 0x81000000
Downloading: #	[ Connected ]
################################	[ 1.000 MB]
################################	[ 2.000 MB]
################################	[ 3.000 MB]
################################	[ 4.000 MB]
################################	[ 5.000 MB]
################################	[ 6.000 MB]
################################	[ 7.000 MB]
################################	[ 8.000 MB]
################################	[ 9.000 MB]
################################	[10.000 MB]
done
Bytes transferred = 10681600 (a2fd00 hex)
Found 1 packets.
Skip file _cfgUpgSecPls
Skip file _cfgUpgClass
Erasing [sys] .........................................................done
Writing [sys] .................................................................done
write uImage len: 3499884 ok
Erasing [app] .................................................................done
Writing [app] .................................................................done
write app.img len: 7180288 ok
Upgrade success!
auto reboot now
resetting ...
и начались циклические перезагрузки
DRAM:  128 MiB
Flash: 16 MiB
|RCV UDP pack timeout| TFTP server not found
auto update with sd is not supported
   Data Size:    3499820 Bytes = 3.3 MiB
OK
Starting kernel ...
/home
Insmod ko start...
Insmod ko end...
DRAM:  128 MiB
Flash: 16 MiB
OK
Starting kernel ...
/home
Insmod ko start...
Insmod ko end...
DRAM:  128 MiB
Flash: 16 MiB
OK
Starting kernel ...
/home
Insmod ko start...
Insmod ko end...
DRAM:  128 MiB
Flash: 16 MiB
OK
Starting kernel ...
/home
Insmod ko start...
Insmod ko end...
DRAM:  128 MiB
Flash: 16 MiB
Hit Ctrl+u to stop autoboot:  2 <0>
Ах да. Совсем забыл. Эксперименты проводил с двумя прошивками с официального сайта. "Как есть" прошивки не влазят судя по логу. Обрезанные льются нормально, но камера не оживает. Резал строго по инструкции, в правильности процесса обрезки абсолютно уверен.
Amwey
Сообщение Amwey » 20 дек 2020, 01:17
Подскажите, что за микросхема 1810?
Сообщение AlienP666 » 21 дек 2020, 09:35
Похоже на SPI 25, возможно крипта.
