Изо выводит , камеы подключает . Висит заставка " подождите " . Меню не доступно .
На терминал выводит циклическую ошибку pppoe
Код: Выделить всё
[spoil=]
Adjusting /etc/ppp/pap-secrets and /etc/ppp/chap-secrets
(But first backing it up to /etc/ppp/pap-secrets-bak)
(But first backing it up to /etc/ppp/chap-secrets-bak)
pppoe-start........
Shutting down PPPoE link failure
Bringing up PPPoE link /usr/sbin/pppoe-connect: Check '/etc//ppp/pppoe.conf' -- no setting for USER
/usr/sbin/pppoe-start: line 97: expr: not found
sh: 10: unknown operand
[/spoil]
Дамп  прошивки есть .
 Процессор Hi3520D .
При нажатии ctrl+c  для stop autoboot  требует  пароль  (pwd )
[spoil=]
U-Boot 2010.06 (Jun 24 2013 - 03:11:20)
Spi(cs1) ID: 0xC2 0x20 0x17 0xC2 0x20 0x17
Spi(cs1): Block:64KB Chip:8MB Name:"MX25L6406E"
In: serial
Out: serial
Err: serial
Hit key to stop autoboot: 0
norm:1, res:6, upg:0
mmu_enable
<<imgwidth=720, imgheight=576, linebytes=1440>>
decode success!!!!
Image Name: Linux-3.0.8
Data Size: 1612884 Bytes = 1.5 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (root@debian) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #39 Thu Jul 18 00:57:27 EDT 2013
XSJ_Version:xsjkernel_v1.01_101
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: hi3520d
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 14224
Memory: 56MB = 56MB total
Memory: 52520k/52520k available, 4824k reserved, 0K highmem
Virtual kernel memory layout:
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc4000000 - 0xfe000000 ( 928 MB)
lowmem : 0xc0000000 - 0xc3800000 ( 56 MB)
.init : 0xc0008000 - 0xc0026000 ( 120 kB)
.text : 0xc0026000 - 0xc03c7000 (3716 kB)
.data : 0xc03c8000 - 0xc03e1f20 ( 104 kB)
.bss : 0xc03e1f44 - 0xc042df20 ( 304 kB)
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 75MHz, resolution 13ns, wraps every 57266ms
Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256)
console [ttyAMA0] enabled
bio: create slab <bio-0> at 0
SCSI subsystem initialized
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
L2cache cache controller enabled
JFFS2 version 2.2. (NAND) c 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 102
io scheduler noop registered
io scheduler cfq registered (default)
HDLC line discipline maxframe=4096
N_HDLC line discipline registered.
brd: module loaded
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 52
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 52
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:8MB
spi size: 0x8388608
chip num: 1
6 cmdlinepart partitions found on MTD device hi_sfc
Fixed MDIO Bus: probed
ata1: SATA link down (SStatus 0 SControl 300)
himii: probed
ata2: SATA link down (SStatus 0 SControl 300)
Invalid HW-MAC Address: 00:00:00:00:00:00
Set Random MAC address: CE:8C:1A:C5:1D:06
PPP Deflate Compression module registered
PPP BSD Compression module registered
SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
CSLIP: code copyright 1989 Regents of the University of California.
SLIP linefill/keepalive option.
hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
i2c /dev entries driver
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 10
VFS: Mounted root (jffs2 filesystem) on device 31:2.
Freeing init memory: 120K
[/spoil]
Как спрятать логи в сполер не нашел , извините .
